Hi,
I have to write in english, because it would take too long to translate in french. But I do understand a little french too. .
As I described in the prismasonic thread, I am a member of the german hometheater forum beisammen.de, where some of us (especialy "Theother") developped several anamorphic prisms devices for digital projectors. The prisms work great - we compared them with the ISCO II and the us-Panamorph at our last meeting the 2. beamertreff near Düsseldorf (you can see two self made prisms here ). You can also see pictures and screenshots of my prisms on my homepage (look for the link "Heimkino" and then "selbstgebauter Anamorphot") but the pictures are a bit unsharp because of the camera.
At the moment, we use prisms, that compress the picture vertical. But we also develeppod prisms of horizontal stretch. Theother wrote a small program to calculate the best prisms for each projector but we have standart prisms, which work with simply every projector.
Because of the costs, we use (as the panamorph or the old cinema-panatars) prisms of clearcolor/mirogard glass, which are filled with different fluids. We use water and terpentine or methylnaphtalin, glycerin. The choice of the right fluids is very improtant, because of the dispersion of the colors.
The total costs of the prisms are about Euro 50,- and two days of work.
And they work quite as good as the ISCO II .
The (enormous) thread at beisammen.de is here .
This is a picture of my switchable prisms at the 4:3-through-setting
Au revoir,
Simon, qui aime beaucoup Carcans plage et Maubuisson prés de Bordeaux [/url]
40 messages • Accèder à une page • 1, 2, 3
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 25 invités
Les Téléviseurs CRT, les Rétro-Projecteurs et autres TV
Très intéressant mais le pb c'est que je ne comprends rien à l'allemand ...
Dommage
Dommage
- Asfred
- Inscription Forum: 27 Déc 2000 2:00
Very interesting but hard to understand; a goood self made anamorphism.
Can you made another and sell it for a good price?
- eleve CHAPROT
- Inscription Forum: 12 Oct 2001 2:00
Salut, pour ceux que ne comprenent pas l'allemand (ce qui est mon cas), vous pouvez utiliser le traducteur suivant :
http://trans.voila.fr/ ( Tapez l'url du post à traduire )
Ce n'est pas très bien traduit mais on arrive à comprendre l'essentiel du post.
- laurentp
@Laurent: merci pour le link pour traduire.
Je regrette: non. Il faut que, tu la fais toi même.
Mais c´est facile.
Le petit prisme est rempli avec d´huile essentielle de térébenthine. Son angle fait 24°. Il est tourne par 3,2° dans la direction de la projection/la mur.
Le grand prisme est rempli avec d´eau. L´angle fait 30°, tourné par 31° à la direction de la projection.
Les verres sont antireflets.
Bonne chance et beaucoup de plaisante avec des images anamorphiques
Simon
knightofthecross a écrit:Can you made another and sell it for a good price?
Mais c´est facile.
Simon
- Glamdring
- Inscription Forum: 17 Avr 2002 13:26
Hi Glamdring,
Excellent work !!!
Do you think your panamorph prism is usable or adaptable for a CRT projector (one prism in front of each lens) ? Can you find bigger pieces of glass ? How is the projected picture luminosity affected ?
Thanks to share all your great work with us
Excellent work !!!
- Pascal Francey
- Broker
- Inscription Forum: 18 Juin 2001 2:00
Hi,
oui ce serait possible, mais personne n´essayé les prismes avec un CRT. Tu aurais besoin des prismes énormes . Je ne sait pas, si la dispersion des coleurs sera ok ???.
On peut acheter les verres antireflets (grands ou petits) dans des magasins de cadres
Il n´y a aucun problème avec la luminosité. What is important for the digital projectors is the dispersion of the colors (rouges, vert , bleu), but the standart prism of vertical compress has no problem with that. It also can optimized for each digital projector.
Simon
Simon
- Glamdring
Pascal Francey a écrit:How is the projected picture luminosity affected ?
Regarder un film 1,85:1, on gagne ~30% luminosity.
You will gain about 30% light, watching a 1,85:1 movie.
Simon
- Glamdring
J'ai 4 petites questions :
Quelle distance entre les deux prismes (entre les deux verticales mentionnées sur le dessin) ?
Quelle épaisseur pour le verre ?
Quelle dimension pour les prismes ?
Le système est-il inclinable si on utilise une correction de trapeze ?
- Asfred
J´ai corrigé le dessin parce que l´angle rose n´était pas correcte!!!
1. mettre une feuille de papier comme modelle devant le projecteur -->tu vois la dimension du premier prisme.
2. construire le premier (petit) prisme,
3. mettre le prisme devant le projecteur
4.prendre une feuillle de papier devant le prisme--> tu vois la dimension du deuxiéme prisme.
Mon prisme de térébenthine a les dimension 15 x 15cm et
mon prisme d´eau a les dimension 20 x 20 cm. C´est assez .
Des amis ont des prismes de 10x 10 et 15 x 15 cm. Mais ce serait trop petit pour mon projecteur.
A propos: pour l´utilisation du bas en haut (projecteur sur la table), il faut tourner le dessin.
Simon
Aussi près que possible.Quelle distance entre les deux prismes
Aussi faiblement que possible. 1,2 - 2 mm pour le verre antireflet.Quelle épaisseur pour le verre ?
Ca dépend au projecteur.Quelle dimension pour les prismes ?
Je ne comprends pas le mot "inclinable" (enlever??)? Il n´y a pas de problèmes avec la correction des trapeze. Peux tu récrire ta question?Le système est-il inclinable si on utilise une correction de trapeze ?
Simon
- Glamdring
Tout d'abord merci pour toutes ces précisions Glamdring, ca donne envie d'essayer !
Ce que je voulais dire en fait est que chez moi j'utilise le projo au plafond (renversé) et avec une correction de trapezes (l'axe de projection n'est pas perpendiculaire à l'écran).
est-ce plus clair ?
J'ai une autre intérrogation : à distance de l'objectif doit etre placé le 1er prisme ?
est-ce plus clair ?
- Asfred
Hi,
Trés important : La compensation de pression. Le rayon de lumière chauffe l´huille. Il faut laisser une bulle d'air dedans.
Voilà un trés bien link de "Jochen": Clickez!
A propos: je transmets les salues d´inventeur "Theother/Dieter".
Simon
Ce n´est pas de problème-la même chose ici. The prisms make an OFFSET of some cm, so you will get less trapez.j'utilise le projo au plafond (renversé) et avec une correction de trapezes
Aussi près que possible. Mais ca dépend à la dimension du premier prisme.J'ai une autre intérrogation : à distance de l'objectif doit etre placé le 1er prisme ?
Simon
- Glamdring
Salut Glamdring,
Mais c'est le REVE pour les utilisateurs de tritube ça !!
Est-ce possible avec cette configuration des tubes:
diamètre 16 cm
écartement: 2 cm
Car ton prisme semble bien plus large que l'objectif de ton projecteur.
Qu'en penses-tu ? (2cm d'écartement c'est très peu )
Fred
diamètre 16 cm
écartement: 2 cm
Fred
- MadCat
- Inscription Forum: 05 Jan 2002 2:00
MadCat a écrit:Est-ce possible avec cette configuration des tubes:
diamètre 16 cm
écartement: 2 cm
Sonne bien pour moi. Ca Depend du rayon de lumière de ton projecteur.
Simon
- Glamdring
40 messages
• Page 1 sur 3 • 1, 2, 3
Retourner vers Cathodiques / Autre
