Je suis un peu perdu avec les redresseurs et les différentes variantes de la 5U4.
Selon les marques de tube de redresseur, les infos techniques sur les datasheets varient pour la capacité d'entrée.
JJ 5U4GB = 40uF
Electro Harmonix EH 5U4GB = 40uF
Emission Labs 5U4G-Mesh = 40uF
Shuguang 5U4G (base maron) = 10 uF
Shuguang 274B = 4uF
PSVANE HIFI 5U4G = 4uF
PSVANE WE274B = 4uF
PSVANE 274B = 4uF
Shuguang 5Z3P (base métal J) = 4uF
KR RK 5U4G = 10uF
Brimar 5U4G = 32uF
TUN-SOL 5U4G = 4uF
Sylvania 5U4G = 4uF
General Electric 5U4G-GB = 40uF
RCA 5U4G-GB = 40uF
J'ai aussi trouvé cette note sur le site d'Emission labs.
There is common misunderstanding that 5U4G and 5U4GB is electrically the same. 5U4GB is a version, with lower internal resistance and higher peak current is allowed. The GB version is not the same tube as the G Version. Replacing 5U4G with 5U4GB may result in higher rectified voltage, so should never be done. Replacing 5U4GB with 5U4G may result in lower rectified voltage, and may result in damage of the 5U4G rectifier.
Cela devient compliqué à suivre.
![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
