Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 56 invités
Tout ce qui ne rentrait pas dans les catégories ci dessus lors de la réorganisation
Par ailleurs, il n'est pas possible de créer un nouveau sujet : merci de le faire dans un autre forum.
Les softwares indispensable du PCHC - PCHIFI - PCPREAMP
Et ZP qui passe à la version 4beta
- DTSman
- Contributeur HCFR 2022
bravo pour ce boulot
- xavkan
- Inscription Forum: 30 Déc 2002 22:04
DTSman a écrit:Et ZP qui passe à la version 4beta
je v resté sur des version Finale ou approuvé pour le tableau
- G0G0
- Inscription Forum: 27 Déc 2002 3:00
DScaler est en version 4.1.8.
Laurent
Laurent
- LaurentG
- Inscription Forum: 31 Aoû 1999 2:00
MAJ MPC 6.4.7.9
Le changelog détaillé :
- New internal mpeg splitter: It can read program/transport/elementary streams, demuxes mpeg1/mpeg2 video, ac3/dts/mpeg/lpcm audio, cvd/scvd/dvd subtitles. You can switch streams through the filter menu (play/filters/...) similar to the original ogm splitter. The subtitle stream is set to a default dummy entry (to prevent emails asking how to turn it off , so it has to be changed to a real stream before you will see anything. Possible problems/bugs/annoyancies: seeking doesn't work very well with small files, and it may not be that resistant to stream errors always (time will tell I guess
- The mpeg2 decoder was updated to accept and display cvd/svcd subtitles of course. Before you ask, there is no other known decoder for dshow doing this. None of the effects of svcd subs are supported at the moment, I don't have the specs on them and have no test files either.
- Updated libdts to 0.0.2 (decodes high frequency extensions)
- More mime types recognized and follows http redirections.
- The .ra file extension (usually used by the audio-only format and what the rm splitter still cannot handle) is now a directshow type, however mpc will switch to realmedia mode when it detects it to be the audio-only format. The same fallback is done when detecting quicktime or shockwavefile header opened over http.
- Improved buffering in all internal splitters. The lower limit is 100 samples or 100k per stream, the upper limit is 10000/1MB for all streams together, but when the lower limit is not met for one stream the others are allowed to read more than the upper limit to unblock. You can check the actual status in mpc's status window, it's going to be in the last row, and the number between [..] will mean the pin number.
- Added the jpeg output format for "Save image...". Also, removed the shell call preventing mpc to start up on win9x without IE4 (but it will still check the registry for this folder )
- G0G0
Thread mis en post-it
- Emmanuel Piat
- Contributeur HCFR 2016
- Inscription Forum: 10 Oct 2000 2:00
Merci kel honneur
et je remercie tous ceux ki m'aide a le completé
ainsi ke tous ceux ki font c programme fabuleux
Ainsi ke ce forum ki ma tous appris (enfin preske )
- G0G0
Il y a pour calibrer la vidéos des soft genre colorfacts avec une partie gratuite pour un calibrage visuel.
http://www.milori.com/products/testpatterns/default.asp
Et un truc dont j'ai oublié le nom exact genre NOKIA quelquechose !
- artefact
- Inscription Forum: 18 Mai 2003 10:24
artefact a écrit:Salut,
en effet ceci est interesant mais je me demande si il sont veritablement indispensable
Un DVD de calibrage n'aurait t'il pas le meme effet ?
Ce que je ne veut pas c surchargé les PC de programme dont on ne ce sert qu'une fois
- G0G0
maintenant kil est en post it j aurais pensée avoir un peu aide pour bien finir de remplir ce tableau
- G0G0
Je pense qu'il serait bien de distinguer MyHTPC de MyHTPC-Fr.
- DTSman
z'avez oublié xmms pour linux dans la section audio...
a++
Richard
a++
Richard
- Riri-DLP
- Inscription Forum: 02 Jan 2002 2:00
Riri-DLP a écrit:z'avez oublié xmms pour linux dans la section audio...
a++
Richard
Ce n'est pas un oublie mais mon manque de connaissance dans cette OS
Si tu en a d'autre n'hesite pas a me les communiqué afin ke je les rajoute.
- G0G0
MAJ MPC 6.4.8.0
- Mpeg video decoder: implemented frame-dropping (b-frames only) when running late and added a new sse2 idct (intel's code, AP-945), now high-definition clips should keep the sync at least
- Mpeg splitter: plays discontinuous/joint files to the end but seeking still broken with those, also recognizes aac streams and misdetects others as lpcm less frequently
- New aac decoder based on libfaad, coreaac didn't handle mpeg's aac very well for some reason (he-aac, stereo downmixing supported)
- Volume normalizer can be "boosted" a bit in case you find the level still low, look for the slider next to the normalize checkbox
- Added a /nofocus command line switch
More fine tuning of the internal splitters' packet buffering
- Fixed the "higher than normal" priority option, it was not applied after reopening the player
- New option to launch files in fullscreen (checkbox at options/player)
- 7th internal logo by Steve Smith (looks very nice), if you made any in the past contact me again and I'll add your name to the logo chooser page, next to your logo
- Fixed the file browser not displaying anything on cd drives under xp, when the recording feature of the operating system is enabled
- G0G0
