Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Hubu, Paranoiak, polo2121 et 84 invités
Dune HDCenter/Dune BDPrime, BD, MKV, ISO BD- part2
Message » 09 Mar 2010 16:02
Ah c'est bon j'ai trouvé, la Dune le prends pas en compte le nom suivant: dune_firmware_hdcenter_sony_100307_2100_beta.txt mais si je le renomme en dune_firmware_hdcenter_sony_091229_1411_beta.txt ça passe...
Par contre y'a énormément de texte à traduire et à l'aveuglette c'est pas facile, y'a ça à traduire:
Code: Tout sélectionner
WARNING: Unknown key found: "upgrade_attention".
WARNING: Unknown key found: "upgrade_dark_screen_warning_string1".
WARNING: Unknown key found: "upgrade_dark_screen_warning_string2".
upgrade_confirm_warning_text_2 =
upgrade_confirm_warning_text_3 =
upgrade_confirm_warning_text_1 =
upgrade_confirm_warning_text_4 =
upgrade_confirm_warning_text_5 =
dialog_utils_url__1 =
fw_online_upgrade_non_stable_non_current_version_caption__1 =
fw_upgrade_setup_hr_settings =
video_setup_hdmi_color_depth_8_bit =
fw_online_upgrade_dialog_title =
smb_mount_in_use_description3 =
navigator_item_info_label_workgroup =
video_advanced_settings_dialog_title =
fw_online_upgrade_no_suitable_storage_text_1__1 =
fw_online_upgrade_stable_non_current_version_caption__1 =
hdmi_color_depth_confirm_text2 =
video_setup_hdmi_color_depth =
hdmi_color_depth_confirm_text3 =
fw_online_upgrade_confirm_non_stable_version_text_4 =
hdmi_color_depth_confirm_text4 =
network_browser_default_smb_network_folder_name__2 =
hdmi_color_depth_confirm_text__1 =
fw_online_upgrade_confirm_non_stable_version_text_1 =
fw_online_upgrade_confirm_non_stable_version_text_2 =
fw_upgrade_setup_label_warn_about_autocheck_failures =
fw_online_upgrade_confirm_non_stable_version_text_3 =
color_depth__1 =
fw_online_upgrade_autocheck_failed_message_text_2 =
video_setup_hdmi_cec_disabled =
fw_online_upgrade_autocheck_failed_message_text_1 =
upgrade_attention_text_1 =
upgrade_attention_text_2 =
fw_upgrade_setup_label_ignore_non_stable_versions =
fw_online_upgrade_confirm_disable_autocheck_text_1 =
fw_online_upgrade_confirm_disable_autocheck_text_3 =
fw_online_upgrade_confirm_download_system_storage_text =
fw_online_upgrade_confirm_disable_autocheck_text_2 =
fw_upgrade_setup_check_failed_message_line_2 =
network_browser_disconnect_failed =
fw_online_upgrade_downloading =
photo_viewer_info_format_aai =
navigator_item_info_disconnecting =
fw_online_upgrade_install_button =
download_file_dialog_error__1 =
fw_upgrade_setup_check_failed_message_line_1 =
download_file_dialog_avg_speed =
fw_online_upgrade_remind_later_button =
download_file_dialog_error_closing_output_file =
download_file_dialog_error_writing_output_file =
fw_online_upgrade_no_new_version_message =
fw_online_upgrade_show_all_versions_button =
download_file_dialog_error_opening_output_file =
network_browser_popup_disconnect =
download_file_dialog_error_opening_input_stream =
video_setup_hdmi_cec_enabled =
fw_online_upgrade_autocheck_failed_ignore_button =
download_file_dialog_error_reading_input_stream =
hdmi_color_depth_confirm_title =
download_file_dialog_read_value__2 =
fw_online_upgrade_new_version_message =
fw_upgrade_setup_checking =
fw_online_upgrade_autocheck_failed_do_not_warn_button =
setup_fw_upgrade_settings =
video_setup_hdmi_cec =
fw_upgrade_setup_label_autocheck_updates =
network_browser_popup_add_to_main_screen =
fw_online_upgrade_skip_this_version_button =
video_setup_advanced_settings_edit =
download_file_dialog_avg_speed_value__1 =
fw_online_upgrade_stable_current_version_caption__1 =
fw_online_upgrade_non_stable_current_version_caption__1 =
download_file_dialog_remaining =
download_file_dialog_error_getting_file_size =
download_file_dialog_confirm_cancel_title =
video_setup_hdmi_color_depth_10_bit =
video_setup_hdmi_color_depth_12_bit =
video_setup_hdmi_color_depth_auto =
fw_upgrade_setup_label_current_version =
navigator_error_failed_to_open_url =
fw_online_upgrade_confirm_download_text =
fw_online_upgrade_confirm_disable_warn_about_autocheck_failures_text_2 =
fw_online_upgrade_unpacking_error_text =
fw_online_upgrade_confirm_disable_warn_about_autocheck_failures_text_3 =
download_file_dialog_button_cancel =
fw_upgrade_setup_button_check =
download_file_dialog_opening_url =
fw_online_upgrade_confirm_skip_version_text_1 =
fw_online_upgrade_no_suitable_storage_text_2 =
fw_online_upgrade_confirm_disable_warn_about_autocheck_failures_text_1 =
network_browser_popup_disconnecting =
fw_online_upgrade_show_all_version_dialog_title =
fw_online_upgrade_confirm_skip_version_text_2 =
video_setup_advanced_settings =
fw_online_upgrade_unpacking =
fw_upgrade_setup_hr_status =
fw_online_upgrade_searching_suitable_storage =
navigator_item_info_button_disconnect =
navigator_item_info_title_smb_share =
navigator_item_info_disconnect_failed =
fw_upgrade_setup_title =
Pour les 3 premières lignes je sais pas trop ça dit que ça n'a pas été trouvé, par contre pour les autre ça dit juste que c'est manquant...
