Beta 2 du nouveau firmw 2.1
What’s new:
Network shares (samba/NFS) auto scan and mount
a) Accessible from “Home->Network Shares” menu
b) Later it will be merged with “Medialibrary->NET” menu
c)Network shares searching time will be reduced later
d) Currently don’t supports password protected shares and wireless network, will support soon.
DVD CSS support
User’s font support for subtitle only
a) Font file should be in internal HDD(first partition) or UBS HDD(first partition) in “user_font” folder.
b) Font file name should be “font1.ttf”
c) Before changing font file please stop the playing moving
d) Multiple user’s font will be supported soon, currently supporting only one.
Subtitle on/off option
a) Subtitle can be turn on/off from “Setup->Playback->Subtitle Default”
b) Factory default in “subtitle on”
Subtitle border thickness can be changed
a) During movie playback, press subtitle button from remote control and select thickness
b) Thickness option is next to size option.
DVD AutoRun
a) From “Setup->Playback->DVD AutoRun” on/off option can be selected
Unzip and Archive option from Xtreamer web UI
a) From Xtreamer web UI .zip, .tar, .tar.bz2 type files can be unzipped
b) Just click unzip icon located next to file name, select target dir and press “unzip” button
c) So user can upload more than 10 files at a time as a zip file
d) Select “File Manager->Archive” option and choose folder to make archive(tar)
e) Folder can be downloaded at a time instead of downloading files one by one
Bugs fixed:
Smooth Fast Forward
“503 upload error” during file upload from Xtreamer web UI
File can’t be uploaded to folder containing multibyte character(Korean/Chinese/Japanese) in folder name
FTP file uploaded error “530 server busy”
a) If this symptom found, Restore Default will be needed
Korean missing character in subtitle
Improvements:
“Kerning” (black line between letters) from Arabic subtitle removed.
Audio CD detection.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bab1c, CYRIL 76, flozelarm, FouedyBrown, fredp76, iaido, Jcddu13, jcre17, job_ananda, mafripouille, matt8508, menrad, papounay, Pilou57, polo2121, silvain24, Stade81, thermique85, TopheHC, totof50 et 160 invités
Xtreamer media player & streamer
- GRAPHIC1
- Inscription Forum: 05 Jan 2004 16:05
Reste plus qu'à mettre la main dessus.
- chasechad
- Inscription Forum: 22 Aoû 2009 15:19
Bah j'ai donné le lien de la beta il y a environ 10 jours, en page 168
DAVEYBROTHERS - Membre HCFR
- Inscription Forum: 25 Juin 2008 13:42
Il me semblait pas y avoir toutes ces fonctions dans l'autre beta.
- chasechad
DAVEYBROTHERS a écrit:Bah j'ai donné le lien de la beta il y a environ 10 jours, en page 168
Ceci est la 2.1 beta 2 (le lien était celui de la 2.1 beta 1 )
- GRAPHIC1
GRAPHIC1 a écrit:DAVEYBROTHERS a écrit:Bah j'ai donné le lien de la beta il y a environ 10 jours, en page 168
Mon lien pointe sur le firmware 2.1b2
Sauf que la version dont je parle 2.1 beta 2 date de 3 jours (voir blog du site officiel) et que ton lien lui est du 24 nov Je pense qu'il y avait un mauvais intitulé pour le premier firmw qui était beta1
D'ailleurs les caracteristiques sont differentes
1ere version
New Features:
1.“My Shortcut” in Home menu.
- Add your favorite contents from HDD (Internal/External) to “My Shortcut”
- By pressing “Func” key from Remote Control select “Add to My Shortcut”
- To remove from My Shortcut press “Func” key and select “Delete from My Shortcut” from My Shortcut menu.
- Contents are ordered as per their insert order, not alphabetically.
- Folders and files are displayed from “All” menu only, “Music/Photo/Video” menu only shows respective files not folders
2.eTrayz auto search and mount.
- eTrayz can be auto searched and mounted from media library.
- Only one eTrayz device supported for auto mount now, later all in local network will be supported..
3.Estonian language support.
- Estonian language support for OSD and subtitle.
Improvements:
1.Photo preview UI improved
2.Movie preview UI improved.
3.Improved ODD (audio & data disc) detection.
- DVD CSS will be added by next f/w.
4.Font outline increased 1 pixel more in thickness.
Bug Fix:
1.During movie playback, after pressing “Stop” button it went to “All” menu from “Movie” menu.
2.Playback OGG with CoverArt.
- Sometimes “invalid file” displayed, we will fix next f/w.
- Not display tag info.
