C'est ce que j'ai longtemps cru (et crois encore dans certains cas) mais allez voir ce thread : http://www.avsforum.com/avs-vb/showthre ... did=330006
Et plus particuliérement le post de Kris Deering page 24 :
"I did some further research to narrow the problem down in the FLI2300. I went to the local A/V store that happens to have a Infocus 7200 and 5700. These projectors have full controls for the FLI chip. Using an interlaced player I calibrated the PJs and checked out the scenes on VE and A Bug's Life. I was able to recreate the problem on both projectors!! It is the Noise Reduction circuit turned all the way up. Stacey's Meridian didn't have the issue since they didn't turn on the NR circuit so I checked that first.
This should be nothing more then a register change in the chip and not a big deal at all."
Voilà, la balle est chez Denon... ou ailleur
![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
--Patrice
