Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: fiscal et 49 invités
UGS - Muse edition
OK je teste, merci Alex
- patroussea
- Inscription Forum: 25 Fév 2009 12:30
Balanced output, signal out on both phases ?
Hi all
Have anyone measured that they have signal out on both phases on the balanced output ?
I have NOT (signal on both phases), and we are now debugging this. Alex ,are you sure the code for the Muse volume chip is correct ?
Salut à tous
Est-ce que quelqu'un a mesuré qu'ils ont signalé sur les deux phases sur la sortie équilibrée?
Je n'ai PAS, et nous débarrassons maintenant de cela. Alex, êtes-vous sûr que le code de Muse volume chip est correct?
[img]http://s560.photobucket.com/user/Ultimate_photos/media/debugging_1.jpg.html?o=0[img]
Johnny
Salut à tous
Johnny
- Ine
- Inscription Forum: 02 Fév 2016 10:53
HI Alex
I haven´t seen anything on the Wifi board, have you written software for it ? or is this for later ?
Carlos
Carlos
- CeeVee
- Inscription Forum: 23 Juin 2017 1:25
Hi Johnny,
Is it after I fix the issue with your specific power supply?
On my UGS both phases are working, I have measured this long time ago and will not be able to double check now as I am out of Taiwan till mid of July.
But I don't see why it would not work now.
Hi Carlos,
No, I did close to nothing on this, I just ported the module driver provided by TI in the UGS Muse software environment but did not build any application based on this.
It was more for the case when the board is used in a DAC with WiFi audio streaming, on the preamp it has limited interest.
Do you have anything specific in mind? What is the use case you want to see here?
Hi Carlos,
- Alex_twn
- Inscription Forum: 10 Nov 2008 6:02
Hi Alex
The fix with the 2 sec. delay of sending the commands to the Muse chip in software works perfect with my heavy powersupply. Both phases starts up every time I power it up. Thanks a lot !
Johnny
Johnny
- Ine
Balance adjustment with remote ?
Hi.
Anyone got the balance adjustment working with the remote control ?
I have been through all the firmwares, but never got this adjustment to work with the remote control.
Alex ?
Google translate:
Salut.
Quelqu'un at-il obtenu l'ajustement de l'équilibre en fonction de la télécommande?
J'ai traversé tous les firmwares, mais je n'ai jamais eu cet ajustement pour fonctionner avec la télécommande.
Alex?
Johnny
Alex ?
Google translate:
Salut.
Alex?
Johnny
- Ine
Hi Johnny,
I just checked the code and you are right.
Everything is already there for what concerns learning the code and assign it to a remote control button, but then during preamp utilization I forgot to add the decoding of those programmed keys in the main state machine... .
So when you press the button nothing happens then.
Pretty easy to do, not a big deal, I'll do this when I have a bit of free time.
- Alex_twn
Hi Alex
Thanks ! I will need a vers.with a 2 sec.delay of the start-up, as you know. Hope you can incorporate that too in the new vers. (for me) ?
Johnny
Johnny
- Ine
Alex_twn a écrit:Hi Johnny,
Hi Alex
Had any time to do this fix with the balance control ?
Kind Regards
Johnny
- Ine
Bonjour Alex, bonjour tout le monde,
J'ai continué à suivre vos exploits depuis le début, je pense que vos réalisations sont à la hauteur de ce beau projet.
Pour ma part j'étais gonflé à bloc, mais après avoir participé à la CG les aléas de la vie ne m'ont pas permis de passer aux choses sérieuses
Comme je ne prévois pas d'amélioration, je vais mettre en vente les kits qu'Alex m'avait fait parvenir et qui dorment dans un tiroir.
Je propose donc:
2 kits complets (n°1) à 65 € pièce
1 kit n°3 (UC board) à 9 €
2 kits n°5 (modules UGS) à 6 € pièce
Ce sont les prix de la CG, j'offre le port en France métropolitaine.
Quoi qu'il en soit je vais continuer à suivre vos réalisation...
Je propose donc:
- Farfe
- Inscription Forum: 05 Nov 2006 13:50
Salut Farfe,
As tu vendu ton kit?
- Alex_twn
Va falloir que je sorte la bestiole de son carton...
- beb
Bonjour a tous,
J'ai 2 gars sur DIY audio qui cherchent des kits PCB.
Il y avait des personnes qui ne voulaient plus aller au bout, si vous voulez vendre c'est le moment.
Envoyez moi MP, merci.
- Alex_twn
Je songe à faire un UGS Muse multicanal mais il me manquerait au moins 2 cartes-mères et 2 modules UGS. Donc si quelqu'un d'autre aurait possiblement un ou deux kits PCB à vendre je serais preneur.
- PaulM
- Inscription Forum: 16 Nov 2008 3:42
J’ai ressorti les PCB du placard (il est jamais trop tard ) mon souci c’est que les booms ne sont plus à jour principalement des résistances et des condensateurs. Vue mon inexpérience dans le domaine quelqu’un pourrait-il m’aider pour savoir quelle caractéristique sont important afin de trouver une ref de remplacement.
Il y a aussi le TPS7A4901 du preamp boards (ref mouser 595-TPS7A4901DGNR)
Bon WE,
terjos
Bon WE,
terjos
- terjos
- Inscription Forum: 25 Fév 2006 15:37
