nico- a écrit:r2lorme a écrit:non, mais si c'est un pb d'épaisseur, un autre cd doit faire l'affaire, enfin je pense, j'ai jamais essayé...
Ben essaye pis tu nous donneras des nouvelles de ton lecteur au SAV
Les statmats ont aussi une incidence sur l electricité statique.
Je me souviens maintenant que je l'avais déjà fait sur un vieux lecteur cd, il y a une dizaine d'années et je n'avais pas eu de problème avec mon lecteur...
Par contre, ca ne risque pas d'endommager le mécanisme de lecture ce truc?
Voici le texte du constructeur :
STATMAT, developed by QR Design, eliminates static induced signal phase distortion by dispersing the low-voltage hot spots while a CD is being played. It is placed on the CD and works during play-time.
The disc itself does not need to be treated beforehand although, of course, it does need to be clean. STATMAT is made of biaxially-oriented polypropylene film. This type of plastic is more resistant to abrasion and wear than standard, extruded polypropylene. As it is pre-strained, it should not stretch during use. The film is coated on both sides with an aqueous dispersion of polyvinylidene chloride copolymer - which itself has anti-static properties - and specially formulated, conductive inks.
The inks are positioned on the top and bottom of the film in two specific patterns, which are the key to STATMAT's functionality. The two patterns work together to disperse the electrostatic fields across the CD's surface. Low-voltage surges are evened out and hot spots eliminated. As a result, the digital circuitry is able to interpret the binary information more accurately and translate this into a clearer, phase coherent signal. The polypropylene material brings with it an additional benefit: STATMAT weighs a mere 3mg. This means that - unlike some competitive products - its mass will not have any significant effect on the sound. While some damping of the disc inevitably occurs during playback, this is secondary to the conductive processes which are taking place.
In conclusion, by controlling electrostatic fields, STATMAT minimises signal distortion by ensuring phase coherence. This brings with it a host of benefits, just some of which are listed below.
STATMAT benefits:
Cleaner, crisper sound
Greater resolution and separation
Wider, deeper soundstage
Enhanced power and dynamics
Improved sense of timing and rhythm
Clearer intonation and voice inflections
Clearer ambience of recording venue
Simply more natural, more musical
Si quelqu'un l'a déjà essayé...
