J'ai vu ca sur AVS:
Lumagen is introducing three new products: Vision DVI ($999), Vision HDP
($1499), and VisionPro HDP ($2299). All have two HD analog and two HD DVI-D inputs. The Vision DVI can transcode, process, and scale HD sources. The Vision HDP and VisionPro HDP can transcode, deinterlace and scale HD up to 1080p output.
Here is a more detailed feature list:
Vision DVI ($999):
- Eight inputs: 2 Composite, 2 SVideo, 2 SD/ED/HD Component, and 2 DVI-D +HDCP
- The Component inputs can also be configured for RGBHV, RGBS, or RGsB
- Option for two SDI inputs ($400)
- Output is DVI-D + HDCP (i.e. digital only) at up to 800p
- Programmable output resolution from 480p to 800p, plus 1080i
- Analog and digital inputs are full-featured (i.e. not just pass-through)
- HD Component inputs are transcoded to RGB
- Component and DVI inputs auto-switch between SD, ED, and HD source
- Two configuration memories per input
- Each input memory has independent parameters for 480i, 480p, 720p, 1080i
- User adjustable image enhancement
- Source aspect ratio selectable as 4:3, letter-box, 16:9 and 1.85
- Adjustable non-linear stretch mode
- 2:2, 3:2, 3:3 pull-down for SD film sources
- HDMI compatible with appropriate adapter cable
- Zoom in any source up to 33% in either 15% or 5% steps
- RS232 control
- NTSC, PAL and SECAM auto-detection
- Programmable output aspect ratio from 1.33 to 2.35
- Optional rack mount ears ($50)
- Studio quality TV decoder with 10-bit A/Ds
- Configuration memories can be used for day/night settings
- All setup parameters are unique for each memory
- Input-cropping, black, contrast, color and hue
- Output resolution and timing are programmable
- Y/C-delay calibration
- Multipoint grayscale calibration
- Gamma calibration
- Genlock
- CUE and ICP filtering (filtrage de chroma, elimnation du chroma bug)
- Programmable input and output color-space (SD, HD)
- DVI input and output dynamic-range can be set to video or full
- Field upgradeable software
- Universal power supply
Vision HDP has all the Vision DVI features plus:
- Output is DVI-I (analog and digital)
- Optional BNC analog output connectors ($100)
- HD deinterlacing at up to 1080p output
- Transcode analog RGB and DVI to analog HD-component
- Output resolution up to 1080p for analog and digital outputs
- Improved video processing quality verses Vision HDP
- 2:2, 3:2, 3:3 pull-down for SD and HD film sources
VisionPro HDP has all the Vision HDP features plus:
- BNC connectors for all analog video in and out provide the ultimate
electrical and mechanical connection.
- Analog output on BNC connectors, plus DVI-D output.
- Ten inputs standard: Two Composite/SVideo (selectable), two
composite/SVideo/SD-Component (selectable), two SD/ED/HD component, two DVI + HDCP, and two SDI
- Professional grade case with machined black-anodized front-panel
- Rack-mount ears standard
- Front panel LCD display
- Front panel controls
- Cables: Two component RCA-to-BNC and two SVideo-to-BNC.
J'ai mis en gras ce qui me semblait particulièrement interessant.
A part le gros modèle qui par sa connectique semble plutot reservé aux pros, le rapport fonctionnalité/prix est hallucinant, recapitule en francais:
Vision DVI 999$:
- entrees 2 composites,2 S, 2 YUV SD/HD (configurable en RGsB,RGBs, RGBHV, 2 DVI/HDCP. Entree SDI en option.
- Sortie DVI HDCP (permet de fonctionner avec les projos ou plasmas qui recalcitrent )
- Peut sortir du 48Hz, 72Hz (NTSC) et 75Hz (PAL) à parti de DVD.
- upconversion jusqu'à 800p (bizarre comme résolution) et 1080i
- Resolutions et fréquences configurables
- Calibration de la courbe de gris et du gamma
- suppression chroma bug
Le modèle au dessus apporte une sortie DVI-I pour ceux qui voudraient du VGA en sortie, du desentrelacement HD, upconversion 1080p.... A 1500$
Bref je ne vois pas ce que l'on peut demander de plus. j'avais tendance à penser qu'avec l'avènement des projos numériques les scalers allaient disparaitre, apparement il n'en n'est rien, le marché n'a jamais été aussi dynamique!!!
