Je répond de non phone, concernant le buzz Jen dirai plus mai la je ne lenten pas du canapé
Je test tout sa et je ferai un cr plus approfondis
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 65 invités
[EPP_3D] Samsung Plasma 2011
- raid
- Inscription Forum: 27 Avr 2010 12:25
raid a écrit:Je répond de non phone, concernant le buzz Jen dirai plus mai la je ne lenten pas du canapé
vivement ce soir
- realzven
- Inscription Forum: 13 Mar 2010 15:19
Merci pour le lien du test ...realzven a écrit::D Update de la review du plasma 64D8000 de Chad B from AVS forum :
http://www.avsforum.com/avs-vb/showthre ... p=20168734
Update 4-19-2011: I just calibrated the 64" version of this TV, and I am very happy with the improvement in black level over the review sample! Before I attempted any black level readings and before I engaged Cinema Smooth, I could plainly see the minimum luminance level and contrast were significantly improved. In a darker than average room, the contrast looked outstanding even with dark scenes. No, it was still not in the same league as the Kuro 101FD I calibrated yesterday, but it looked similar to the higher end Panasonics and at least as good as last year's 63D7000/8000.
I have determined that my Chroma5 meter, which is rated to be accurate down to approximately .014 fL, at least gives gives ballpark readings from that level down to approximately .008 fL. The PN-64D8000's readings were below that threshold with both a black screen and the black section of the ANSI checkerboard pattern. While I cannot provide a reliable exact number for the black level, it is definitely lower than that of the PN-51D8000, and it is probably very close to the best Panasonic plasmas.
With a 1080P/24 input and Cinema Smooth engaged, I got a consistent reading of .012 fL.
As was the case last year, the contrast is dramatically improved with the larger panel size, and picture quality is a significant notch higher as a result.
Pas ridicule du tout le D8000 .
- Urga
- Inscription Forum: 15 Mar 2006 14:35
Personne pour parler du menu cache pour la garanti ,je c ke c juste pour mettre sur on l je et ke au cas ou on peu basculer sur off, c pour savoir ke je le fasse ce soir pour test la 3d mici
- raid
Urga a écrit:Merci pour le lien du test ...realzven a écrit::D Update de la review du plasma 64D8000 de Chad B from AVS forum :
+1, j'espère pouvoir lire des review de Chad B sur le D550 et du D6500 (6900 chez nous) bientôt voir le niveau des noirs est identiques, car pour rappel le niveau des noirs du C550 était aussi bon que sur les C7000/C8000 (lu sur AVSForum, faut que je retrouve le lien )
En plus D-nice doit faire une review du D8000 bientôt et on connait son niveau de référence dans le monde du plasma surtout sur AVS
- realzven
raid a écrit:Personne pour parler du menu cache pour la garanti ,je c ke c juste pour mettre sur on l je et ke au cas ou on peu basculer sur off, c pour savoir ke je le fasse ce soir pour test la 3d mici
je sais pas désolé
- realzven
de " realzven " ,
C'est le pape du plasma .
+1 ,En plus D-nice doit faire une review du D8000 bientôt et on connait son niveau de référence dans le monde du plasma surtout sur AVS
- Urga
realzven a écrit:raid a écrit:Personne pour parler du menu cache pour la garanti ,je c ke c juste pour mettre sur on l je et ke au cas ou on peu basculer sur off, c pour savoir ke je le fasse ce soir pour test la 3d mici
je sais pas désolé
A propos de pas savoir, est-ce que par hasard t'avais trouvé l'info sur les sous-titres avec le pvr? (question évoquée sur le topic il y a qq semaines)
- pa159
- Inscription Forum: 14 Nov 2007 15:54
Hello dan le menu caché quel est l'option à mettre sur on merci
- raid
G mis ir sur on etein le tv puis redémarrer je lance la conversion 2d 3 d mais les lunette s'active pas
- raid
les photos raid tu peux me dire si la télécommande est tactile ?
- montheo1
- Inscription Forum: 14 Déc 2008 13:37
Je suis sur mon fone et plus internet à free kel daube
La téléco non tactile à mon goût nul la teleco car je préfère celle du c7700. Gris alu et bien fini
Pour les tiff demain si g recup le net
Bonne soirée
Bonne soirée
- raid
je vais voir demain pour garder la mienne
- montheo1
Bon bah je v appeler mob revendeur ou samy c même plu un buzz la mais la cata un gro bourdonnement horrible ki me soule même ma femme lenten pour dire
À suivre donc pi être un movai branchement
À demin
À demin
- raid
raid a écrit:Bon bah je v appeler mob revendeur ou samy c même plu un buzz la mais la cata un gro bourdonnement horrible ki me soule même ma femme lenten pour dire
À demin
- ethma
- Inscription Forum: 23 Mar 2011 22:50
