![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
/HS
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 3 invités
This is a review of the HMZ-T1 based on about 4 hours of use with a variety of materials.
The quick-start booklet that comes with the HMZ-T1 mentions 4 steps to get going
1) Connect
2) Wear
3) Set-up
4) Enjoy
So I will follow the same flow and discuss each point in some detail.
Before we start, in the box there is
1) The glasses with a permanently attached 11 foot cable. The connector is proprietary and therefore I don't believe it would be easy to extend
2) An HDMI control unit with country specific power cord. This has an HDMI in, out (acts as a through), figure of 8 power connector (the power supply is integrated), and the connector the glasses. There are 2 LEDs on the front. One indicates power/standby (green/red) and another indicates pass-through is active (orange)
3) An HDMI cable. You will need this extra cable, to "insert" the control box into your chain with your current TV.
4) Accessories. These include 3 forehead pads (medium already fitted), a forehead pad cover (a nicer material especially if you are prone to having a sweaty forehead), cable tidy clip (to help the cable feed nicely from the glasses), a headmount strap tightener (more on this later), a pair of rubber light-blockers (that fit to the lower part of the glasses to help eliminate intruding light from the room
5) A colour start-up guide and a black and white reference guide. There is also a sheet of paper to help those with a PS3
The glasses are a mix of glossy white and matt black plastics. Although the plastics feel solid enough, you will probably feel nervous holding one as its clearly a fragile technology that should not be dropped! With the headbands, speakers and lenses, it is difficult to first determine how/where to hold it! There are buttons on the glasses for left, right, up, down, Menu/OK, Volume up, volume down, and power (which you need to hold down for a couple of seconds to activate)
CONNECT
The first step is to get the source media linked up to the control box. Most people will already have a PS3 or blu-ray player connected directly to a TV or an AVR. Fortunately you do not need to go out and buy HDMI switchers or another PS3. The control box has an HDMI "pass-through" capability. This feature can be switched off to reduce power consumption. If you have a PS3 connected to a TV, simply unplug the HDMI connector from the back of the TV and insert to the IN on the HMZ-T1 control box. Then using the provided HDMI cable, use the OUT to connect to the TV. The control box is intelligent. If the glasses are on, the signal is cut from the TV and fed to the glasses. As soon as the glasses are switched off, the signal returns back to the TV.
For those with very technical set-ups, you will be pleased to know that the pass-through is bi-directional supporting features like ARC (Audio return channel) and HDMI control. If your TV is also a 3D device, the source is able to still detect this capability in your TV and correctly continue to feed it 3D signals as well.
Finally connect the long glasses cable and power lead and you are ready for the next step.
WEAR
This is the bit that sounds easy but turns out to be the most frustrating aspect of the HMZ-T1. Due to the design of the glasses, setting them fit your head is VERY personalised. This means if friends or other family members want to use it, you will probably be tempted to say no, as you will mess up your own set-up, and spend ages finding the correct set-up for someone else. This also means this is not a "glory piece" in your home to show-off to visitors.
There are primarily 5 adjustment points
1) Head-strap upper band
2) Head-strap lower band
3) Head-strap extension adjustments on both sides
4) Forehead pads and adjustment position
5) Ear-piece alignment
I found the starter guide to be VERY poor in explaining how to get the headset well aligned despite it being printed in colour. The first step is to fully extend the head-strap using two little push buttons on either side of the headset and pulling the bands fully out. The headset is not supported at the top of the head, but instead at the back of the head with the forehead rest at the front. Novices will most likely start with the head bands positioned too high up on the head. The first thing to get right is to get the lower of the head bands as low as the indent at the back of your skull. The upper headband then sits at 45 degrees, at the back corner of your head. Both head bands are adjustable and you may want a family member to help you unclip, adjust and re-clip. I found that I ended up with the lower head band almost fully tightened, and the upper head band mostly opened. If you find the lower head band is not going tight enough, there is an extra clip that forces the band to tighten further.
At this point, the unit will still not still well. that is because we now need to tightened the headband against the unit at the two sides. This is done by simply forcing the headband into the glasses which results in a click/lock/click/lock behaviour. If you over-tighten, simply press the little buttons on the side of the glasses to release the headband. It is advisable to loosen the headband using these buttons every time you put the glasses off and on. There are three forehead pads. The default is the medium pad. The idea is that the weight is distributed between the forehead pad and the headband straps. Your nose should NOT be supporting the weight.
Depending on the depth of your skull, you will need to experiment with the forehead pads. Generally the smallest pad will give the best image (more on this later), but may not work for everyone's head. For my own head, I need to use the medium pad. When the pad and straps are correctly set-up, the glasses will sit dead horizontal on your head. A problem I found is that when the glasses are horizontal, although the weight is not on my nose, my nose is compressed by the unit. An apology for stereo-typing, but it seems the glasses have been designed in Japan for more typical Asian features with noses that are less tall than westerners. This makes the glasses a tad uncomfortable, but when you get absorbed into viewing, you can put it out of your mind. Using a deeper forehead pad helps with this, but has consequences on image quality (more on this below).