12 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 5 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Nouveaux scalers chez Lumagen
- pedro
- Inscription Forum: 08 Déc 1999 2:00
Un ptit up avec un lien vers le site "officiel" :
http://www.lumagen.com/new_products.htm
et un lien vers un pdf anglais avec les prix anglais à la fin (une petite idée du prix en europe ?)
http://www.crtprojectors.co.uk/vision_hdp_spec.pdf
Ce qui est intéressant c'est que le lumagen vision est toujours proposé à 999 $, le même prix que celui du futur DVI. A la sortie des nouveaux, ce prix risque de prendre une claque...
Le problème c'est qu'il n'y a pas de distributeur en France à ma connaissance, et je ne sais pas où il peut être intéressant d'en 'acheter un en europe. Le prix de 1390 € pratiqué par Spatz en allemagne me paraît exagéré quand on voit le prix aux US.
En tous cas, comme dit Pedro, le marché pour ce genre d'appareils n'est pas mort. Il me semble en effet que le vision couplé à un projecteur d'entrée de gamme permettrait de résoudre les problémes liés au scaler interne qui est souvent faiblard sur ce genre d'appareil et de se rapprocher d'appareils bien plus chers. Enfin il faudrait essayer...
- -=Arnaud=-
- Inscription Forum: 09 Déc 2002 11:46
UP !
Savez vous s'il supporte le 1280x720p ? et le 50Hz ? des nouvelles d'un tarif en europe ?
Pascal
Pascal
- FreqResPlot
- Inscription Forum: 20 Déc 2002 15:36
Oui Arnaud un sclaer fait des merveilles sur un "vieux" PJ, pour peu de l'optique et les matrices soient de bonne qualite !
Ce fut une nouvelle naissance pour mon 10HT !
FreqResPlot a écrit:UP !
Pascal
Toutes les résolutions sont ajustables par pixel et les frequences par pas de 0,1hz....
Spatz devrait les distribuer fin mai courant juin....
- pedro
Ah interressant pour les réglages fin !
Je suis en train de me palucher la review sur leur site
Si quelqu'un connais un magasin qui vend ce produit à bon prix aux US (avec livraison aux US aussi) je suis preneur.
Pascal
Pascal
- FreqResPlot
FreqResPlot a écrit:Si quelqu'un connais un magasin qui vend ce produit à bon prix aux US (avec livraison aux US aussi) je suis preneur.
Pascal
Hello
Il est possible d'acheter directement sur le site Lumagen. Pour les commandes hors US, il faut proceder par contact mail.
Kéni
- KeniHamilton
- Inscription Forum: 25 Fév 2003 20:19
Les nouveaux ? j'ai essayé on ne peut passer commande que des anciens modèles (pas DVI)
Je leur ai envoyé un mail mais pas de réponse pour l'instant
Pascal
Pascal
- FreqResPlot
FreqResPlot a écrit: Les nouveaux ? j'ai essayé on ne peut passer commande que des anciens modèles (pas DVI)
Oui en effet, mais pour le moment les produits semblent attendus mais non encore dispo.
FreqResPlot a écrit:Je leur ai envoyé un mail mais pas de réponse pour l'instant
Pascal
Oui, Patrick Harkin met parfois un peu de temps à répondre mais il le fait à chaque fois.
Une adresse US où ils font du Lumagen http://www.800stereo.org/
En Europe, UK voir ici http://www.crtprojectors.co.uk ou encore en Suède ici http://www.brabild.se
Voilà si ça peut t'aider.
Kéni
- KeniHamilton
Merci, je suis allé voir ce sont les anciens modèles. J'ai l'impression qu'ils sont pas encore dispo en version DVI.
Pascal
Pascal
- FreqResPlot
FreqResPlot a écrit:Les nouveaux ? j'ai essayé on ne peut passer commande que des anciens modèles (pas DVI)
Pascal
Fin mai normalement pour les premiers batchs des versions DVI.
- pedro
Bonne nouvelle ca ! Les Lumagen distrib par Spatz ! Merci Pedro
12 messages
Retourner vers Processeurs Vidéo