To Do:
1.NFS auto search.
2.All NSF and Samba shares will be displayed directly from “Media Library->NET” menu
- Dept will be decreased from Group->PC_name->Share_folder to Share_folder
- Wi-Fi connection improvement
2eme version
What’s new:
1.Network shares (samba/NFS) auto scan and mount
c) Network shares searching time will be reduced later
2.DVD CSS support
3.User’s font support for subtitle only
4.Subtitle on/off option
5.Subtitle border thickness can be changed
6.DVD AutoRun
7.Unzip and Archive option from Xtreamer web UI
Bugs fixed:
1.Smooth Fast Forward
2.“503 upload error” during file upload from Xtreamer web UI
3.File can’t be uploaded to folder containing multibyte character(Korean/Chinese/Japanese) in folder name
4.FTP file uploaded error “530 server busy”
5.Korean missing character in subtitle
Improvements:
1.“Kerning” (black line between letters) from Arabic subtitle removed.
2.Audio CD detection
1ere version
New Features:
Improvements:
Bug Fix:
To Do:
1.NFS auto search.
2eme version
What’s new:
2.DVD CSS support
6.DVD AutoRun
Bugs fixed:
Improvements:
- GRAPHIC1
Ci-après les problèmes que je rencontre pour visionner mes films via le XT. En espérant que quelqu'un puisse me donner une piste pour régler çà.
Lors de la première utilisation du XT via HDMI tous mes MKV ou AVI passent sans problème. Par contre, quand je rallume le XT quelques heures plus tard ou le lendemain et que je lance la lecture d'un film, ce dernier se met à saccader au bout d'1 à 2 minutes, puis forte pixellisation,.... Bref, cela devient illisible ( y compris pour des films qui passaient bien quelques heures avant ). Pour retrouver une lecture correcte, je dois débrancher le câble HDMI, débrancher le câble secteur, rebrancher ce dernier, allumer le XT puis rebrancher le câble HDMI, aller dans le menu et faire un reset des paramètres usines. C'est franchement galère de bidouiller mon installation pendant 10 minutes rien que pour pouvoir utiliser le XT.
Je précise que j'utilise un DD externe ( formaté en NTFS ) relié en USB.
Une idée ?
Merci d'avance.
Une idée ?
Merci d'avance.
- vinvin37
- Inscription Forum: 07 Jan 2007 10:56
Space cette histoire de beta 2 qui n'en est pas une
De toute façon, c'est cette semaine que la release 2.1 sort officiellement
il y a t'il un risque si l'on se sert du boitier avec le ventillo désactivé? je n'utilise pas de dd interne ..
- wool
- Inscription Forum: 13 Oct 2006 21:15
non, comme cela a été dit dans les posts précédents, le ventilateur ne serait utile qu'avec un disque interne
- gromit1
- Inscription Forum: 06 Jan 2007 12:37
gromit1 a écrit:non, comme cela a été dit dans les posts précédents, le ventilateur ne serait utile qu'avec un disque interne
Moi j'ai vraiment des doutes sur ça... perso si je le désactive le XT monte en température très vite et devient vite assez brulant sur le côté gauche quand on le regarde de face. Sans DD interne. Et même sur du format SD ou de la musique...
J'attends toujours le nouveau ventilo de la part de dreamy, mais je préfère garder le bruit de turbine mais que ca refroidisse un peu...
Ciao
Fred
- frederikk
- Inscription Forum: 05 Avr 2001 2:00
excellent merci l'ami je le laisse désactiver alors, ça commencer à me pomper l'air..
- wool
Bon moi toujours pas decider entre le xtreamer et le Western Digital ,je peux savoir pourquoi vous avez preferer le xtreamer?
- cubitusmetz
- Inscription Forum: 07 Sep 2001 2:00
GRAPHIC1 a écrit:(...)
2eme version
What’s new:
2.DVD CSS support
- DVD CSS support, ca veut dire qu'on va pouvoir lire des DVD commerciaux?
- D'ailleurs, parcourant les forums depuis longtemps, j'ai vu que le Xtreamer lit plutôt bien les DVD ISO, avec les menus, etc... ceux qui l'ont confirment?
- Sur le forum Xtreamer, j'ai lu que YAMJ n'était pas fonctionnel sur le Xtreamer, alors qu'il l'est pour les puces Sigma. Cependant, il me semble avoir vu sur ce forum qu'une version de YAMJ avait été adaptée. Qui dit vrai? YAMJ tourne sur le PC ou directement sur le Xtreamer?
- Slee
- Inscription Forum: 14 Sep 2007 23:40