Finally, the ear-pieces can be adjusted in and out and up and down so that they sit nicely over your ears.
SETUP
Finally, after a lot of fiddly set-up, we can power on the glasses for the first time. The first time the glasses are switched on, it will ask you for your language choice. It will also ask you if you want to activate the HDMI pass-through. It will not ask these questions again. However the next screens I describe will appear every single time. A test screen then appears with the word "Welcome" in large letters. This image may be out of focus for 2 reasons.
1) You need to adjust the inter-ocular distance. There are little sliders under each eye piece that shift the eye pieces further out or closer together. You have to move both sliders together (i.e. slide both outwards together, or inwards together). This should help bring things into focus. For me, I had to slide them as far apart as possible. I don't have unusually wide-spaced eyes, so I can imagine some people might have a problem with the maximum adjustment
2) The glasses are not positioned low enough down your head. This is where you need to go back to the "Wear" stage and fine tune the position of the glasses so that the whole image comes into focus.
If you are using the deeper forehead pads it may not be possible to get the whole screen perfectly in focus. You may find the sides are a little out of focus even though the centre is sharp. If you find one side is in focus and one is not, then moving the headset slightly left or right should help. You may have to accept a compromise. Additionally the deeper forehead pads will push the glasses further away from your face which may allow more light leakage from the room, particularly at the top. The light blockers only fit to the bottom of the glasses.
After the welcome screen, pressing the Menu/OK button on the bottom of the headset will move to the next screens which describe a diagnostic test to ensure the glasses are safe to use. The left eye will contain an image with a white line running from left to right. The right eye will contain and image consisting of 3 letter I's like this "I I I". Your brain will then merge the two images. You should see the line intersecting the letter Is. If they do not intersect the glasses are not safe to use as it can cause eye-strain/headaches and nausea. The line may not be perfectly straight, or directly through the middle, but as long as it intersects all three Is then it is okay to use. Mine was perfectly through the middle.
The final screen that appears is a safety warning about prolonged use of the glasses.
Now at last(!) we are ready to actually watch some material on the HMZ-T1
ENJOY
The primary reason for writing such a detailed report on setting up was to help those that may not have received theirs yet and will want the best hints/tips to get started. For those thinking about purchasing still, or have a pre-order they can cancel, this section is devoted to giving my personal opinions on the video and audio quality of the HMZ-T1.
So we have seen the HMZ-T1 advertised as a 750" screen from 20 metres away, or a 150" screen from 12 feet away. In fact you could calculate a whole range of numbers in-between that have the same field of view (45 degrees). However, my personal evaluation suggests that it is NOT the same. When you are in a big IMAX cinema, you are aware of the distance between you and the screen due to other seats, people, speakers or other objects in the room. When I wear the glasses I do not have any objects in my vision to relate to, and the impression I get is of a very large screen but more like 12 feet away. I have found depending on the material being watched, it sometimes does feel even larger than 150" as if I am being nearly consumed by the image. Whatever the case, it does not feel like a tiny 0.7 inch panel 2cm away from my eyeballs. I think many will be impressed with the vastness of the image experienced. However an absolute MUST is to watch without outside light influences. The illusion of size is broken by this and may explain some unhappy viewers who have seen these units at brightly lit shows and stores.
The HMZ-T1 uses OLED panels and it definitely shows! Blacks are almost perfectly black. This means if you watch 21:9 movies, you will not be distracted by the black bands top and bottom. In fact, strangely, the screen seems even larger due to the aspect ratio. Colours are vibrant and the detail is most definitely there. Although the panels are 720p, I do not find myself wishing for greater resolution. If you study hard on certain colours you may "just" be able to make out the pixel grid. But it requires concentration and would not be noticed while watching material. There are picture adjustments and presets (e.g. cinema), but it is hard to validate the accuracy of these as it will not be possible to colour calibrate the display with any equipment. Overall, with minimal adjustment, I was able to get a picture that looked very cinematic with accurate colour.
Playing first person games in 2D such as Call of Duty MW3 looks anything but 2D! Incredibly as the image occupies so much of your vision, your brain is partially fooled into believing you are right there in the game. I then tried Wipeout HD on the PS3 in 2D. I was amazed at how 3D things looked as I hurtled along the race track at high speed. Wipeout should be played with the 1st person viewpoint for maximum effect. I then switched to 3D and there was significant further enhancement. It is important to understand these games add depth and not pop-out. But this extra 3D layer drew me further into this virtual world. In fact, and rather embarrassingly, I found myself uncontrollably tilting my head as I went around corners. Anyone who suffers motion sickness may struggle playing these games for a long duration. I was not aware of any intrusive lag during games.
