Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 6 invités
ChromaPure récap page 1
bonsoir, une version un peu plus aboutie doit sortir d'ici quelques jours apparemment !
CEDRICLOUIS - Pro-Divers.
- Inscription Forum: 28 Oct 2005 10:50
La 2.4.1 est prévue dans quelques jours selon tom
- realzven
- Inscription Forum: 13 Mar 2010 15:19
Bonne nouvelle !
Et voilà, la version finale de la 2.4.1 est sortie.
Le Changelog:
Le lien pour le téléchargement:
http://www.chromapure.com/distribute/st ... mapure.zip
Le Changelog:
New Features
We have added support for BT.1886 gamma transfer function to the Gamma module. You must enter the 100% white and video black data in the Options panel to get a accurate gamma response.
We have added an Excel-based report to the Color Checker module, including support for pre and post-calibration data.
We have added support for selectable gamma (including BT.1886) to the Color Checker module.
We have added support for the 4K Quantum Data 804a signal generator.
Improvements
We have simplified the test pattern generation/measurement functions in the Color Checker module. One click now displays a test pattern and takes a measurement.
We have added support for 75% stimulus test patterns to both the Lumagen auto-calibrate feature and the Lumagen Video Processor Control Toolbar.
We have added a Gamma Factor selector to the Lumagen Video Processor Control Toolbar to allow for easy across-the-board adjustments of gamma.
We have added the ability to use Auto-Advance when beginning measurements at 10% or 20% stimulus in the Pre/Post-Calibration Grayscale module.
Repeatability and speed with low-light measurements when using the Display 3 colorimeter has been further improved.
We have added adjustable increments to the Video Processor Control Toolbar to allow for both smaller and larger adjustment increments.
We have adjusted the layout of the auto-calibrate module to fix problems with selectable options being cut off and rendered invisible.
We have added support for custom colors to the Quantum Data 780 and 804a signal generators. Both signal generators can now be used in the Advanced Color Management, Color Checker, and Color Management (when selecting the 75% of Rec. 709 gamut) modules.
We have enabled a manual mode on the JETI 1211 reference spectroradiometer. This allows the user to manually select a desired refresh rate of the target display. However, for most applications we recommend that you continue to use the sync mode.
We have added additional test patterns to the AccuPel Signal Generator Toolbar.
We have added a Reset button to the Raw Data module that allows users to clear out data without having to close and then reopen the module.
We have enhanced both the layout and the user options for the Excel Calibration Report.
Bug Fixes
Several problems were fixed with the Detailed Report that arose as a result of adding 0% to the Pre and Post-Calibration Grayscale modules. The report will no longer return a Fatal Exception when 0% is not read. Also, several formatting issues were resolved.
We fixed some level errors with the DVDO Duo and AccuPel signal generator when using the 75% of Rec. 709 Gamut in the Color Management module.
After using the AccuPel signal generator with the Advanced Color Management module, white could be reset to a different color. This has been fixed.
Known Issues
When taking continuous measurements in the Gamma module using the BT.1886 gamma transfer function, you may see the target line revert to the default 2.22 level at the stimulus level being measured. This will be fixed in a few days in a maintenance release.
PingouMasqué - Membre HCFR
- Inscription Forum: 07 Déc 2007 10:14
Best news of the year
From tom huffman
http://www.avsforum.com/t/1174468/the-o ... t_23352257
From tom huffman
Announcement
After much back-and-forth over a long period of time I am happy to announce that ChromaPure will finally be supporting the retail i1 Display Pro.
Will will issue a maintenance release next week that includes support.
- realzven
Voilà une très bonne nouvelle !
Argh !!!!! Grilled.
En effet, la i1 retail est compatible avec CP ! Cool !
- mlg33
- Inscription Forum: 05 Déc 2010 20:36
mlg33 a écrit:Argh !!!!! Grilled.
- realzven
y a t il une réelle diff entre les 2 pack qui propsoe une i1 display pro ?
- Btbw
- Inscription Forum: 30 Aoû 2004 11:38
Quel 2 packs ?
Chromapure standard ou plus ? Ou tu parle des 2 sondes : display 3 oem (version normale) ou display 3 pro (version améliorée) ?
- realzven
la diff entre les deux display 3.
Pareil, j'ai regardé entre la standard et la pro, pour un particulier comme moi qui achèterait peut etre chromapure, la standard suffit ? (j'ai un x30)
- Btbw
La pro est étalonnée.
jazzliberator - Membre HCFR
- Inscription Forum: 10 Mai 2008 21:24
ça change quoi ? (par rapport à http://www.redcoon.fr/B308621-X-Rite-i1 ... m%C3%A8tre )
bon 50$ de frais de port si on prend tout par le site de chromapure :/
Vaut mieux acheter la sonde en France (i1 display) à 180€ + chromapure par leur site, économie des fdp.
- Btbw
Un étalonnage se fait/un étalon, une référence et celà permet à l'outil de réaliser des mesures au plus proche de la réalité, plus précises; sans celà toutes tes mesures se font/une marge d'erreur plus élevée et donc plus éloigné de la vérité. Tu économises sur le rendu des résultats obtenus.
Retourner vers Les logiciels de calibration
