En cette fin de semaine, je vous propose un petit test "détente" afin que ceux qui le veulent puissent vérifier leur perception des couleurs
Attention paradoxalement il faut régler le son de votre P.C. à un niveau moyen car certains tests sont accompagnés de commentaires.
J'attends les votre.
c'est ici
12 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 74 invités
Bien comprendre l'Ultra HD, la 4K, et les normes THX, Dolby, DTS, Auro 3D
This page cannot get laid.
The page you are looking for cannot get laid and so it’s currently unavailable. The Web site might be experiencing gonorrhea, genital warts or may need to put on sexy lingerie and adjust its browser settings.
Please try the following:
Ejaculate on the Refresh button, or try again later after this Web site is drunk.
If you typed the page address in the Address bar, make sure that it is spelled correctly and you’re not so damn horny that you left out a letter or two.
To check your connection settings, stroke the Tool menu, and then, with your lips and tongue, suck Internet Options. On the Connections tab, dry hump Settings. The settings should match those of a man that’s old, naked and hairy, just like your local area network (PERV) administrator or Internet Service Provider (ASS).
If your Netwerk Administrator has fellated it, Microsoft Windows can swallow your network whole and automatically spit its settings upon your stomach.
If you would like windows to spit upon your stomach so that you can discover your netwerk connection settings, click Shoot It On My Belly.
Some sites require that 128-bit connection security but not this one. We use The Club. Click the Help menu and then click About Internet Explorer if you have trouble looking at porn.
If you’re trying to buy vibrators, blow-up dollars, hot oils and such, make sure your Security settings can support it. Stroke the Tool menus, and then suck Internet Options. If you’re more advanced, roll your tongue across the Security section and bark like a dog. Yeah, that’s it. You’re turning me on now.
Kiss my Booty to try another link.
Cannot find sex partner or STD test
Internet Exploder
C'est quoi ce délire ?
- ajds
- Inscription Forum: 02 Fév 2000 2:00
ajds a écrit:This page cannot get laid.
Internet Exploder
y'a eu un hic, pourtant je n'ai fait que copier/coller le lien !
J'ai corrigé et vérifié ce coup ci.
- Patrice
- Inscription Forum: 14 Aoû 2000 2:00
Patrice a écrit:y'a eu un hic, pourtant je n'ai fait que copier/coller le lien !
Y a pas de souçis et tu peut aussi laisser le lien d'avant, perso j'étais plié de rire à la lecture du message erreur 404
- ajds
bon sinon j'ai eu tout bon jusqu'a la fin au niveau du test
- ajds
apporter moi une canne blanche
et un chien, j'ai eu tout bon sauf au dernier.... ........................................
- allucinéma
- Pro-Divers
- Inscription Forum: 19 Juin 2002 18:15
ajds a écrit:bon sinon j'ai eu tout bon jusqu'a la fin au niveau du test
moi vers la fin ça m'a un peu surpris, enfin c'est le reflet de mes réponse je présume
- Patrice
Patrice a écrit:moi vers la fin ça m'a un peu surpris, enfin c'est le reflet de mes réponse je présume
J'ai pas été surpris, j'ai rentré la bonne réponse et eu le résultat adéquat
- ajds
Bah on avait les même tests aux 3 jours à l'armée, et j'ai tout bon ! ( ça me rassure, j'suis pas encore trop décrépi ! )
- thestreetfighter
- Inscription Forum: 26 Fév 2002 2:00
thestreetfighter a écrit:Bah on avait les même tests aux 3 jours à l'armée, et j'ai tout bon ! ( ça me rassure, j'suis pas encore trop décrépi ! )
Ne pas réussir ces tests n'a rien à voir avec la décrépitude mais est une question de déficience dans la vision des couleurs.
- thaih
- Inscription Forum: 18 Juil 2002 17:45
thaih a écrit:thestreetfighter a écrit:Bah on avait les même tests aux 3 jours à l'armée, et j'ai tout bon ! ( ça me rassure, j'suis pas encore trop décrépi ! )
Oui et moi c'était pas une constatation scientifique que je faisais, c'était juste une vanne à 2 balles !
- thestreetfighter
Enfoiré! je suis cardiaque! Vous voulez me ramasser à la petite cuillère ou quoi? Faut plus me faire des chose comme ça !
- Puma
- Inscription Forum: 13 Sep 2002 22:32
12 messages
