Mission:
Les MX6 (749 livres la paire !):
spéc: Type: 3-way reflex Floorstander
- Bass/Mid: 3 x 6.5"(165mm); Tweeter: 6.5"(165mm)
- Crossover Frequency: 400Hz, 2.2kHz
- Frequency Response+/-3dB: 30Hz-20kHz
- Sensitivity SPL/M @ 2.83V: 91dB
- Recommended Amplifier: 25-200W
- Dimensions (HxWxD): 1100x250x420mm
Quad 25L (£1749.00)
spéc:- Bass response: 35Hz
- Sensitivity: 91dB/W/m
- Impedance: 6ohm nominal impedance
- Bass Driver: 16.5cm woven kevlar drive unit
- Midrange Driver: 2 12.5cm woven kevlar drive units
- Tweeter: 25mm fabric dome tweeter
- 20cm downward firing Auxiliary Bass Radiator
- Height: 112.5cm
Wharfedale Jade 7 (£2199.00)
Enclosure type: 3-way Aperiodic system
- Tweeter: 25mm aluminium dome
- Midrange driver: 75mm Acufiber cone
- Bass drivers: 2x 150mm Acufiber cones
- Frequency response: 45Hz - 24kHz
- Crossover frequncies: 540Hz; 2.5kHz
- Nominal impedance: 6 ohms
- Sensitivity: 88dB
- Recommended amplifier power: 30 - 150W
- Weight (per speaker): 27.5kg
- Dimensions (HxWxD): 1055x246x400mm
