Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: faraksen, VampirXX et 107 invités
[EPP_3D] PLASMA SAMSUNG PS51D550
Oui , bof il délaisse le Plasma complétement et c'est pas nouveau ...
- Urga
- Inscription Forum: 15 Mar 2006 14:35
Sur AVSForum :
http://www.avsforum.com/avs-vb/showthre ... 43&page=12
Noirs D550 aussi bien que sur D8000 ?
I measured these on my PS51D550: 0.05 cd/m^3 (60Hz) and 0.06 cd/m^2 24Hz+CS
David Mackenzie at HDTVtest.co.uk measured these on a PS51D8000: 0.050 cd/m2 (60hz), 0.062 cd/m2 (24p), 0.065 cd/m2 (50hz)
As much as I can remember it was ChadB who compared the smaller and higher panel sizes
- Urga
Quelqu'un a t'il de bons tuyaus pour des lunettes 3D a pas chéres? Les vendeurs sur Ebay de Corée du Sud son t'il fiable? J'y trouve des SSG3700CR a moins de 110€ les 2 paires ou des SSG3500CR a moins de 74€ les 2 paires livré.
- Vincentp72
- Inscription Forum: 09 Déc 2010 22:05
Un D550 EU passé en D7000 calibré ( BdB 10pts ) : :
Ok, if you are interested, then I will post my final settings.
0a: Carefully and fully backup your current Service Menu settings! (Everything under ADC/WP)
0b: Change your model number to D7000
0c: Connect your player to HDMI_3 and your fake/inactive device to HDMI_1
1a: Reset your WP settings: set all of the eight editable values to 128 (this is their default state).
1b: Optionally run a HDMI Calibration using a 8x8 inverted checkerboard pattern (->)
1c: Restart with a Factory Reset
2a: Go through the initial setup and select HDMI_1 as your source.
2b: Apply the settings as follows...
Mode:Movie
Cell Light---20
Contrast---95
Brightness---54
Sharpness---18
Color---50
Tint---50/50
Black Tone---off
Dynamic---off
Gamma--- 0
Expert Pattern---off
Rgb Only---off
Flesh Tone---0
Motion Light---off
xvYcc---off
Color Tone---warm2
Digital Noise---off
Mpeg Noise---off
HDMI Black Level---Normal (if available)
Film Mode---CinemaSmooth/Auto1 (if available)
Energy Saving---off
Eco Sensor---off
Game Mode---off
BD Wise---off
Color Space
_______
Red_r-----50
Red_g-----37
Red_b-----29
_______
Green_r-----62
Green_g-----27
Green_b-----0
_______
Blue_r-----0
Blue_g-----0
Blue_b-----50
_______
Yellow_r-----47
Yellow_g-----50
Yellow_b-----36
_______
Cyan_r-----100
Cyan_g-----48
Cyan_b-----50
_______
Magenta_r-----47
Magenta_g-----43
Magenta_b-----50
________________
White Balance
r_offset-----25
g_offset-----25
b_offset-----25
r_gain-----39
b_gain-----25
g_gain-----29
________________
10 Point Calibration
r1--------(+2
g1-------(+3
b1-------(+4
r2-------(+3
g2-------(+4
b2-------(+4
r3-------(+2
g3-------(+4
b3-------(+4
r4-------(-3
g4-------(-1
b4-------(+1
r5-------(-3
g5-------(0
b5-------(-1
r6-------(-2
g6-------(+1
b6-------(0
r7-------(-4
g7-------(-1
b7-------(+1
r8-------(-4
g8-------(-3
b8-------(-1
r9-------(+6
g9-------(+4
b9-------(+5
r10-------(0 (-> Why the hell would anybody change this if he used the 2p Gains earlier? And you should...)
g10-------(0
b10-------(0
|3D settings - Differences only|
Contrast---100
Brightness---45
b_offset-----46
r_gain-----33
g_gain-----11
Too bad we Europeans do not have Cal-Day/Night presets because CinemaSmooth makes differences, these settings are optimal for 24fps but not for 60fps video.
I am thinking about connecting another HDMI input and calibrate that for 60Hz.
IRE10 and 20 is well, let's say questionable.
I used my ColorMunki in "adaptive integration time" sensor mode (only available with ArgyllCMS driver). It's usually much more accurate on low light than the default mode (default ArgyllCMs or original X-Rite driver) but also more unpredictable and questionable.
I also checked my calibration result with CalMan v4 (it uses the original X-Rite driver and only offers "average many dark readings" of normal sensor mode but do not offer adaptive sensor mode like ArgyllCMS). It agreed about the spot-on 6 point gamut but it thought my white balance is not that smooth and my gamma is way off on low IREs.
I give CalMan a try but the calibration result looked much worse (way too bright and bluish low IREs -> This is why THX/ISF guys say the CM is not good for IREs lower than 30. It's true with the X-Rite driver.)
I trust in the ArgyllCMS results better but I plan to pick up a colorimeter with better
- Urga
Salut ,
J'ai toujours pas vu de D6900 ...
- Urga
Urga a écrit:Salut ,
moi oui mais bon à darty mais il passait du rugby samedi après midi sur canal la qualité de la transmission etait pas top, l'image sur tout les écrans était moche... moi qui revait de voir un D6900 dans de bonnes conditions ...
j'ai pas pu juger de la qualité du D6900 mais au vu D550 que j'avais à la fnac il doit être tout aussi bon...
- realzven
- Inscription Forum: 13 Mar 2010 15:19
T'es chateux ...realzven a écrit:Urga a écrit:Salut ,
Mon " Darty " ne l'a pas en expo que sur le catalogue en commande , le D550 est en expo .
Saturn expose le 51 D550 et le 64 D8000 , mais pas le D6900 .
Autre chose mercredi dernier le D550 était en rupture de stock chez eux .
- Urga
Urga a écrit:T'es chateux ...realzven a écrit:Urga a écrit:Salut ,
Au fait c'était le 59D6900 je suis en train de négocier avec wafette pour la taille (et le prix )
le 59 pouces est grand ; il n'avait pas de D550 juste des D450...
sinon je pense que le D550 doit se vendre comme des petits pains
et c'est vrai qui ma laissé une excelente impression
- realzven
Les interressés de la 3D à petit Budget ont du ce jeter dessus .
- Urga
Urga a écrit:Vu la qualité/prix sa doit dégager en + il fait la 3D .realzven a écrit:
je crois que je vais me faire un darty + surcouf ce midi pour voir un D550 ou d6900
si je vois un D6900 je fais un screenshot
- realzven
Pourquoi pas ?
J'ai pas de mobile pour cela vait pas trimbaler mon équipement screen dans les magasins .
" Messieurs dames Circulez je m'installe , faudrait éteindre les néons SVP ... "
- Urga
Je reçois mon 59D6900 mercredi, j'essayerai de vous faire quelques photos
- Mc_Fly
- Inscription Forum: 04 Juil 2010 20:46
Pourquoi pas ?
Bon verdict de ma ballade du midi :
- surcouf : PAS de D6900 ... un PS51D550 avec GameOne TV donc rien pour juger de la qualité de la TV
- darty : Pas de D6900 et pas de 550
Voilà retour à la case de départ
- realzven
Pourquoi pas ?
- realzven
