Ça change quoi par rapport à l'origine ?
J'ai toujours peur de flasher du matériel sous garantie....
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 58 invités
Philips 42pfl9803h, rétroéclairage LED, primé EISA
- wolfridge
- Inscription Forum: 27 Juil 2009 21:08
voilà les améliorations en fonction des versions
http://www.p4c.philips.com/files/4/42pf ... ur_aen.pdf
Q591E_0.97.0.0
• Solution for picture drops when watching digital broadcasts in the United
Kingdom.
Q591E_0.94.0.0
• audio issue solved when switching between HDMI sources.
• Optimalisation Audio SPDIF for HTS3367
Q591E_0.93.0.0
• Upgrade Madrid solution.
• Improvement for Riks-TV.
• Improved picture quality via availability of more colors.(color gamut)
Q591E_0.91.0.0
• Solution for the Madrid Broadcast issue.
• Improvement digital channel reception La7 DVB payTV channel Italy.
• DGTVi approved.
Q591E_0.89.0.0
• Improvement of Teletext.(no longer mixed pages or skipped parts)
• Solution for loosen channels overnight in Denmark.
• Reboot of the 42PFL9803D/10 after switching to the HDMI(Philips 1080)
solved.
Q591E_0.83.0.0
• replaces all previous releases, including Q591E_1.58.14.0.
• problems with installation algorithm for DVB-T UK solved.
• audio problems with certain STB devices solved.
Q591E_0.58.14.1
• Improvements for DNLA(decrease time to display thumbnails)
• Improvements DVB-T for France(region with the Belgian boarder)
Q591E_0.58.11.0
• Improvement of the OSD after start-up.
Q591E_0.58.8.0
• Missing of information on TXT pages has been solved.
• Improved settings when identifying the source as a 'PC'.
• Resolving the fact that mouse movements lag behind.
• Solution about disappearing subtitles with DVB-C.
• Sporadically no picture on DVB-C channels with specific CAM's and when
starting up the TV, has been solved.
Q591E_0.58.5.0
Improvement of the connection via HDMI with Bose system.
• Improvement of stand-by behaviour.
• Improvements for EPG behavior in UK.
• Functionality added for Australia and Finland.
• Improvement scroll behavior remote control.
• supports MPEG4 in Spain.
Q591E_0.25.26.1
• Improved channel reception in Spain.
Q591E_0.25.24.1
• Improved black impression.
Q591E_0.25.21.0
• A 1080p 60Hz type of input signal does no longer show flashes on screen
with this software upgrade.
• The Common Interface functionality is now enabled for the UK with this
software upgrade.
• Possible picture judder with MPEG4 signals is solved with this software
upgrade.
• While the TV relaunches its software during normal use, strange picture
and sound artefacts no longer appear, with this software upgrade.
- alfa
- Inscription Forum: 27 Avr 2003 14:33
Susension Maj automatique des chaines
Depuis la dernière MaJ disponible sur le site PHILIPS Version : 000.100.000.000,une nouvelle option permettant la suspension de la maj automatique des chaines est apparue dans le menu Installation .
Je l'ai activé pour éviter la mise en route du téléviseur à 5h tous les matins .
Mais même en la mettant ON,celui ci se met malgré tout sous tension!
Avez vous rencontré le même pb pour ceux qui 'ont activé cette option?
Merci de votre aide.
- LCD31
- Inscription Forum: 18 Déc 2004 0:03
