Suite à mon dernier et ultime proXchange (suivi de la vente du projo), j'avais eu la réponse suivante du SAV Infocus à propos du flickering :
Dear Stéphane Mottelet,
Thank you for contacting Infocus.
Every modern mercury high pressure lamp will show lamp flicker. This is
caused by arc jump in the lamp itself. Due to the light tunnel, a short
duration of jumping will not be noticed, as the light is bounced around and
integrated again with the 'good' light. Longer duration jumps will become
visible, specifically with light (e.g. white) backgrounds. Every single
Mercury high pressure lamp (all lamp manufacturers are facing this
phenomenon), will eventually show arc jump. Due to the extreme high
temperatures and the current, molecules on the surfaces of the two
electrodes will disappear or be re-arranged. The current tries to find the
shortest way with the less resistance as possible. It can therefore be that
the arc is not going straight through the electrode ends, but crosses over
taking another path. This in turn causes another position relative to the
lamp reflector (out of the center) so that less light is beamed into the
light tunnel. This is perceived as flicker (max light followed by less
light).
Some lamps will show this earlier than others and might disapear over time
again.
This is not caused by a defect of the unit, this phenomenon is technology
related.
Intéressant non ? Pas besoin donc d'abuser du proXchange pour les problèmes de flickering?
En y réfléchissant un peu, je me souviens que ce phénomène arrive vers les 50h de la lampe. Tout ceux qui ont passé outre (si je me souviens des posts) ont constaté une disparition du flickering vers 100h.
S.
3 messages • Page 1 sur 1
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 25 invités
Les Téléviseurs CRT, les Rétro-Projecteurs et autres TV
LS110 et Flickering : le comment du pourquoi
- stephane999
- Inscription Forum: 06 Juin 2002 11:06
Les miens sont arrivés vers 15h pour la 1ère lampe et 8h pour la 2ème puis revente du LS110
- DVDPhil
- Inscription Forum: 31 Jan 2002 2:00
moi sur le mt5 je l'avais remarquer au début,puis ça à disparus et depuis ,rien(156h au compteur),je ne sais pas si s'etait du à ça,mais javait réglé le sens de la prise secteur,un peut près à la mème période,sens qui à une grande importance vu la différence des valeurs que j'ai pu trouvé.
bref acun probleme
bref acun probleme
- mich
- Inscription Forum: 13 Jan 2002 2:00
3 messages
Retourner vers Cathodiques / Autre