Donc si y'a des personnes qui savent à quoi correspondent chaque balise, donnez moi les infos ;)
Guilouz
Inscription Forum: 12 Juin 2009 14:49
Message » 09 Mar 2010 19:44
Pour ce qui est des indications de HDi, il est clairement indiqué pour chaque machine les fonctionnalités précises des firmware. Sur la description du nouveau firmware pour les Dune 1.0, il n'y a nullement indiqué Deep Color :
http://dune-hd.com/firmware/bdprime/
Ce sera de plus en plus le cas. En effet, si au départ, les machines étaient quasiment identiques au niveau firmware, de plus en plus de fonctions ne seront pas disponibles sur les anciennes Dune.
Christophe CHEREL
Pro-Fabricant
Pro-Fabricant
Inscription Forum: 06 Juil 2001 2:00
Message » 09 Mar 2010 19:46
A propos du Deep Color qui semble faire débat ici...
La puce Sigma Designs SMP8642 est capable de gérer le 10 et 12-Bit par couleur (30 et 36-Bit). En Blu-ray, l'image est encodée en 8-Bit par couleur 4:2:2 (soit 256 niveaux). Il n'existe pour le moment pas de source vidéo grand public 10 et 12-Bit à part les films provenant de caméscopes HD. Pour ce qui est de l'upsampling couleur des Blu-ray, bien que certaines personnes sur les forums parlent d'un traitement matériel temps réel, je suis pour ma part très dubitatif sur le sujet car tous les tests et mesures que j'ai pu réaliser jusqu'à présent ne montraient aucune amélioration visible (testé sur vidéoprojecteur Samsung SP-A900B capable d'accepter en entrée du 10-Bit et de l'afficher réellement du 10-Bit). Un de mes confrère disposant d'un vidéoprojecteur professionnel à 60 K€ n'a lui aussi pas vu de différence. D'autre part, dans le manuel de l'OPPO (qui est compatible Deep Color), il est bien précisé qu'aucun upsampling 10-Bit n'est réalisé par la machine.
A noter également que si beaucoup de téléviseurs actuels acceptent le Deep Color jusqu'à 12-Bit par couleur, très peu sont capables d'afficher du 10-Bit réel et encore moins du 12-Bit. D'ailleurs, même au cinéma numérique, la plupart des fichiers ne sont qu'en 10-Bit 4:4:4 et rares sont ceux encodés en 12-Bit 4:4:4.
Pour ce qui est du 4:4:4, ce n'est pas du tout obsolète mais simplement utilisé quasi-exclusivement dans le monde pro (les masters de nos Blu-ray sont en 4:4:4).
Je précise aussi que la vraie nomenclature est "10-Bit" (sans "s") et non "10 bits".
Enfin, les photos sont généralement encodées en 8-Bit mais certains conteneur permettent d'enregistrer en 10-Bit ou plus comme le format RAW.
Pour conclure, il y aura certainement des Blu-ray 4:4:4 10-Bit, mais cela a finalement peu d'intérêt pour le grand public sur qui la 3D ou le 4K auront beaucoup plus d'impact. Avant de parler de 10-Bit ou 12-Bit, les utilisateurs devraient déjà faire calibrer leur téléviseur ou vidéoprojecteur. Il y a de mon point de vue un apport bien plus grand dans le calibrage vidéo en 8-Bit que dans du Deep Color sur un écran non calibré. :roll:
En espérant que cela pourra vous apporter quelques réponses...
Christophe.
Christophe CHEREL
Pro-Fabricant
Pro-Fabricant
Message » 09 Mar 2010 19:55
Christophe CHEREL a écrit:Pour ce qui est des indications de HDi, il est clairement indiqué pour chaque machine les fonctionnalités précises des firmware. Sur la description du nouveau firmware pour les Dune 1.0, il n'y a nullement indiqué Deep Color :
Merci pour l'explication ;mais l'erreur viens de eux car a l'origine il était marqué sur le changelog de la prime 1.0 ,vue que j'avais récupérer les info dessus
calimero 28
Inscription Forum: 31 Juil 2006 18:32
Message » 09 Mar 2010 19:57
tout à fait christophe :wink:
costaud
Contributeur HCFR 2019
Inscription Forum: 05 Oct 2004 20:51
Message » 09 Mar 2010 20:12
parfait Christophe sur ton explication..
