Sony confident as 40GB model arrives at UK retail
SCE UK boss Ray Maguire has told MCV that the introduction of the new entry level 40GB PS3 will silence the doubters and take the platform to ‘the next level’.
In the week that SCE UK introduced the new SKU at £299 and revealed that the 60GB console is to be phased out, boss Maguire (pictured) stressed that Sony’s strategy was the result of industry pressure, falling production costs, and a desire to boost installed base as the industry moves into peak period.
“You’ve seen in the pages of MCV that most people want the price to come down – we have to take a more strategic view on when we do these things,” said Maguire. “We’re always mindful of price and installed base, but we’re also mindful that we have a sustainable business.
“We’ve been considering this since launch – this is all part of a very carefully thought-out plan.”
Maguire also hit out at the level of anti-Sony feeling on internet forums.
“If the product was too expensive, of course they’re going to feel ‘anti’, but now I imagine there will be some changing of attitudes,” he said.
“They don’t have sight of running the company and the financials involved. So they end up with internet information – and that is often based on a complete lack of understanding of the facts.”
Modérateurs: Modération Forum Oeuvres & Multimédia, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 18 invités
Pour discuter des jeux-vidéo
Big bang: Nouvelle PS3 à 399€ pour Noël
- Nobo
- Inscription Forum: 25 Déc 2000 2:00
Nobo a écrit:“We’re always mindful of price and installed base, but we’re also mindful that we have a sustainable business.
Tellement vrai
- Meven
- Inscription Forum: 04 Déc 2006 12:26
J'ai un petit soucis. J'ai fait l'acquisition d'une PS3 hier (modèle 60 go) or si j'ai bien la qualité en YUV, je ne l'ai absolument pas en hdmi. Je n'y arrive pas. Le lecteur de la PS ne reconnaît aucune source. J'avais acheté un HD-E1 en Juin et j'avais le même pépin; Je l'ai renvoyé bien qu'il ait parfaitement fonctionné sur un Misubishi HC3100 d'un ami. J'ai changé mes câbles hdmi mais rien n'y fait.
Le paradoxe est qu'avec mon vieux Denon 1920 en 720p, le hdmi faisait du super boulot.
En voulant passer à la HD, je rencontre un mur. Est il possible que la première génération de HD73 ne soit pas compatible ?
Je vais rentré en contact avec Otoma France dès lundi pour essayé de comprendre.
Ou cela viendrait il de la PS3 ou de ma célébrissime incompétence ?
John
John
- Rapoutzi
- Inscription Forum: 14 Déc 2000 2:00
Rapoutzi a écrit:J'ai un petit soucis. J'ai fait l'acquisition d'une PS3 hier (modèle 60 go) or si j'ai bien la qualité en YUV, je ne l'ai absolument pas en hdmi. Je n'y arrive pas. Le lecteur de la PS ne reconnaît aucune source. J'avais acheté un HD-E1 en Juin et j'avais le même pépin; Je l'ai renvoyé bien qu'il ait parfaitement fonctionné sur un Misubishi HC3100 d'un ami. J'ai changé mes câbles hdmi mais rien n'y fait.
John
Bonjour ,
as-tu essayé de "reseter" la PS3 en restant appuyer sur le bouton on/off quelques secondes jusqu'à entendre 2 bips ?
- wopr
- Inscription Forum: 08 Avr 2004 19:51
tu as un écran noir ?
"Remember, remember, the 5th of November."
- Danam
- Inscription Forum: 12 Fév 2002 2:00
wopr a écrit:as-tu essayé de "reseter" la PS3 en restant appuyer sur le bouton on/off quelques secondes jusqu'à entendre 2 bips ?
Oui tout à fait et à part réinitialiser le tout, il ne passe rien.
John
- Rapoutzi
Danam a écrit:tu as un écran noir ?
Oui. L'Optoma cherche une source hdmi en vain et me ramène sur le YUV comme si le hdmi n'existait pas.
John
- Rapoutzi
Rapoutzi a écrit:Danam a écrit:tu as un écran noir ?
John
Apparemment ,ta console est reliée à la fois en HDMi et en YUV au projo ; As-tu essayé de débrancher le cable YUV et de laisser juste l'HDMI relié à l'Optoma puis relancer la procédure de "ré-initialisation" ?
- wopr
wopr a écrit:Apparemment ,ta console est reliée à la fois en HDMi et en YUV au projo ; As-tu essayé de débrancher le cable YUV et de laisser juste l'HDMI relié à l'Optoma puis relancer la procédure de "ré-initialisation" ?
Non mais si je fais ça, je ne pourrais voir l'OSD à l'écran et la seule façon de voir ce que je fais est d'avoir le câble YUV de branché.
John
- Rapoutzi
Rapoutzi a écrit:Non mais si je fais ça, je ne pourrais voir l'OSD à l'écran et la seule façon de voir ce que je fais est d'avoir le câble YUV de branché.
Ah oui en effet, les deux en même temps je ne suis pas certain qu'on puisse.
- Meven
Rapoutzi a écrit:wopr a écrit:Apparemment ,ta console est reliée à la fois en HDMi et en YUV au projo ; As-tu essayé de débrancher le cable YUV et de laisser juste l'HDMI relié à l'Optoma puis relancer la procédure de "ré-initialisation" ?
John
Peut-être le problème vient-il de là .
Débranche l'YUV et tente un "reset" de la PS3 pour voir si l'Optoma la reconnait .
- wopr
Cela voudrait dire qu'on ne peut utiliser les deux en même temps ?
Mais je vais essayé ce que tu me conseilles. Après tout, il faut explorer toutes les pistes.
John
John
- Rapoutzi
étant connecté en YUV, (avec l' HDMI connecté également) as-tu tenté de changer les settings vidéo et de basculer sur HDMI ?
ensuite changer la source de ton projo sur l'entrée HDMI et ça devrait marcher non ?
- Danam
Rapoutzi a écrit:Cela voudrait dire qu'on ne peut utiliser les deux en même temps ?
John
En principe ,la PS3 ne sait "pas encore" gérer et sortir le flux vidéo sur plusieurs sorties en même temps (tout comme l'audio ).
- wopr
Danam a écrit:étant connecté en YUV, (avec l' HDMI connecté également) as-tu tenté de changer les settings vidéo et de basculer sur HDMI ?
Non, justement pas du tout. Le VP cherche lui-même la source. Si j'appuie sur la touche hdmi, il ne trouve rien et se remet sur YUV.
Quant à la PS, je suis allé dans les settings, j'ai coché hdmi et là, après 30 secondes d'écran noir, il revient en YUV.
John
- Rapoutzi
