Je vends mon scaler crystalio VPS 2300 HDCP, élu comme un des meilleurs scalers du marché
Couleur : Noir
Cause : besoin de sous car projet immobilier
Tarif : 2000 € +port (50€ par UPS avec assurance) , garantie encore 10 mois; état neuf, carton, etc....
Prix de vente public : 3490 €
Specs :
Crystalio® is a high definition video processor/scaler that is designed to deliver an unprecedented high quality video experience from a video source to video display device.
Combines the state-of-the-art digital video transmission, processing, scaling and format conversion technologies, Crystalio® offers a sophisticated control over every aspect of video processing, so that you can control the performance of the entire video system to a far greater extent.
Crystalio® comprise numbers of groundbreaking features such as:-
SDI, DVI, RGBS, RGsB & Component inputs
DVI, RGBHV and Component outputs
Crystalio® also include cutting edge technologies such as:
User-customizable output resolutions
DCDi™ and TrueLife™ by Faroudja®
Pixel Magic System™ by Pixel Magic Systems Ltd
and more…
A set of tools for the user to configure the video output of Crystalio, ensure that it is mapped in Pixel Perfect mode to your digital display.
DCDi is to eliminate jagged edges normally seen on angled lines in motion video, so that to create smooth and natural looking images. See the difference!
Crystalio comes with 3 SDI (Serial Digital Interface) inputs as standard. This input allows zero picture quality loss when the video is transported from a SDI equipped DVD players or set-top-boxes to the Crystalio. In addition, SDI signals can be transmitted over long distances without loss of quality, allowing increased installation flexibility.
The DVI (Digital Visual Interface) output with the SDI input represents a full digital signal path from the video source to the digital display devices without any signal degradation caused by unnecessary digital-to-analog or analog-to-digital conversions
TrueLife?enhancement uses non-linear algorithms to enhance the small details and colors in images, and improve depth perception by sharpening large edges without introducing visual artifacts or distortion.
The overall result is a richer, more pleasing, high-definition-like picture.
Crystalio supports virtually any video image aspect ratio and display devices aspect ratio including, but not limited to, video images ranging from 4:3, 16:9, 16:9 letter box, to 2.35:1 anamorphic; and display device aspect ratio from 4:3, 16:10, 16:9, to 2.35:1. For example, a 2.35:1 anamorphic DVD video source can be shown on a 2.35:1 projection screen with the top and bottom black bars cropped.
The large zoom function of Crystalio can enlarge the image by up to 10 times the screen height. With an array of Crystalios, a Video Wall of up to 10 screens wide by 10 screens high can be produced!
Pictured is an example of how a 3x3 CrystalWall could be built.
7 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 14 invités
+VENDU+VENDS SCALER CRYSTALIO HDCP 2000€!!!! VN : 3490€
- Fichiers joints
- crystalio1.JPG (75.36 Kio) Vu 1195 fois
- crystalio1.JPG (75.36 Kio) Vu 1194 fois
- BA
- Inscription Forum: 10 Mar 2000 2:00
UP pour la vente d'un excellent scaler !
A ce prix c'est une belle affaire, bonne vente !
Merci et il est comme neuf
- BA
up et pour ceux que cela intéresse je fournis un lecteur SDI Pioneer 737 multizone, noir en très bon état pour 350 euros seulement
De quoi avoir une chaine vidéo extraordinaire
- BA
J'aimerais ajouter un peu de commentaire sur ce scaler.
Sa base est une puce Faroudja FLI2300 qui integre le DCDI, le TrueLife et est capable de gerer de maniere independente une sortie analogique et une sortie numerique. PMS a aussi prevu un outil "pixel perfect" qui permet de creer la resolution parfaite pour le diffuseur.
La machine integre des profils correspondants aux projos les plus courant, DLP, CLD, TT et Dila. Donc il suffit de selectionner son matos dans cette liste, PMS a fait le boulot pour creer la res de sortie parfaite.
Il est possible de l'utiliser de maniere simple, il marche tres bien "out of the box" ou d'optimiser au maximum les reglages. Il est possible de travailler les elements RGB en gain et bias, ce qui permet de calibrer le diffuseur d'image sans toucher au menu usine (genial lorsque celui-ci n'est pas accessible comme sur les plasmas et LCD). Tous les autres parametres peuvent etre customises.
Les mises a jours sont regulaires et ont ajouter de nombreuses fonction inedites comme la taille de la fenetre de detection de cadence pour traitement progressif grande ou petite pour exclure les sous titres qui peuvent induire en erreur la detection. Il est possible de sortir une res dif pour le NTSC et pour le PAL, puis la selection est auto, genial pour les TT !
Il y a plein d'autres fonctions .....
C'est le scaler absolut aussi bien pour les TT que pour toute matrice numerique !
Le mien marchait sur un simple 10HT, le Crystalio lui a donne une nouvelle jeunesse !
On voit les connaisseurs
- BA
salut
il est tjrs à vendre ?
- dark.side
- Inscription Forum: 01 Oct 2003 1:59
7 messages
Retourner vers Plasma, LCD et TV |
