Des informations officielles sur les changements de firmware apportés par Philips. On trouve ça ici.
Pour info, voici la liste des tous les changements :
Software history
Main modifications
Each release contains:
• All solutions identified in earlier versions
• Improved connectivity to improve compatibility with other external devices
Q591E_0.100.0.0
• implementation to switch off the overnight update.
• Regression caused on HDMI has been resolved.
Q591E_0.97.0.0
• Solution for picture drops when watching digital broadcasts in the United
Kingdom.
Q591E_0.94.0.0
• audio issue solved when switching between HDMI sources.
• Optimalisation Audio SPDIF for HTS3367
Q591E_0.93.0.0
• Upgrade Madrid solution.
• Improvement for Riks-TV.
• Improved picture quality via availability of more colors.(color gamut)
Q591E_0.91.0.0
• Solution for the Madrid Broadcast issue.
• Improvement digital channel reception La7 DVB payTV channel Italy.
• DGTVi approved.
Q591E_0.89.0.0
• Improvement of Teletext.(no longer mixed pages or skipped parts)
• Solution for loosen channels overnight in Denmark.
• Reboot of the 42PFL9803D/10 after switching to the HDMI(Philips 1080)
solved.
Q591E_0.83.0.0
• replaces all previous releases, including Q591E_1.58.14.0.
• problems with installation algorithm for DVB-T UK solved.
• audio problems with certain STB devices solved.
Q591E_0.58.14.1
• Improvements for DNLA(decrease time to display thumbnails)
• Improvements DVB-T for France(region with the Belgian boarder)
Q591E_0.58.11.0
• Improvement of the OSD after start-up.
Q591E_0.58.8.0
• Missing of information on TXT pages has been solved.
• Improved settings when identifying the source as a 'PC'.
• Resolving the fact that mouse movements lag behind.
• Solution about disappearing subtitles with DVB-C.
• Sporadically no picture on DVB-C channels with specific CAM's and when
starting up the TV, has been solved.
Q591E_0.58.5.0
• Improvement of the connection via HDMI with Bose system.
• Improvement of stand-by behaviour.
• Improvements for EPG behavior in UK.
• Functionality added for Australia and Finland.
• Improvement scroll behavior remote control.
• supports MPEG4 in Spain.
Q591E_0.25.26.1
• Improved channel reception in Spain.
Q591E_0.25.24.1
• Improved black impression.
Q591E_0.25.21.0
• A 1080p 60Hz type of input signal does no longer show flashes on screen
with this software upgrade.
• The Common Interface functionality is now enabled for the UK with this
software upgrade.
• Possible picture judder with MPEG4 signals is solved with this software
upgrade.
• While the TV relaunches its software during normal use, strange picture
and sound artefacts no longer appear, with this software upgrade
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 170 invités
Philips xxpfl7403, xxpfl7423
- Kcnarf57
- Inscription Forum: 09 Déc 2008 11:12
Salut à tous,
Je viens de brancher mon PC par la prise dite "VGA" sur ma 47PFL7403, et je ne parviens pas à mettre une réso supérieure à 1360*768.
Déjà, à la base, le maxi était le 1024*768. Il a fallu que je décoche sur le panneau de config du PC l'option "masquer les résolutions non supportées par l'écran".
Là, j'ai bien accès à quantité de réso, dont le 1920*2080. Mais la TV n'affiche pas l'image.
Elle m'indique "pas de signal video" et non "signal video non supporté", ce qui indiquerait qu'elle reçoit quelque chose au moins...![:roll:](https://www.homecinema-fr.com/forum/images/smilies/icon_rolleyes.gif)
J'ai essayé le mode couleur 16 bits également, et je suis resté en 60hz.
Bref, si quelqu'un a une idée, je suis preneur.
Pour info, j'ai un P4 2Ghz sous Win XP avec une CG Nvidia GeForce 4 MX 440 with AGP8x.
Fafa - Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV
Fafa a écrit:Salut à tous,
salut fafa,
je pense au vue des capacités de ta CG tu aura pas mieux que le 1024 x 768.
"• Moteur de traitement vidéo (VPE) de NVIDIA proposant des capacités vidéo et multimédia inégalées
° Intégration d'un encodeur TV à une résolution de 1 024 x 768
° Intégration d'un décodeur MPEG-2 matériel
° Compensation de mouvement et IDCT
° Compatibilité HDTV ....."
si tu pousse ta CG au dessus, tu aura un ecran noir due a la carte.
je pense que si tu veux profiter du 1920 x 1080 sur ton ecran, il te faut changer de CG.
cordialement
ange
- aNGe_a_Sa_FeMMe
- Inscription Forum: 11 Avr 2008 21:57
Merci pour ton avis.
Actuellement, j'arrive quand même à être en 1360*768, ce qui n'est pas trop mal.
