b]Type :[/b] Caisson de Basses
Marque : Velodyne
Model et options : HGS 10
Prix de vente : 950 euros
Département où la marchandise est visible : 59
Montant des frais d'expédition : a négocier
État de la marchandise : Très bon
Première main : non
Prix neuf : 1499 dollars
Facture disponible : non
Date et lieu d'achat : elecson
Numéro de série : je peux regarder à la demande
Site web du constructeur :
Commentaires : Le HGS 10 est un DD 10 sans systèmed 'équalisation. Une sacrée référence quand même, non ?
Liens divers : http://www.hometheaterhifi.com/volume_4 ... hgs10.html
http://www.holtmods.com/hgs-10.htm
VELODYNE HGS-10 -- Enjoy the full lower extension of Digital Audio with this high impact, extraordinarily musical subwoofer. This unit generates less than half the Distortion of conventional motor designs, with of four times the heat dissipation.
High quality crossover system -- allows seamless integration with the most demanding full range speakers
Switchable subsonic filter -- allows adjustment for either audio with low Bass extension or dynamic Home Theater bass presentation -- at the flick of a switch
Optional Infrared remote control allows adjustment of bass Output from one source to another
Volume control for perfect integration with any speaker system
Adjustable low-pass filter offers hook-up flexibility for all equipment
Subwoofer Direct optimizes installation for the latest digital Surround equipment
Subsonic filter maximizes subwoofer performance for audio or Video use
Phase adjustment optimizes performance with different speakers and locations
Amplifier: 1250 Watts continuous; 3000 peak
Woofer: 10" forward firing
Voice Coil: 3" Dual Tandem push-pull
19.3 magnet
High Pass Crossover: passive 80/100Hz (6dB/octave)
Low Pass Crossover: 40Hz - 120Hz
Anti-clipping
Line & Speaker Level Inputs & Outputs
Frequency Response: 20--125Hz +/- 3dB
11 ½" (h) x 11" (w) x 11" (d)
Weight: 45 pounds
35 messages • Accèder à une page • 1, 2, 3
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Amra et 23 invités
mais... pourquoi?
- pierrelenhardt
- Inscription Forum: 19 Mar 2004 12:10
pour acheter 2 cht r 12
- Asmodeth
- Inscription Forum: 10 Juin 2000 2:00
Asmodeth a écrit:pour acheter 2 cht r 12
tu vas avantager la puissance au contrôle alors
- ashram
- Inscription Forum: 08 Juin 2001 2:00
Disons que j'aimerais essayer une solution avec deux caissons et si j'avais les moyens d'avoir 2 hgs 10, je ferais de bon coeur..... LE HGS 10 est incroyable au vu de sa taille, je retrouve les nappes de grave et la puissance d'un Omega 380 mais avec beaucoup plus de discernement dans les notes..
Parexemple sur le demo DTS 7 , mon test préféré est l'impact des pistolets soniques sur Minority Report, avec la magnat , ça pétait grave mais avec le velodyne, ça pete grave mais en plus j'entends une deuxième resonnance de ce coup de semonce que je n'avais jamais entendu avant. LE HGS 10est rapide donc il permet d'enchainer les notes et les distinctions dans le grave.
- Asmodeth
A mon avis tu devrais plutôt acheter un deuxième HGS!
- Ulysse21
- Inscription Forum: 28 Oct 2002 12:10
ou essayer un DD12!
- pierrelenhardt
Asmodeth a écrit:Disons que j'aimerais essayer une solution avec deux caissons et si j'avais les moyens d'avoir 2 hgs 10, je ferais de bon coeur..... LE HGS 10 est incroyable au vu de sa taille, je retrouve les nappes de grave et la puissance d'un Omega 380 mais avec beaucoup plus de discernement dans les notes..
Tiens c'est marrant ce constat je l'avais fait lorsque j'étais passé de mes cabasse MT360 à mes FPM 4 (je n'ai pas de caisson de grave). Comme quoi ces petites FPM sont pas mal.
- fango
- Inscription Forum: 15 Mar 2004 0:27
Bon sinon un HGS10 à 950 euros c'est intéressant. Les dimensions en cm c'est combien ?
- fango
25 cms sur 25 cms sur 25 cms.
Bluffant non
Bluffant non
- Asmodeth
Euh.. on paie en dollards chez Elecson maintenant ?
Ce serait plus correct de mettre le prix neuf en Euros
- Keron
Keron a écrit:Euh.. on paie en dollards chez Elecson maintenant ?
Ce serait plus correct de mettre le prix neuf en Euros :mdr:
Lors de sa sortie ce caisson etait vendu 2400 euro et 1900 en fin de vie.
Gil
- gil2b
me suis dit la meme chose, elecson accepte les dollars?
un bien beau caisson en tout cas...
- ranix
- Inscription Forum: 17 Déc 2003 21:53
Oups, j'ai copié collé la description sans faire gaffe. Merci de la correction
- Asmodeth
35 messages
• Page 1 sur 3 • 1, 2, 3
