Modérateurs: Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 10 invités
Discussions techniques sur les autres types de projet DIY : la fabrication de meubles, câbles, accessoires divers, ...
Cable de modulation "Great White Shark"
Message » 31 Aoû 2003 15:26
http://evildonut.34sp.com/diy/GWS.html : qqn a deja essayé ca ?
Il est basé sur le cable maplin ref. CC23A à 15£ le metre. :
"The ultimate in high quality screened audio cable, having 5/0.28mm extruded, pure silver strands as the centre conductor in a red polyethylene inner insulator, surrounded by a silver-plated copper braid over foil screening, and covered overall in a translucent sheath."
en rajoutant des plugs maplin ref. JZ13P (gold plated, teflon insulation) à 2£ piece, ca nous fait 23£ la paire de 0.5m. Ca reste tout a fait raisonnable, il faut juste voir les frais de livraison.
00940
Inscription Forum: 08 Avr 2003 6:04
Message » 31 Aoû 2003 16:33
Dommage ca aurait été du Téflon c'était nettement meilleur...
ogobert
Fondateur et Membre d'Honneur
Message » 31 Aoû 2003 18:39
ogobert a écrit:> polyethylene inner insulator
Même après lu ça :
If you have done some research on this topic, you will have noticed that many authors will recommend that you use a plenum version of the cable. This means: Use a FEP or Teflon coated wire. (I even saw one state that it is a waste of time to use anything else.) This kind of isolation is mainly used in USA. Usage is discouraged in Europe, because the resulting gases when it burns (in an established fire) are toxic. For this reason, this kind of cable is difficult to obtain in Europe. Don't worry, the geometry of the cable is very important, so use the ordinary kind, which is covered with polyolefin (an excellent dielectric, even though Teflon may be better). If you still think you will get better results with the plenum kind (and you can obtain it), be aware of the fire hazards of using Teflon.
et le polyolefin c'est quoi ?
langmc
Inscription Forum: 01 Mai 2003 17:12
Message » 31 Aoû 2003 19:18
je viens de faire un tour sur le site de John Risch, c'est pas la joie :cry:
-Inner Conductor Insulation-
In descending order of preference:
Foamed Teflon (TFE)
Solid Teflon (TFE)
Foamed FEP Teflon
Solid FEP Teflon
Foamed Polypropylene
Solid Polypropylene
Foamed Polyethylene
NOT RECOMMENDED FOR SERIOUS AUDIO USE AT ALL:
Solid Polyethylene
Rubber
PVC (Polyvinylchoride)
Polyurethane
-Shield Materials-
In descending order of preference for coaxial cables:
Bare copper
Tinned copper
Silver plated copper
Foil
effectivement, ce qui paraissait terrible à premiere vue est peut etre douteux :-? Bon coeur mais isolation et shield pas terrible
00940
Message » 31 Aoû 2003 20:15
Espérant me faciliter la vie, j'ai essayer de faire bruler les bouts de brins en téflon plutot que d'avoir à les dénuder un par un...
Bide total même avec une falmme de briquet pendant plusieurs minutes !! Je confirme que le téflon est très sérieusement ignifuge...
ogobert
Message » 31 Aoû 2003 20:32
ogobert a écrit:> because the resulting gases when it burns
Sauf peut-être lors d'un incendit, mais c'est rassurant que tu ai fait le test :lol: :lol:
langmc
Message » 31 Aoû 2003 20:53
tant pis, fichu pour l'argent solide sur le coup. :evil:
Retour au classique, qqn a testé le Fine silver de Venhaus ?
7.5m de cable argent (awg32, pur à 99.99%) pour 32$, qqes rouleaux de teflon, une corde de coton, des plugs rca dayton à 11$ le set de 4, de la soudure Kester à l'argent et voila :)
a peu pres 30€-40€ pour une paire de 50cm
00940
Message » 31 Aoû 2003 21:21
si le teflon bruler, il y en aurrait il au fond des poele ?
phill
Inscription Forum: 15 Jan 2003 22:59
Retourner vers DIY - Divers
