Inside the plugin, there should be a Contents/Frameworks/Spyder.dylib file.
Is it readable ?
Modérateurs: Modération Forum Installations, Modération Forum Univers TV, Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 3 invités
Le version pour Mac
- popey.marin
- Inscription Forum: 21 Aoû 2007 22:33
It's there, with same md5 as on other installation where it works. Readable only by user (also same as working installation), -rwx------.
- henrikolsen
- Inscription Forum: 18 Jan 2011 15:05
wow !
This is really strange .... the same installation should give the same behaviour ...
Have you tried to copy one version to the other computer ?
- popey.marin
Getting more weird now... Tried to copy the package from the working installation - still no luck. But(!) if I launch the application directly from the mount I just copied from it works fine. Why it doesn't work when copied to and launched from this one machine I don't understand.
- henrikolsen
Can you check on both computer if your filesystem is case sensitive ?
The default mac os filesystem can be either case sensitive or unsensitive. You should fine this information in the "Sytem information" utility :
in the left coloum : hardware -> serial ata
in the right top list : select your hard drive
in the right bottom zone, there should be a "filesystem" line.
- popey.marin
Nice idea. Filesystem is indeed case sensitive on the problematic machine, and not on the other one where it is working.
- henrikolsen
I have to check my path management then !
Can you check where the difference lies between the real file path and the one shown in the console ?
I will fix that in the next release.
- popey.marin
Cannot initially spot the error. Here's what a `find /Applications/ColorHCFR.app` gives, with referenced paths mentioned in Console inserted where appropriate for comparison (look for <== marker),
/Applications/ColorHCFR.app/Contents
/Applications/ColorHCFR.app/Contents/Frameworks
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRGammaGraphController.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/HCFRPlugins
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/HCFRPlugins
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRColor.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRColorReference.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRDataSerie+IO.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRDataSerie.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRDataSerieListener.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRDataSource.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRDataStoreEntry.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRDataTypes.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRFullscreenWindow.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRGenerator.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRGeneratorDelegate.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRPlugin.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRPlugins.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRScreensManager+alerts.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRScreensManager.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRSensor.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRTool.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRUnicolorView.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Headers/HCFRUtilities.h
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/A/Resources/Info.plist
/Applications/ColorHCFR.app/Contents/Frameworks/HCFRPlugins.framework/Versions/Current
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/SM2DGraphView
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Headers/CTGradient.h
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Headers/SM2DGraphView.h
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Headers/SMPieChartView.h
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Resources/English.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Resources/Info.plist
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/Resources/fr.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/A/SM2DGraphView
/Applications/ColorHCFR.app/Contents/Frameworks/SM2DGraphView.framework/Versions/Current
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Sparkle
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/NSApplication+AppCopies.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/NSFileManager+Authentication.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/NSFileManager+Verification.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/NSString+extras.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/RSS.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUAppcast.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUAppcastItem.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUAutomaticUpdateAlert.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUConstants.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUStatusChecker.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUStatusController.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUUnarchiver.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUUpdateAlert.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUUpdater.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/SUUtilities.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers/Sparkle.h
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/Info.plist
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/SUStatus.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/SUStatus.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/SUStatus.nib/info.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/SUStatus.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUAutomaticUpdateAlert.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUAutomaticUpdateAlert.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUAutomaticUpdateAlert.nib/info.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUAutomaticUpdateAlert.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUUpdateAlert.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUUpdateAlert.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUUpdateAlert.nib/info.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUUpdateAlert.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/Sparkle.strings
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUAutomaticUpdateAlert.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUAutomaticUpdateAlert.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUAutomaticUpdateAlert.nib/info.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUAutomaticUpdateAlert.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUUpdateAlert.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUUpdateAlert.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUUpdateAlert.nib/info.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUUpdateAlert.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/Sparkle.strings
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
/Applications/ColorHCFR.app/Contents/Frameworks/Sparkle.framework/Versions/Current
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/CHCFile.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/CalibrationFile.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/Color.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/Endianness.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/Exceptions.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/IHCFile.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/ProfilesRepositoryIndexFileReader.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Headers/matrix.h
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Resources
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Resources/English.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Resources/Info.plist
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/Resources/fr.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/A/libHCFR
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/Versions/Current
/Applications/ColorHCFR.app/Contents/Frameworks/libHCFR.framework/libHCFR
/Applications/ColorHCFR.app/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/MacOS
/Applications/ColorHCFR.app/Contents/MacOS/ColorHCFR
/Applications/ColorHCFR.app/Contents/PkgInfo
/Applications/ColorHCFR.app/Contents/PlugIns