I then tried a few 3D movie titles. I could certainly see the added depth. Where I struggled a bit more was appreciating those titles which have "pop-out" effects. A few other owners of these glasses have commented that they see less pop-out than in a cinema, or home projector, or even their TV. Surely the opposite should be true, as these glasses can display 3D with zero crosstalk and high brightness and contrast. I believe there is an inherent limitation here and I will try to articulate my current thinking. When we watch in the cinema, the objects coming out of the screen effectively occupy our real-world space. This space is filled with people, chairs, tables, curtains or speakers. In these use cases, you have a frame of reference to associate with. However, when using the glasses, you are in a void. So when an object is designed to pop-out towards you, you have less to associate that with. I found that very large objects such as the famous Cod fish in "IMAX Under the Sea" do pop-out very convincingly. With smaller objects, by the time your brain can process it and compare it to the screen edges to see there is a difference and go "Wow, pop-out" it is too late. However I did find that if I periodically looked at the screen edge and back to the pop-out object, that the effect snapped into place. So this is more of a perception issue and probably varies from person to person. I still think the HMZ-T1 does a very good job with 3D, but may not provide the thrill factor some were hoping for. This is not due to a poor 3D implementation, but simply inherent in the design of any glasses like this. This is still not the IMAX cinema replacement some might wish for.
The sound was better than I expected. It simulates surround quite convincingly and the frequency range and clarity is impressive. Watching a movie or playing a game were equally good with an immersive full-range sound with a certain level of surround experience. It won't achieve gut wrenching bass as the speakers sit loosely over the ears. Unfortunately there isn't an easy way of connecting your own earphones.
CONCLUSION
This was originally introduced as a proof of concept product. That is exactly what it is. It delivers impressive images and sound. However it is not the most comfortable thing to wear for long periods and could do with further refinement for different head shapes. It can only be used tethered and so is not really portable. To adjust it to fit someone’s head is complex enough that you will not want to share it with friends and family. However, for the selfish individual who wants to go into their own world, and watch a virtual massive screen for gaming or a movie will not find any other products even remotely close to it. I have a pair of the latest Vuzix glasses here, and while they are portable and comfortable, the image difference is like chalk and cheese. Some may prefer to wait for another iteration of this product, if Sony continue to invest along these lines. For those hoping to have the ultimate 3D experience, this isn't it. You will still need to go to an IMAX cinema, or create the largest home cinema with projector that you can afford and find space for. 3D is solid on the HMZ-T1 and many will be very satisfied with its performance, particularly with zero crosstalk, high brightness and stunning contrast. However, due to the way the brain perceives it, for 3D "pop-out" junkies, your brain will not always be able to realise/process this to the same extent as in a real room. Although I do not believe the image feels like watching a 750” IMAX screen, the 45 degree FOV often manages to put you inside the action, even in 2D.
djaret a écrit:Bonjour,
Merci à macgillian993 pour sa réponse rapide, je pense que je vais annuler ma précommande, car j'ai majoriterement du divx à regarder, bcps de series et en hd, c'est trop lourd, dommage.
macgillian993 a écrit:...Par contre pour la 2D (HD bien sûr) le résultat est excellent. (et c'est frappant en passant de 2D à 3D sur un film par exemple, on voit qu'on ne perds pas de luminosité en 3D, c'est bluffant.)
manuxs a écrit:Y a un truc qui me stresse un peu quand même.
Il est bien précisé dans le manuel que lors de la calibration du casque (premier allumage), il faut faire passer un trait horizontal dans les I
Si jamais, par malheur, on n'arrive pas à voir le trait au milieu des I, c'est que dans ce cas, notre vue ne nous permet pas d'utiliser le casque.
Bon, je touche du bois. Je suis myope mais j'ai des lentilles de contact et je suis bien corrigé.
Mais pour ceux qui seront peut-être confrontés au problème, c'est terrible. Parce que vu que le Sony Store ne reprend pas le casque, qu'est-on censé faire dans ce cas ??
Like others here, I found that switching to the thin forehead pad alleviates the pressure the HMZ-T1 places on my forehead, and gives me edge-to-edge sharpness that I can't get with the medium pad. However, the unit still has to rest low on my nose which I find to be a bit bothersome. I found an effective way to eliminate most the pressure on my nose. I took a small chunk of HandiTak and molded it just above the tip of my nose where the HMZ-T1 would rest. HandiTak is an adhesive, resuable putty made by the Super Glue company, normally used to do things like hang posters and photos on walls. You can find it in any hardware store like Home Depot, and probably Walmart. Only costs a couple bucks. It's odorless and easily comes on/off the nose. The HandiTak acts as a nice cushion, alleviating much of the pressure on nose. Definitely give it a try if you're finding the pressure on your nose to be bothersome.
upsilandre a écrit:c'est un test de disparité vertical, ca sert a mesurer la qualité de l'assemblage
Retourner vers Accessoires Divers
