![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 30 invités
Amp Ohm FP-CA-AU 630VDC - 5% tolerance
Technical Specifications (according to manufacturer): "Amp Ohm Audio Capacitors are specially designed for high performance audio systems. The capacitors are hand wound and have their insulated copper leads hand soldered before being assembled in a plastic case and resin sealed. The resin filled end identifies the outer winding. This construction results in the capacitors having low ESR and low inductance and possessing high stability with respect to both temperature and frequency. They are ideal for use in loudspeaker crossover networks and valve amplifiers where pure sound is at a premium. Line on label denotes outer foil".
Sound: The Amp Ohm FP-CA-AU is a very neutral sounding capacitor that takes a nice smooth and calm approach to the reproduction of music. I found the balance of the midrange very pleasing letting acoustic instruments keep their natural warm tone. Absolute detail and air isn't quite up to the level of an Audyn Cap Plus or Mundorf Supreme but it comes very close although they do need some time to open up so don't judge them fresh out of the box. Spatiality is broad with reasonable depth but if you want "bowling alley" depth go for (the much more expensive) Mundorf Silver/Oil. Compared to the more luxurious Amp Ohm capacitors they are more 2D and a little rough, but again those cost far more.
Verdict: 8,5
ils sont en soldes chez audiophonicsAlexScan a écrit:Prochain condo à l'essai dès que j'aurai reçu mon nouveau module DAC :Amp Ohm FP-CA-AU 630VDC - 5% tolerance
t'es pas joueurptiJean a écrit::mdr:
Achtung aux boîtes en bois : j'oserai jamais.
J'ai pas envie de faire brûler mon salon !
