![Image](http://frog-publicite.com/images/blog/dcx2496.jpg)
une petite photo de mon dcx2496 a base de sabre es9023 + batterie 40000ma 7.4v !!
Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 20 invités
Nico a écrit:Pas trop lu de commentaires sur celui-là :
http://www.diyinhk.com/shop/audio-kits/ ... c_pcb_only
Au moins avec ce genre de carte on peut soigner l'alim...
Upgrade components,
use TCXO 0.5ppm, ELNA 8200uf caps, WIMA between ES9018 IC, axial Philips etc... it is a big improvement from the regular parts!
high quality R core transformer
TWO pcs seal transformer for seperatly power supply for digital and analog
Include newest U8 series XMOS USB support DSD
Support coaxial and optical and USB input
With XLR balanced output and RCA analog output
4 layers quality PCB board and total six pcs AD797 opamps which are recommended by ESS company and most hifier
3 golden plated PCB mounted RCA jacks with better and solid connecting
add better aluminum feet, improving our assembling