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/MacOS/AditionnalFramesPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/English.lproj/AditionnalFrames.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/English.lproj/AditionnalFrames.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/English.lproj/AditionnalFrames.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/English.lproj/AditionnalFrames.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/fr.lproj/AditionnalFrames.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/fr.lproj/AditionnalFrames.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/fr.lproj/AditionnalFrames.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/fr.lproj/AditionnalFrames.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/smpte-hd.png
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/smpte.png
/Applications/ColorHCFR.app/Contents/PlugIns/AditionnalFramesPlugin.hcfrPlugin/Contents/Resources/testimg.jpg
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/MacOS/IntegratedGeneratorPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj/IntegratedGenerator.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj/IntegratedGenerator.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj/IntegratedGenerator.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj/IntegratedGenerator.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/IntegratedGenerator.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/IntegratedGenerator.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/IntegratedGenerator.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/IntegratedGenerator.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/IntegratedGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/MacOS/KiPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiGenerator.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiGenerator.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiGenerator.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiGenerator.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiIRProfilesManagerTool.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiIRProfilesManagerTool.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiIRProfilesManagerTool.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiIRProfilesManagerTool.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensor.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensor.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensor.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensor.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensorUpdaterTool.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensorUpdaterTool.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensorUpdaterTool.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/KiSensorUpdaterTool.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/done.png
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/error.png
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiGenerator.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiGenerator.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiGenerator.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiGenerator.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiIRProfilesManagerTool.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiIRProfilesManagerTool.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiIRProfilesManagerTool.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiIRProfilesManagerTool.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensor.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensor.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensor.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensor.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensorUpdaterTool.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensorUpdaterTool.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensorUpdaterTool.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/KiSensorUpdaterTool.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/irProfiles.xml
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/notDone.png
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/sensor.jpg
/Applications/ColorHCFR.app/Contents/PlugIns/KiPlugin.hcfrPlugin/Contents/Resources/valid.png
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/MacOS/ManualDVDGeneratorPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/ManualDVDGeneratorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/MacOS/VirtualSensorPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/English.lproj/VirtualSensor.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/English.lproj/VirtualSensor.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/English.lproj/VirtualSensor.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/English.lproj/VirtualSensor.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/defaultVirtualValues.csv
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/VirtualSensor.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/VirtualSensor.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/VirtualSensor.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/VirtualSensorPlugin.hcfrPlugin/Contents/Resources/fr.lproj/VirtualSensor.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Frameworks
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Frameworks/Spyder.dylib
@executable_path/../Plugins/spyder2Plugin.hcfrPlugin/Contents/Frameworks/Spyder.dylib <== from Console
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/MacOS/spyder2Plugin
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/MacOS/spyder2Plugin <== from Console
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/English.lproj/spyder2Setup.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/English.lproj/spyder2Setup.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/English.lproj/spyder2Setup.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/English.lproj/spyder2Setup.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/fr.lproj/spyder2Setup.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/fr.lproj/spyder2Setup.nib/classes.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/fr.lproj/spyder2Setup.nib/info.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder2Plugin.hcfrPlugin/Contents/Resources/fr.lproj/spyder2Setup.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/Info.plist
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/MacOS
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/MacOS/spyder3Plugin
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/Resources
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/Resources/English.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/PlugIns/spyder3Plugin.hcfrPlugin/Contents/Resources/fr.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Resources
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/BenQ-7800.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/BenQ-8720.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/BenQ-W5000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW1000-Naturel-IR.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW2000-naturel-filtre-IR.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW600-Dynamique-filtre-IR.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW600-Naturel-filtre-IR.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW600-Naturel.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW600-dynamique.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW700-Naturel-filtre-IR.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-TW700-Naturel.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Epson-Tw1000-naturel.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Hitachi-PJ-TX100.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Hitachi-PJ-TX200.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Hitachi-PJ-TX300.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/JVC-DILA-HX2.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/JVC-DLA-HD1.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Mitsubishi-HC3000-ccr30.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Mitsubishi-HC3000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Mitsubishi-HC5000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Mitsubishi-HC900.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Mitsubishi-Hc3100.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Nec-6PG.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Nec-HT1000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Optoma-H70.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Optoma-H72-ccr30.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Optoma-H72.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Optoma-H78.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Optoma-H79.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Optoma-H81.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Panasonic-PTAE-2000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Panasonic-PTAE-700.