![Image](https://www.dune-hd.com/cdn/shop/products/Premier_4K_pro_3_900x.png?v=1681649543)
![Image](https://www.dune-hd.com/cdn/shop/products/Premier_4K_pro_5_900x.png?v=1681649543)
![Image](https://www.dune-hd.com/cdn/shop/products/Premier_4K_pro_2_800x.png?v=1681649543)
![Image](https://www.dune-hd.com/cdn/shop/products/Premier_4K_pro_1_800x.png?v=1681649528)
2-in-1 Premium Netflix-certified Streaming Media Player + Dune HD Media Center.
Netflix in 4K Dolby Vision & Atmos, AV1, 4GB, Wi-Fi 6, 1Gbit, ISO 4K DV P7 FEL.
2.5" HDD rack. Extremely Feature-Rich Android TV Box.
Hardware and Technologies
S905X4-K media processor (special version with all licenses)
S905X4-K media processor is the most advanced version of the latest media processor from Amlogic which includes all possible technologies and licenses: Dolby Vision, Dolby Atmos, DTS.
4 GB operating memory
Ensures excellent performance and support for the most heavy Android apps.
32 GB flash memory
Provides a lot of space for Android apps and other needs.
1 Gbit Ethernet
Ensures fast data transfer and smooth playback of high bitrate video when using a wired connection to the home network.
Wi-Fi 6
This newest Wi-Fi standard provides a better wireless performance and a better wireless range, when using a wireless connection to the home network.
2.5" HDD rack
You can easily install a 2.5" SATA HDD or SSD into the media player and store up to 5 TB and more media content directly in the media player. HDD hot swap is supported. No tools are needed for HDD installation. Installed HDD can also be accessed from local network via SMB file server function built-in into Dune HD Media Center.
USB 3.0 slave HDD port
You can easily connect the media player by USB cable to a PC for fast and convenient direct file transfer between the PC and the HDD in the media player. No additional power is required, so you can also use the media player as a portable USB HDD.
Front panel display
Gives you even more experience of a classical Dune HD media center. When playing content via Dune HD media center app, shows the current playback position. Also can show the current time.
Dolby Vision and HDR10+
The media player supports not only HDR technology (supported by the previous generation of media players), but also the most latest and advanced Dolby Vision and HDR10+ technologies. In conventional HDR technology, the brightness range is set at the beginning of the film and does not change during the film, so completely dark and completely bright scenes may have insufficient detail. In the latest Dolby Vision and HDR10+ technologies, the brightness range can vary from frame to frame, so the maximum picture detail is provided even in scenes that contain only dark or only light elements.
Dolby Atmos
Dolby Atmos is the most widely used advanced technology for surround sound. Dolby Atmos draws you in deeper, so you hear more and feel more, for a more realistic and immersive audio experience. This media player supports Dolby Atmos sound both when watching streaming services such as Netlix and when playing files from your local library (in formats such as ISO, BDMV, MKV, and so on).
Newest Dolby MAT technology
This media player includes the newest Dolby technology for multichannel surround sound - Dolby MAT. Using Dolby MAT technology, the media player does not just output the fantastic Dolby Atmos audio to your TV or A/V receiver, but also performs partial decoding of the audio directly on the media player. This improves A/V synchronisation, reduces latency, and improves compatibility. Nowadays this approach for audio output is recommended by industry leaders such as Netflix and Google.
AV1 video codec
The media player supports the very newest AV1 video codec, which helps to get up to 50% video quality improvement without increasing video bitrate (or requires up to 50% lesser bitrate for the same video quality). This new video codec is already used by YouTube and will be increasingly important for various services.
YouTube 4K HDR and VP9 profile 2
The media player supports the modern "VP9 profile 2" video codec, which is used by YouTube for HDR content. This makes it possible to watch YouTube videos in maximum 4K HDR quality.
Two USB 3.0 host ports
Allows you to connect USB storage devices (such as flash drive, HDD or SSD) and ensures fast data transfer and smooth playback of high bitrate video. Connected USB storage devices can also be accessed from local network via SMB file server function built-in into Dune HD Media Center.
Dispo pour 199€
