Gort'h a écrit:Sur la partie medium aigu on est sur les mêmes HP entre la 1.5 et la B1?
Oui et non... sur la 1.5 tu as 1 D26 et 1 C125...
http://www.vividaudio.com/speakers/oval ... tions.html
B1 Specifications
Configuration: 3 & 1⁄ 2 way vented cabinet
Cabinet material: Complex loaded carbon fibre filled polymer
HF – D26 – 26mm metal dome unit with Tapered Tube loading
MID – D50 – 50mm metal dome unit with Tapered Tube loading
LF – C125 – 2 x 158mm metal coned unit (coupled)
First D26 Break Up mode: 44,000 Hz
Sensitivity: 89dB @ 2.83Vrms and 1.0 meter on axis
Nominal Impedance (Ohm ): 4
Frequency range – 6dB points: 35 – 36,000Hz
Frequency response: 39 – 33,000 Hz +/- 2dB on reference axis
Harmonic distortion (2nd and 3rd): < .0.5% over frequency range
Cross over frequencies (Hz): 100, 900, 4000
Power handling (music program) watts rms: 300
Loudspeaker dimensions (H, W, D cabinet, D base) mm: 1095, 265, 375, 420
Net weight (kg): 38
et les V1.5 :
Configuration: 2 way vented cabinet
Finish: High gloss automotive
Drive units: 26mm metal dome hf unit 158mm metal coned lf unit
Sensitivity: 89dB/1w @1m
Nominal Impedance (Ohm): 8 Frequency range (hz): - 6dB points 40 - 42,000
Frequency response (hz): 42 - 39,000 +/- 2dB on reference axis Harmonic
distortion (2nd and 3rd harmonics): < .0.5% over frequency range
Cross over frequency (hz): 3000 Power handling (music program) watts rms: 150
Loudspeaker dimensions (H, W, D) mm: 1130, 255, 240
Net mass (kg): 23
Shipping dimensions (H, W, D) mm: 1300, 430, 460
Shipping mass (kg): 37 (unit)