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Panasonic-PTAE-900.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Plasma-Pioneer-PDP-506-XDE.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Plasma-Pioneer-pdp-436-xde.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sanyo-PLV-Z1-ccr20.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sanyo-PLV-Z1-ccr30.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sanyo-PLV-Z1.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sanyo-PLV-Z2.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sanyo-PLV-Z3.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sanyo-PLV-Z4.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sharp-Z10000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sharp-Z12000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sharp-Z2000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sharp-Z3000.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sim2-Domino-30H.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VPL-HS10-Filtre-Cinema.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VPL-HS10.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VPL-HS50.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VPL-HS60.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VW100-Ruby.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VW50-Pearl.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Sony-VW60.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Toshiba-MT400.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Toshiba-MT500.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Toshiba-MT700.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Toshiba-TDP-MT8.thc
/Applications/ColorHCFR.app/Contents/Resources/CalibrationProfiles/Yamaha-dpx1200.thc
/Applications/ColorHCFR.app/Contents/Resources/English.lproj
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/CIEChart.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/CIEChart.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/CIEChart.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/CIEChart.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/Credits.rtf
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/GammaGraph.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/GammaGraph.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/GammaGraph.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/GammaGraph.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/LuminanceGraph.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/LuminanceGraph.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/LuminanceGraph.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/LuminanceGraph.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/MainMenu.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/MainMenu.nib/designable.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/MainMenu.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/ProfilesManager.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/ProfilesManager.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/ProfilesManager.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/ProfilesManager.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/SatShiftGraph.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/SatShiftGraph.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/SatShiftGraph.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/SatShiftGraph.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/about.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/about.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/about.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/English.lproj/about.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/HCFRFile.icns
/Applications/ColorHCFR.app/Contents/Resources/Infos.rtf
/Applications/ColorHCFR.app/Contents/Resources/License.txt
/Applications/ColorHCFR.app/Contents/Resources/changelog.txt
/Applications/ColorHCFR.app/Contents/Resources/config.png
/Applications/ColorHCFR.app/Contents/Resources/contrast.bmp
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/CIEChart.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/CIEChart.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/CIEChart.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/CIEChart.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/Credits.rtf
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/GammaGraph.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/GammaGraph.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/GammaGraph.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/GammaGraph.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/InfoPlist.strings
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/Localizable.strings
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/LuminanceGraph.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/LuminanceGraph.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/LuminanceGraph.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/LuminanceGraph.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/MainMenu.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/MainMenu.nib/designable.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/MainMenu.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/ProfilesManager.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/ProfilesManager.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/ProfilesManager.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/ProfilesManager.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/SatShiftGraph.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/SatShiftGraph.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/SatShiftGraph.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/SatShiftGraph.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/about.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/about.nib/classes.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/about.nib/info.nib
/Applications/ColorHCFR.app/Contents/Resources/fr.lproj/about.nib/keyedobjects.nib
/Applications/ColorHCFR.app/Contents/Resources/icon.icns
/Applications/ColorHCFR.app/Contents/Resources/inspector.png
/Applications/ColorHCFR.app/Contents/Resources/logo.bmp
/Applications/ColorHCFR.app/Contents/Resources/measure.ico
/Applications/ColorHCFR.app/Contents/Resources/measure_lumi.ico
/Applications/ColorHCFR.app/Contents/Resources/measure_rgb.ico
/Applications/ColorHCFR.app/Contents/Resources/reference.png
/Applications/ColorHCFR.app/Contents/Resources/splash_shadowed.png
/Applications/ColorHCFR.app/Contents/Resources/stop.png
Console also says:
ColorHCFR[243] HCFRPluginManager : Unable to load plugin spyder2Plugin.hcfrPlugin : principal class HCFRSpyder2Plugin not found
Don't know if the difference in capitalization in spyder2Plugin(.hcfrPlugin) vs (HCFR)Spyder2Plugin matters here.
Console also says:
- henrikolsen
Ok, the case problem is fixed for the spyder 2 plugin. It will be in the next release.
The app is looking for the lib in a Plugins folder, and the folder name is PluIns.
The absence of the library makes it impossible to load the plugin, hence the "class not found" error in the console (the class is provided by the plugin once loaded).
- popey.marin
Great. Before next release I've temporarily fixed my local issue by making a copy of the dir, so I have both PlugIns and plugins now. Then I can continue. Thanks for your help.
BTW, does the Windows version contain attractive features that the OS X version do not have, or is the feature set more or less the same?
- henrikolsen
The windows version is currently far more complete than the mac os one. It has more features and supports more probes.
I try to upgrade the mac os version to add features when I can find some time to do so. Currently, I am working on an upgrade (after months and months of silence) to add continuous measures.
- popey.marin
Salut et s'il vous plaît pardonnez mon mauvais français.
C'est une question d'un débutant.
Mon mac a Affichez profils (Display Profiles) pour différents écrans; Adobe RGB, sRGB IEC61966 etc
Si j'utilise ColourHCFR intégré générateur ne le profil d'affichage affecter l'étalonnage ?
Je tiens à calibrer sur mon mac, mais vue sur mon lecteur DVD.
Ou serais-je mieux en utilisant un test (c.-à-GetGray) DVD et le mac que pour l'enregistrement?
- foxystoatypig
- Inscription Forum: 24 Avr 2011 11:58
Eye one display 2
Hello,
Great work with the application. Is the support for eye one display available yet in some form? Really looking forward to calibrting my projector![:-)](https://www.homecinema-fr.com/forum/images/smilies/icon_smile.gif)
Thanks!
Thanks!
- sefr
- Inscription Forum: 15 Aoû 2011 21:44
Nope, we're waiting for Xrite new SDK...
- ogobert
