http://www.homecinema-fr.com/forum/view ... #168077963
[Edit]
Cambridge sort un nouvel integre de la gamme azur, le 540R
![Image](http://www.cambridgeaudio.com/azurpix/540rpic.jpg)
![Image](http://www.cambridgeaudio.com/azurpix/540rrearpic.jpg)
![Image](http://www.hifissimo.com/images/cambridge540r-inside.jpg)
Power Output:
100 watts rms per channel,
8 Ohms, two channels driven.
80 watts rms per channel 8 Ohms,
aIl 6 channels driven
THD: <0.006% @1kHz
Crosstalk: <-60dB
Frequency response: 20Hz - 20kHz +/- 1dB
Standby power consumption: <2w
Max power consumption: 850w
DAC: CS42518 Multi-DAC
CS493263 DSP
Connections
Audio Inputs: 6 Line Level + Tuner
6.1 Direct Input
Audio Outputs: 6 Amplified Speaker Outputs
6.1 Preamp output
1 Tape record output
Video Inputs: 4 Composite, 3 S-Video,
2 ComponentVideo
Video Ouputs: 1 Composite, 1 S-Video,
1 ComponentVideo
Digital Inputs: 2 Co-Axial, 3 Optical
Digital Outputs: 1 Co-Axial, 1 Optical
Dimensions (mm): 430 x 100x310
Weight: 9.5kg/20.9lbs
voila
a+
