LaurentHU2 a écrit:Je reste sur ma config, qui me procure une fluidité parfaite!
![:mdr:](https://www.homecinema-fr.com/forum/images/smilies/icon_mrgreen.gif)
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 31 invités
13/02/2007
* New Features:
o Added color planes shifting code (useful for correcting projector errors).
o Added support for DTS in bluray m2ts.
o Added support for WMA Pro to the muxer.
o Aspect ratio and frame rate is now extracted from MPEG2 in TS.
o Added a graphical DS Mux application.
* Fixed items:
o mkv2vfr now writes correct files bigger than 2GB.
o Fixed a bug in stream switching.
o A more detailed message is displayed when a codec is missing during a stream switch.
o Fixed incorrect behaviour during file open when the file is in the process of being written.
o Fixed image distortions when using bicubic enlarging.
o Fixed detection of some DTS streams in TS.
o Fixed a crash in the simple media splitter when file open fails.
o Fixed a number of threading issues in the renderer that happened during DVD playback.
corto a écrit:J'utilise le resize de FFDShow pour monter en 720x720 et le resize de la carte (render) pour faire passer 720x720 en 1280x720.
Haali Media Splitter
Changes27/02/2007
New Features:
Added MPEG PS support (incomplete).
Added VC-1 in TS/PS support.
Added more items to the renderer OSD.
Renderer OSD can now be activated with right-Alt+O.
Added LPCM in TS support (incomplete).
Improved GDSMux utility.
Improved seeking in TS files.
Fixed items:
Fixed display when the window is partially outside the screen.
Allow playback when TS file duration can't be detected, seeking is not possible in this case.
H.264 with short startcodes in TS is now properly handled.
Muxer bugfixes.
corto a écrit:Le render fait le bon resize en fonction d ela taille de la fenetre, d'accord, mais quand je suis en plein écran, il ne devrait pas reduire la taille de la video ...
07/03/2007
New Features:
Improved gdsmux.
Added support for S_TEXT/ASCII subtitles to the DS muxer filter.
Added support for H.264 in MPEG-PS.
Improved support for DD+ in MPEG-PS.
Added a bitrate graph to the renderer OSD (only active when the splitter is used as source).
Added some support for PCM an ulaw audio in qt files.
Added automatic linking of VOB files.
Fixed items:
Renderer: eliminated an incompatibility with geforce 5 hardware.
Renderer: fixed a distroted picture with some VfW codecs.
Fixed a problem with seeking in MPEG-PS/TS.
