__________________________________________________
Caractéristiques du S97 (citation AVSForum) :
** Video
- Faroudja DCDi (Press release of Panasonic Japan officially mentioned the DCDi)
- Digital video output of 720p and 1080i up-conversion with HDMI
- Panasonic original 4:4:4 color upsampling
- 216Mhz / 11 bit video encoder for analog video output
- MPEG4 playback (SD Video(asf) / V : MPEG4 simple profile / A : G.726)
** Audio
- High-resolution digital audio output of DVD-Audio with HDMI, 192 khz / 24 bit / 2 ch
- High-resolution digital audio output of DVD-Audio with HDMI, 96 khz / 24 bit / 6 ch
- Advanced Multi Remaster
- Virtual battery operation power circuit
- High sound quality parts of audio DAC, OPAMP and capacitor
- Large-sized insulator for vibration control
- HDCD & Dolby Pro Logic II
* Etc.
- Depth Enhancer
- Monitor Select
- Digital Noise Reduction (Block NR, Mosquito NR, 3D NR)
- 0.6X, 0.7X, 0.8X, 0.9X, 1.1X, 1.2X, 1.3X, 1.4X variable speed playback with sound and subtitle
- subtitle brightness & position control (manual and auto mode.)
Quelques liens:
http://www.avsforum.com/avs-vb/showthread.php?s=a2a3b631e407d72167b778dcd494ae67&postid=4582851#post4582851
(doc) http://www.panasonic.ch/doc/4401_4500/4486/userguide/userguide_3_dvd-s97eg-s_-.pdf
CR et tests :
http://www.avsforum.com/avs-vb/attachment.php?s=&attachmentid=28713
De BA: http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=60
De Chriss: http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=135
D'Alex Foley:
http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=165
http://www.hometheaterhifi.com/cgi-bin/shootout.cgi?function=search&articles=121
De Pas72:
http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=225
Questions et réponses:
Upscaling uniquement sur HDMI ? oui
50 Hz en PAL Progessive Scan ? oui
Lecture DVD+R/RW et DVD-R/RW ? oui
Lecture MP3 sur DVD ? ?
Lecture MPEG4 ? oui
Lecture DiVX ? non
720p (ou 750) et 1080i à 50 Hz ? oui
Dézonable (ou dézoné chez Hifissimo par exemple) ? oui
Sortie Peritel ? semble que oui
Avantages/Problèmes :
Image HDMI (ancien firmware) : plutôt image lisse, pas très contrastée
Image HDMI (firmware 536): d'après des CR, fait jeu égal avec un Denon 2910
Netteté (ancien firmware) : bien en YUV, moins bien en HDMI
Problème de macroblocking: peut être atténué avec les 2 réglages de bruit vidéo
Astuces:
Possibilité d'avoir du 576p sur l'HDMI en désactivant l'HDMI
![:o](https://www.homecinema-fr.com/forum/images/smilies/icon_eek.gif)
Firmwares:
A priori, le dernier en date est le 540, mais il vaut mieux rester en 536 (downgrade impossible)
http://home.comcast.net/~fu_family/Panasonic_DVD-S97_85E536_firmware_update.zip
Sujet HCFR: http://www.homecinema-fr.com/forum/viewtopic.php?t=29768994&postdays=0&postorder=asc&start=150
Ouf, c'est quand même long à faire ! Oublis, remarques, imprécisions, etc.: pas de problème, dites-le moi et je ferai des modifs.
Fred
