i'm trying to calibrate my epson tw700 with hcfr sonde i built withour IR filter.
the problem is that when i start (and i tried to move the sonde from 20 to 70 cm away from the screen) and i load the "Epson TW 700 natural" profile in hcfr software i always get this CIE (cfc1)
in any case the triangle is smaller than the reference one....
Where i'm failing ??
another thing is that if i measure with sensor0 is different from sensor1 ....
please help me.
thanks
p.s. if you prefer to answer in french for me is ok, i can read it, but i can't write
![:-)](https://www.homecinema-fr.com/forum/images/smilies/icon_smile.gif)
