Conclusion de la review :
(dark room, 1080P/24, Cinema Smooth engaged)
The first thing that struck me was the beautiful color; it was saturated and rich but still natural. There was lots of pop in bright scenes, but blacks had a slight glow in dark scenes. Whites were pure and vibrant. Shadow detail was excellent- well balanced and neutral. I saw very detailed resolution. The image was very slightly grainy when sitting close to the screen with NR off, but it looked smooth from a more typical viewing distance. The picture was stable, with no pumping or floating blacks. Flesh tones were natural. Pans and motion were good. I experimented with turning Cinema Smooth off and on; it was hard to see the black level penalty when engaging CS because of the large, bright menu screen, but it did seem to be slightly perceptible.
In every regard except MLL and dark scene contrast,
I absolutely loved the image I saw on the PN51D8000. I have not seen any other display that exceeds it's picture quality in many respects. Is the black level performance enough to tame your enthusiasm for the PN51D8000? If you're hard core like my buddy, who liked his CRT front projector's blacks so dark that seeing his hand held up between his eyes and the screen could be a challenge, then yes. If your tastes are more moderate and you watch with a little light in the room, then sit back and enjoy that beautiful picture!
Traduction google
La première chose qui m'a frappé, c'est la belle couleur, il a été saturé et riche mais toujours naturelle. Il y avait beaucoup de pop dans les scènes claires, mais les Noirs avaient une légère lueur dans les scènes sombres. Blancs étaient pures et dynamiques. détail de l'ombre était excellente, bien équilibrée et neutre. J'ai vu la résolution très détaillée. L'image a été très légèrement granuleuse lorsque vous êtes assis près de l'écran avec NR off, mais il a regardé sans heurt d'une distance de plus de vision typique. La photo a été stable, sans les Noirs de pompage ou flottantes. tons de chair étaient naturelles. Casseroles et le mouvement ont été bonnes. J'ai expérimenté avec le retournement Cinema Smooth sous et hors tension, il était difficile de voir la peine de niveau de noir lorsqu'ils s'engagent CS en raison de la grande, l'écran de menu lumineux, mais il semble être légèrement perceptible.
En ce qui concerne tous les sauf MLL et contraste de la scène sombre, j
'ai adoré l'image que j'ai vu sur le PN51D8000. Je n'ai pas vu tout autre affichage qui dépasse la qualité d'image il est à bien des égards. Le niveau de performance assez noir pour apprivoiser votre enthousiasme pour le PN51D8000? Si vous êtes noyau dur comme mon copain, qui aimait les noirs de son projecteur frontal CRT si sombre que de voir sa main jusqu'à entre ses yeux et l'écran peut être un défi, alors oui. Si vos goûts sont plus modérés et que vous regardez avec un peu de lumière dans la chambre, puis asseyez-vous et profitez de cette belle image!
