en passant par le site maxio xd ce soir que vois-je :
(New for 2006 - Available Soon)
-AX8000
- E.D.I Connector - Support up to 8 x 8 simultaneous channels at 24-bit / 192kHz
- High-end quality 24-bit / 192kHz ADC with 123dB(a) dynamic range
- High-end quality 24-bit / 192kHz ADC with 120dB(a) dynamic range
- 8 balanced analog inputs with XLR connectors (+4dBu)
- 8 balanced analog outputs with XLR connectors (+4dBu)
- ADAT optical I/O with S/MUX support
- Word Clock Input - FS / 256FS with BNC connector
- Supported sample rates: 44.1, 48, 88.2, 96, 176.4 and 192kHz
- 16 x 10-Setp indicator LEDs show precision I/O level for all channels
- Stand alone A/D, D/A converter function
- Compatible with MaXiO series card
DX8000
- 4 x 4 XLR connectors for AES/EBU I/O
- 4 x 4 RCA connectors for S/PDIF Coaxial I/O
- Support Consumer and Professional format
- Word Clock I/O - FS / 256FS with BNC connector
- 16 x 4-Setp indicator LEDs show precision AES/EBU I/O level for all channels
- Stand alone Digital format converter function
- Powered via E.D.I Connector or exclusive DC adapter
LX8000
- 2 balanced analog / Hi-Z selectable inputs with combo-TRS connectors
- 2 MIC-preamps (combo-XLR) with gain controls and peak LEDs
- +48V phantom power support for MIC-preamps
- 2 phono-preamps with RCA connectors
- 6 balanced/unbalanced analog inputs with 1/4" TRS connectors (-10dBv/+4dBu, ADC 114dB)
- 8 balanced/unbalanced analog outputs with 1/4" TRS connectors (-10dBv/+4dBu, DAC 112dB)
- RCA connectors for S/PDIF Coaxial I/O
- Exclusive DC supply powered
