Il semble que ce lecteur DVD/Divx venu d'Australie soit passé inapercu...
Il est pourtant le meilleur de sa catégorie si l'on en juge par ses performances globales.
Il permet de lire en streaming (ethernet et wifi) les contenus multimédia, un joli "Media Center"
Sa compatibilité Divx est sans aucun doute la meilleure qui existe si l'on tient compte de ce comparatif :
http://www.divxtest.com/form/divxtest2_list.php?lang=fra
Spécifications téchniques :
Audio Formats Supported
- MPEG 1 Layers I,II and III
- WAV
- CD Audio (With FreeDB Support)
- OGG Vorbis
- FLAC
- WMA
- AAC
- Video Formats Supported
- MPEG-1, MPEG-2 MP@HL, MPEG-4
- ASP@L5 (720p), WMV9 MP@ML (720p)
- XviD
- Nero Digital™
- QuickTime with MPEG4 encoding. .MP4 extension
Picture Formats Supported
JPG/JPEG2000, BMP, GIF, PNG, TIFF
Playlist Supported
M3U, PLS, ASX
Network Support
- Ethernet 10/100 Mbps
- Wireless 802.11b/g
- SMB support -- access Windows shares directly
USB 2 device Support
(Only if the device appears as a mass storage device)
- USB Thumb Drives
- USB HDD Drives
Internet Radio Support
- Integrated Internet Radio Player with preinstalled library of stations
- Only stations streaming MP3 or ASX are supported
Media Streaming Software
- TwonkyVision (Full Version), Windows Media Connect
- TwonkyVision supports Windows, MacOS X & Linux
- Share Pictures, Audio and Video Files
- UPnP enabled
DVD Player
- DVD-Video, SVCD, VCD 1.x and 2.0
- DVD-R/-RW/+R/+RW
- CD/-R/-RW
Extras
- Subtitle support
- Online Weather Panel
- HDCP support
- Digital Rights Management: Windows Media DRM 10 *
- EL backlit remote
- Multi-purpose joystick for quick and easy navigation
- ID3 Tag and display on VFD panel on player
- Incremental Pan and Zoom (fine grained control of zoom in .1 increments)
- Firmware updates from OSD. Check for new updates.
- WEP encryption support on Wireless 802.11g
I/O
- SCART output
- HDMI output
- S-Video output
- Composite Video output
- Component outputs
Audio
- Stereo output
- Coaxial output
- Optical output
- Analog 5.1 outputs
Connectors
- 10/100 Ethernet
- USB 2.0
- Wireless 802.11g
TV Types
- NTSC (480i / 480p)
- PAL (576i / 576p)
- HDTV (720p50 / 720p60 / 1080i50 / 1080i60)
![Image](http://www.zensonic.com/images/products/z500.png)
Devant :
![Image](http://www.z500series.com/images/products/Z500_front.jpg)
Derrière :
![Image](http://www.z500series.com/images/products/Z500_rear.jpg)
Les menus :
![Image](http://www.z500series.com/images/products/mainmenu.jpg)
![Image](http://www.z500series.com/images/products/music.jpg)
![Image](http://www.z500series.com/images/products/settings.jpg)
![Image](http://www.z500series.com/images/products/settings_firmware.jpg)
![Image](http://www.z500series.com/images/products/settings_video.jpg)
![Image](http://www.z500series.com/images/products/usb.jpg)
La téléco:
![Image](http://www.z500series.com/images/products/Z500_Remote_Off.jpg)
![Image](http://www.z500series.com/images/products/Z500_Remote_On.jpg)
Prix : 500$ Aust / soit 300 €uros
Le lecteur est disponible auprès du site marchand Kadek, il est possible de passer commande pour un envoi vers la France sans problème...
http://www.kadek.com.au/
=> Il upscale les DVDs protégés uniquement en HDMI
=> Il upscale les DVDs non protégés via l'HDMI et YUV
Qu'en pensez vous ? Quelqu'un a t'il vu ce produit ?
