Ridge Racer a écrit:whaou, c'est un vrai miroir cet écran![]()
c'est un peu vrai pour tous les samsungs non? c'est ce qui plait aux masses et que perso je deteste chez eux
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 41 invités
feverish a écrit: Samsung's S-PVA panels offer a response time of 8ms
Monitor
Windows description......... Plug and Play Monitor
Manufacturer description.... SAMSUNG
Manufacturer................ Samsung
Plug and Play ID............ SAM0319
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2007, ISO week 25
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 160 x 90 mm (~8")
Power management............ n/a
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.650 - Ry 0.330
Green chromaticity.......... Gx 0.300 - Gy 0.600
Blue chromaticity........... Bx 0.150 - By 0.080
White point (default)....... Wx 0.313 - Wy 0.329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 30-68kHz
Vertical scan range......... 59-61Hz
Video bandwidth............. 230MHz
Extension blocks............ 1
Timing recommendation #1.... 1920x1080 at 60Hz
Modeline................ "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Timing recommendation #2.... 1920x540 at 60Hz
Modeline................ "1920x540" 74.250 1920 2008 2052 2200 540 542 547 562 +hsync +vsync
Timing recommendation #3.... 1920x1080 at 30Hz
Modeline................ "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Timing recommendation #4.... 1280x720 at 60Hz
Modeline................ "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Timing recommendation #5.... 720x480 at 60Hz
Modeline................ "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
720 x 480 at 60Hz - Samsung
1280 x 720 at 60Hz - Samsung
1920 x 540 at 60Hz - Samsung
1920 x 1080 at 30Hz - Samsung
1920 x 1080 at 60Hz - Samsung
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C 2D 19 03 00 00 00 00
10: 19 11 01 03 80 10 09 78 0A AE A1 A6 54 4C 99 26
20: 14 50 54 20 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
40: 45 00 A0 5A 00 00 00 1E 01 1D 80 18 71 1C 16 20
50: 58 2C 25 00 A0 5A 00 00 00 9E 00 00 00 FC 00 53
60: 41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FD
70: 00 3B 3D 1E 44 17 00 0A 20 20 20 20 20 20 01 EA
Raw EDID extension (CEA-861)
00: 02 03 22 71 46 90 05 04 03 20 22 23 09 07 07 83
10: 01 00 00 E2 00 0F E3 05 03 01 67 03 0C 00 30 00
20: B8 2D 01 1D 00 72 51 D0 1E 20 6E 28 55 00 A0 5A
30: 00 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00
40: A0 5A 00 00 00 18 00 00 00 00 00 00 00 00 00 00
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09
EIA/CEA-861 Information
Revision number............. 3
DTV underscan............... Not supported
Basic audio................. Supported
YCbCr 4:4:4................. Supported
YCbCr 4:2:2................. Supported
Native formats supported.... 1
DTV formats supported....... 6
CE standard timings supported
1920 x 1080p at 59.94/60Hz (16:9) - HDTV (Native)
1920 x 1080i at 59.94/60Hz (16:9) - HDTV
1280 x 720p at 59.94/60Hz (16:9) - HDTV
720 x 480p at 59.94/60Hz (16:9) - EDTV
1920 x 1080p at 23.97/24Hz (16:9) - HDTV
1920 x 1080p at 28.97/30Hz (16:9) - HDTV
Display adapter
Adapter description......... RADEON 9550
Adapter device ID........... 0x41531002
Display settings............ 1920x1080, 32bpp
Pathou a écrit:http://www.01net.com/editorial/355467/l ... e-des-led/Les écrans LCD boostés par l'arrivée des Led
La technique de rétroéclairage par diodes électroluminescentes va remplacer l'actuelle à base de néons. A la clé, un respect des couleurs sans égal et de vrais noirs.
La plupart des grands constructeurs d'écrans LCD l'ont annoncé : à partir de 2008, ils ne produiront plus que des modèles à rétroéclairage par Led (Light Emitting Diode ou diodes électroluminescentes) en lieu et place de la classique technique à base de tubes néon (ou CCFL, Cold Cathode Fluorescent Lamps, pour cathode fluorescente froide).
http://www.hardware.fr/articles/630-1/a ... t-led.htmlLa technologie LCD actuelle va progressivement disparaître, remplacée d’abord par des écrans avec rétro-éclairage assuré par des tubes CCFL à gamut étendu, puis en backlight LED, puis enfin par l’OLED.
alfa a écrit:bienvenue sur le forum shrek91
shrek91 a écrit:Salut à tous les coupeurs de pixel en 4 !
Pour mon premier message,j'aimerais savoir comment la techno LED élargi l'espace colorimétrique sachant que (je dis peut etre une anerie!)la chroma est codée à 8 bits(dvd,hdvd)
et tout comme le Deep Color(hdmi 1.3),il y aurait obligation d'élargir d'abord la chroma sur les supports pour bénéficier de ce progrès.
Merci à tous.
Merci à tous.