étant données que nos média sont encodées en 8-Bit, cela ne change en rien de pouvoir afficher du 12-Bit ou du 16-Bit..
en ce qui concerne le calibrage, je suis entièrement d'accord avec toi
et j'y avais pensé dès le départ avant de faire mon achat ( LE 46F86BDX ).. et ne voulant pas trop me prendre la tête à acheter une sonde, j'ai plutôt préférer de prendre un écran calibré d'usine.. peut être pas aussi parfait que tu peux le faire.. mais on s'en rapproche je pense..
mesure effectué par lesnumeriques.com sur le LE40F86BDX
réglages par défaut en mode ''Cinema''
que penses-tu de cette mesure?
wool
Inscription Forum: 13 Oct 2006 21:15
Message » 09 Mar 2010 20:15
ben vue que ça depend de la chaine video complète , je suis pas sur que tu ais réellement ça chez toi :wink:
Mais la base est pas mal effectivement .
costaud
Message » 09 Mar 2010 20:16
d'usine c'est vraiment beau comme calibration ;) 8)
Après faut voir dans le temps car on dis toujours qu'il faut laisser travailler l'écran avant de faire un calibrage idem pour les projo et qu'il faut le refaire toutes les 2000 h ou toutes les 5000 heures je sait plus très bien :(
Et bien sur faut voir avec qu'elle sources il on fait ça ;)
Gandalflux
Inscription Forum: 07 Avr 2008 23:03
Message » 09 Mar 2010 20:18
Point besoin d'une sonde pour déjà obtenir un rendu bien supérieur au réglage d'usine.
Ce dont tu as besoin ----> le BluRay DVE Essentials
djoole
Inscription Forum: 25 Avr 2007 0:43
Message » 09 Mar 2010 20:35
ok je vais essayer le bluray DVE Essentials..
ensuite perso je trouve le mode Cinema de mon écran très bien calibré.. l'image est parfaite à mon gout ..
pour preuve j'ai fait prendre à mon frère le Viera TX-P50V10 avec une Dune et en mode THX ce n'est pas mieux que sur mon écran.. ensuite c'est peut être une affaire de gout, mais je reste sur mon avis ..
wool
Message » 09 Mar 2010 20:36
djoole a écrit:Point besoin d'une sonde pour déjà obtenir un rendu bien supérieur au réglage d'usine.
LOL Et tu fait ton réglage a l'œil ??? :mdr:
Non sans rire c'est pas de la calibration ça c'est du bidouillage :mdr: :mdr:
wool a écrit:ok je vais essayer le bluray DVE Essentials..
Ca peut tout a fait être a ton gout et ne pas du tout être calibrer ;)
MA chaine avant calibration je la trouvais bien certe les vert étais un peut trop pousser mais ca allais.
Lorsque l'on a mis la sonde j'ai fait Arffff ha ouais je suis grave a coter de la plaque.
Apres on la régler comme il faut et je trouvais l'image un poils fadasse maintenant elle me convient très bien et lorsque je vais chez quelqu'un qui a une image non calibre je le voie tous de suite.
Premier mots ha ouais ça pète ton image le mec sourire et remercie et ensuite je rajoute tes carrément a l'ouest niveau colorimétrie, la ça calme et je suis toujours dans le vrais.
Réponse : Ouais j'ai fait a l'œil comment tu voie que ça vas pas ...... ;) un coup de sonde HCFR juste pour voir le diagramme et Hop ça loupe pas c'est a l'ouest ;)
j'ai toujours ma petite sonde HCFR juste pour vérifier et pour étayer mes dire, mon installe a toujours été calibrer par des personnes fort compétente avec du gros matos je ne mis connais pas assez pour calibrer moi même mon installe :-? :oops: si je devais le faire je mettrais 1 semaines et les pro en 1h c'est fait chacun sont métier ;)
Gandalflux
Message » 09 Mar 2010 20:38
oui tu vas régler la luminosité , le contraste , et pour le reste , sans sonde , nada !! :mdr:
costaud
Message » 09 Mar 2010 20:42
ET encore luminosité et contraste moi je dis et encore .... à peu prés ;)
Gandalflux
Message » 09 Mar 2010 20:53
âme charitable pour calibrages de mon LCD.. j'ai déjà vu ça à quelque part.. :mdr:
non sérieusement moi ça me va comme ça .. pour mon VP je le prendrais calibré d'usine ou bien.. s'il faut je prendrais une sonde ou bien je le ferais calibré..
et puis la courbe n'est pas si mal que ça pour mon lcd..
les mesures ont été réalisé en mode cinéma dans lequel je l'utilise, alors pourquoi voulez-vous que ça change..
wool
Message » 09 Mar 2010 21:00
wool a écrit:âme charitable pour calibrages de mon LCD.. j'ai déjà vu ça à quelque part.. :mdr:
C'est bien là l'essentiel, que l'image te donne entière satisfaction, le reste :roll:
Pourquoi ça changerait ? et bien comment crois tu qu'ils ont fait les mesures, avec un lecteur source , or si ton lecteur est complètement à l'ouest, et bien tu n'auras pas du tout ces courbes :wink:
costaud
