Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 10 invités
Conseils, Guides et Tutos pour le stockage et réseau
[Synthese] NAS: Choix, Configuration, exploitation, support.
Message » 01 Juin 2012 7:24
L'un des disques ne veut pas rentrer dans la grappe. 4 mauvais secteurs a priori:
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363580] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363589] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363597] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363622] end_request: I/O error, dev sdc, sector 0
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.364983] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.364991] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.364999] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 28 00 00 08 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.365017] end_request: I/O error, dev sdc, sector 40
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366139] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366145] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366153] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 0f 33 00 00 00 08 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366172] end_request: I/O error, dev sdc, sector 996096
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367547] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367555] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367563] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 a4 3d 98 00 00 04 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367582] end_request: I/O error, dev sdc, sector 10763672
Je croyais qu'on pouvait masquer des mauvais secteurs. Je sens que ça va se terminer en SAV avec un RAID5 transformé en RAID0.
Bobor
Inscription Forum: 01 Avr 2002 2:00
Message » 01 Juin 2012 7:40
Je viens de regarder la valeur LCC pour chacun de mes 10 disques WD Green 3T...
Les 5 plus anciens sont à tous à 35 000 et des brouettes, pour 7500 heures d'utilisation, alors que les 5 derniers sont tous à 50 000 / 60 000...
Et j'en ai même un à 151 000 pour 5700 heures de fonctionnement... :o
Le firmware des disques récents provoquerait-t-il un parckage plus fréquent que sur les anciens disques ?
En RAID ils sont tous sensés êtres actifs au même moment non ? Comment expliquer cette différence de LCC ?
Je suis donc partant pour la manip... Mais si je flashe un premier disque et que je rallume le NAS, est-ce qu'un fsck suffira pour détecter un problème d'intégrité avant de passer aux autres ?
Par contre ça ne donne pas envie : http://lime-technology.com/forum/index. ... ic=15554.0
J'ai des EZRX aussi... :o
Conseil du gars : "Run it with /S300 and not /D !"
basthi
basthi
Inscription Forum: 15 Mai 2006 23:12
Message » 02 Juin 2012 22:34
Depuis la mise à jour du DSM 3 au 4, j'ai toujours le même problème: quand le système est arrêté (vacances, déménagement, ou pire, coupure de jus... note à moi même: acheter un onduleur), c'est la galère pour le remettre en route, ça prend 24h pour que je parvienne à y accéder de façon normale:
au démarrage, séquence normale, puis diode LAN qui clignote vert un dizaine de secondes, s'arrête 1 seconde pendant que les diodes HD clignotent un coup, puis rebelote, LAN, HD, LAN, HD pendant un temps assez long.
pendant ce temps, le Syno est visible de façon aléatoire depuis le finder de mon Mac, y accéder depuis l'interface web est une gageure, et quand j'y parviens, c'est très long, lent...
Je pense retourner au DSM 3.2 sous lequel tout tournait à la perfection... Comment faire sans perdre mes données?
Vermel
Inscription Forum: 05 Déc 2005 15:27
Message » 09 Juin 2012 20:13
Bobor a écrit:Comme nombre d'entre vous ont des WD 3To Green dans leurs NAS, j'aimerais savoir quelle valeur de LCC (load cycle count) vous avez sur ces disques. Les miens sont 120000. Je crois que c'est lié au parcage de têtes qu'on peut désactiver via un programme mais la manipulation est assez pénible (boot sous DOS).
si cela peut donner des indications
voila ce que j'ai sur le disque le plus ancien (sept 2011)
Kervinou
Inscription Forum: 12 Oct 2009 10:32
Message » 09 Juin 2012 20:14
Bon j'ai reçu en retour de RMA les deux HDD WD.
Je suis en train de le tester + passage de Discwipe.
J'ai aussi reçu le NAS, un DS212.
Il faut que je fasse les premiers pas avec et décide du système que je vais utiliser pour les HDDs ;)
The Dji
Inscription Forum: 25 Jan 2010 12:14
Message » 10 Juin 2012 13:09
Bon en fait problème, on ne peut pas passer des HDD de 3To sous DiscWipe :/
Comment faire pour ceux qui l'ont déjà fait ?
The Dji
Message » 10 Juin 2012 13:37
As tu essayé en les mettant ne interne dans le PC sur un port SATA 3 ? ;)
Gandalflux
Inscription Forum: 07 Avr 2008 23:03
Message » 10 Juin 2012 15:35
Ils sont en interne ;)
The Dji
Message » 10 Juin 2012 20:15
The Dji a écrit:Bon en fait problème, on ne peut pas passer des HDD de 3To sous DiscWipe :/
tu les laisses dans le nas, et tu utilises la méthode du "dd"
http://fredo.servehttp.com/html/Astu-19 ... reparation
Kervinou
Message » 10 Juin 2012 20:19
+1
Gandalflux
Message » 10 Juin 2012 20:30
D'accord, donc je fais ça dès l'allumage du NAS et avant d'y avoir mis des données ??
The Dji
Message » 10 Juin 2012 20:49
Tu suit le Tuto !! :grr: :grr:
:ane:
:friend:
Gandalflux
Message » 10 Juin 2012 20:57
Ok Ok :D
EDIT : Il faut que je suive celui-ci : "Sous Telnet. SYNO neuf et 2 disques minimum."
Bien compliqué en tout cas :/
Il n'y a vraiment pas plus simple ?
The Dji
Message » 11 Juin 2012 10:37
Bon j'en ai marre des prix des disques durs... ça baisse trop lentement.
J'ai envie/besoin de disques pour mon DX510... et je refuse de mettre 100€ dans des 2To ou 150€ dans des 3To :x
ZeTom
Inscription Forum: 04 Sep 2007 9:52
Message » 11 Juin 2012 10:41
ZeTom a écrit: (...) J'ai envie/besoin de disques pour mon DX510 (...)
Comme tu es loin d'être le seul, les prix ne baisseront pas de sitôt :(
Adhérez à l'association pour que le site progresse : http://www.homecinema-fr.com/asso.php/
frahlt
Membre d'Honneur
Membre d'Honneur
Inscription Forum: 05 Mai 2006 4:29
Retourner vers Stockage et Réseau
