JPforU a écrit:Bonsoir. Que vaut-il par rapport au HD 598 ? L'un de vous a t'il pu les comparer ?
N'ayant pas trouver de comparaison directe entre le deux casques, l'on peut transiter le différentiel par un casque intermédiaire comme le HD599.
Le site Ratings.com a comparé le HD598 avec le HD599 et la conclusion est :
"The Sennheiser HD 599 are marginally better audiophile headphones than the Sennheiser HD 598, but both are great for neutral sound and you may prefer either. They're nearly identical in terms of comfort and build quality. The HD 599 sound a bit better, with a less underemphasized bass response, but it's a small difference and may not be noticeable for all listeners. The HD 599 also seem to isolate the wearer better than the HD 598, but neither of them isolate you from very much noise since they’re open-back headphones. "
Ils ont également comparé le HD599 avec le HD560S et la conclusion est :
"The Sennheiser HD 599 and Sennheiser HD 560S are closely-matched in regards to neutral sound. The HD 599 are more comfortable, have a better-balanced treble range, and a more spacious soundstage. The HD 560S offer a more stable fit, a more neutral bass and mid-range, better stereo imaging performance, and demonstrate slightly less distortion at high volumes."
