En fin de compte, la puissance n'est pas terrible...car les 5X 130 W sur 4 ohms de la brochure sont même faux...
General Specifications
Power Requirements
Power Output with Rated Power Band
Minimum sine wave continuous average power output per
channel for Zone A, with specified number of channels operating
is:
Rated Power Band (
80Hz to 20,000Hz) into a 4 ohm load
2 x 160 watts
3 x 140 watts
5 x 130 watts
6 x 120 watts
Rated Power Band (80Hz to 20,000Hz) into a 8 ohm load
2 x 100 watts
3 x 95 watts
5 x 85 watts
6 x 80 watts
Rated Power Band (20Hz to 20,000Hz) into a 4 ohm load
2 x 150 watts
6 x 100 watts
Rated Power Band (20Hz to 20,000Hz) into a 8 ohm load
2 x 95 watts
6 x 75 watts
Power Amplifer Specifications
A-Weighted Signal To Noise Ratio
92dB (112dB below rated output)
Intermodulation Distortion
Maximum Intermodulation Distortion if instantaneous
peak output per channel does not exceed
twice the rated output, for any combination of frequencies
from 20Hz to 20,000Hz, with the specified
number of channels operating is:
0.05% for 4 or 8 ohm loads
Input Impedance
20,000 ohms
Wide Band Damping Factor
100 at 4 ohms
200 at 8 ohms
Retour à la case départ...je cherche toujours un MC7205 d'occasion comme prévu...pour mon HK 1.0 en attendant un C45...
A +.
Gérard.
