http://www.avsforum.com/avs-vb/showthre ... 51&page=14
Chris Walker, de Pioneer USA, poste des photos et videos du 440
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: maiden123, ZEMBLA87 et 19 invités
Lecteurs Blu-Ray
[BD_3D] Pioneer 2011: BDP-140/440/LX55 - Tout en 1ère Page
- siderys
- Inscription Forum: 03 Jan 2005 17:53
Toujours Chris Walker :
"I have to admit I was surprised of the load time for Blu-ray. I used the movie The Eagle. The Oppo BDP-93 took 44 seconds from tray close to disc menu (Choose which version), the BDP-52FD took 33.4 seconds.. Not too shabby.... I have not done any other load comparisons yet, but I am more than happy to if anyone has any requests.."
Temps de chargement du BD "The Eagle" :
Oppo BDP-93 : 44 secondes
Pioneer BDP-440 : 33,4 secondes
- siderys
quelques photos du BDP 52FD par chris walker (http://www.avsforum.com/avs-vb/showthre ... st20983200)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010523.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010524.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010525.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010526.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010528.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010529.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010530.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010531.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010532.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010533.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010534.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010535.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010536.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010537.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010538.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010540.jpg)
![Image](http://i1124.photobucket.com/albums/l567/Walkamo/P1010543.jpg)
- realzven
- Inscription Forum: 13 Mar 2010 15:19
2 vidéos du BDP 52FD par chris Walker
http://www.youtube.com/watch?v=XSskZQPiIps
http://www.youtube.com/watch?v=1sE-KYc5N4A
- realzven
realzven a écrit:Daoud II a écrit:realzven a écrit:antislash a écrit:Bonjour, je lis que les 2 HDMI du LX55 permettent de scinder audio et video.
Donc à priori elle n'ont pas exactement les memes fonctions.
admettons que avec l'une d'elle on envoie la video seule directement vers un videoproj, et que l'on relie la seconde à un ampli HC, est-ce que la seconde enverra également la vidéo à l'ampli pour qu'il puisse la ressortir vers la TV par exemple ?
Si oui l'interet est de bypasser l'ampli avec l'une des HDMI ? quel que soit l'ampli ce sera toujours mieux que la vidéo aille directement au videoproj ? Qu'en est-il pour l'upscale 1080p par ex ?
selon son-video http://www.son-video.com/Rayons/HomeCin ... PLX55.htmlConnectique
1 sortie HDMI
1 sortie HDMI SUB (image + son en PCM stéréo)
donc la 2ème HDMI peut envoyer l'image vers la Tv mais le son sera en PCM stéréo
Donc,pour l'histoire des deux prises HDMI, avec mon ampli non 3D,je branche le projo sur l'une est la seconde HDMI sur l'ampli mais je n'ai que de la stéréo??
si la HDMI 2 est branché sur l'ampli, c'est du stéréo en PCM qui sera envoyé par la LX55 (donc décodage par la platine des formats audio) mais en bitstream la platine envoie le signal non décodé (DTS HDM ou DTHD par exemple) et c'est l'ampli qui décode. Selon ta signature ton onkyo TX-NR9206 décode bien les formats HD donc pas de problème
Juste un truc,j'ai un peu de mal
![:ane: :ane:](https://www.homecinema-fr.com/forum/images/smilies/ane.gif)
Est ce que c'est comme ma ps3 a l'heure actuelle,c'est a dire branchée sur mon ampli,qui me donne du son HD (DTS HDM etc..)mais qui n'est pas affichée sur mon ampli?
- Daoud II
- Inscription Forum: 27 Juin 2009 17:00
Le bitstream permet d'envoyer le signal audio sans décodage, c'est l'ampli qui s'en charge, et dans ce cas il affiche DTS HD MA ou Dolby True HD.
S'il n'affiche pas cela, c'est que ce sont les décodeurs du lecteur bluray qui sont utilisé et envoyé à l'ampli sous un format "downscalé", à utiliser pour les amplis qui n'ont pas les décodeurs adhoc.
Qu'on me reprenne si je me trompe...
- antislash
- Inscription Forum: 05 Oct 2007 23:18
realzven a écrit: si la HDMI 2 est branché sur l'ampli, c'est du stéréo en PCM qui sera envoyé par la LX55 (donc décodage par la platine des formats audio) mais en bitstream la platine envoie le signal non décodé (DTS HDM ou DTHD par exemple) et c'est l'ampli qui décode. Selon ta signature ton onkyo TX-NR9206 décode bien les formats HD donc pas de problème
On peut faire du bitstream aussi sur la HDMI 2 ?
- antislash
Daoud II a écrit:...Juste un truc,j'ai un peu de mal,"bitstream" késako??
- si PCM : la PS3 envoi un signal décodé et l'ampli ne fait son rôle que d'amplificateur (ton ampli n'affiche rien...)
- si bitstream : la PS3 envoi un signal non décodé et ton ampli décode le format (ton ampli affiche le format : DTS/DD/DTS HD...)
tu doit être en PCM : c'est ta ps3 qui décode et ton ampli n'affiche rien
edit : grillé par antislash
- realzven
antislash a écrit:realzven a écrit: si la HDMI 2 est branché sur l'ampli, c'est du stéréo en PCM qui sera envoyé par la LX55 (donc décodage par la platine des formats audio) mais en bitstream la platine envoie le signal non décodé (DTS HDM ou DTHD par exemple) et c'est l'ampli qui décode. Selon ta signature ton onkyo TX-NR9206 décode bien les formats HD donc pas de problème
selon ce que j'ai lu
![:oops:](https://www.homecinema-fr.com/forum/images/smilies/icon_redface.gif)
- realzven
ok merci de vos informations!!
donc cette platine lx55 est parfaite pour ma config,image en 3D et son HD,nickel,ou est mon bon de commande
![:mdr:](https://www.homecinema-fr.com/forum/images/smilies/icon_mrgreen.gif)
- Daoud II
la LX-55 sera ma future platine également pour moi
, j'attendais de voir le temps de chargement des br et d'après le "post" de siderys ça l'air tout bon ![:wink:](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
- xsi77
- Inscription Forum: 20 Oct 2004 13:40
yep. dès que je pourrais j'irais faire un tour chez mon revendeur pour voir combien il me fera dessus. Au moins 10% j'espère...
j'ai déjà eu 15 % sur mes T....
- antislash
antislash a écrit:yep. dès que je pourrais j'irais faire un tour chez mon revendeur pour voir combien il me fera dessus. Au moins 10% j'espère...![]()
si ton vendeur arrive à 300 Euros je suis là
- realzven
fo pas rêver. Ou etre patient.
Lorsque son remplaçant sortira, tu pourras peut-etre le toucher à ce prix ...
sinon tenter une CG.
- antislash
antislash a écrit:fo pas rêver. Ou etre patient.
![8)](https://www.homecinema-fr.com/forum/images/smilies/icon_cool.gif)
- realzven
Retourner vers Lecteurs Blu-Ray
