Sennheiser HD 4.50 BTNCIn terms of sound, they are good, well balanced and clean. The ANC is also good for the price. However, they are not very comfortable, and every single head movement tends to break the seal between the cushions and your head, which as you would imagine is quite disturbing as it lets a lot of outside noice in. Also, theres this weird thumping of your footsteps when you walk, this is to do with the ANC, almost all ANC headphones have this... the only pairs which dont have this issue are beats studio 3, sony ch700n and the XM series. The HD 4.50 also do not go very loud
reversephonelookup.onl/ curated.onl/nba-reddit/ pcbuilder.onl/pcpartpicker/.
I would definitely recommend the sony ch700n for that price. They all round better. They go very loud, the ANC does not make that annoying thumping with every step you take, and they sound very clean with punchy bass. The seal of the cushions is not perfect but better than the Hd 4.50, and they are also far more comfortable.
If you are willing to spend a bit more, then definitely get yourself the Sony 1000XM2. They are regularly on sale not that the XM3 are out, and are still the 2nd best ANC headphones I’ve owned, and I’ve owned pretty much every top end ANC headphones at some point. And if you wanna have the best possible ANC headphones money can buy, the XM3 are a no brainer.
Hope that helps.
