Size (inch) 47 inch / 42 inch
Analog Terrestrial Yes
Display 8 ms S-IPS LCD with EEFL Backlight
S-IPS 1080p LCD panel med 120Hz (Pal 100Hz)
Picture Format 16:9 WideScreen
Resolution 1920x1080p
Contrast Ratio 1600:1 (Al) Dynamic
Brightness (Cd/m²) 550 cd/m²
Panel Mode 1920x1080, 1366x768, 1280x720, 1024x768, 852x480, 848x480, 640x480
XD Engine XD engine 3
XD Engine Control Auto, Advanced control
XD Engine Control Cinema, On/Off
XD Engine Control Black level, Low/Mid/High
XD Engine Control XD Contrast On/Off
XD Engine Control XD Colour On/Off
XD Engine Control XD Noice reduction
XD Engine Control MPEG NR 1-10
Cinema 3:2 mode (natural motion) Yes
Enhanced Line Doubler Yes
Auto Booster (Analog) Yes
Color Reproduction Electronic part: 14 bit
Supported Signals NTSC,PAL,SECAM,HD 720p,1080i,1080p, VGA~UXGA
DCDi Yes
PIP (Picture In Picture) Yes (Two Tuners)
Split Screen (Double Window) Yes (Two Tuners)
POP (1 3 Pictures) Yes (Two Tuners)
Component (Y/Pb/Pr) 1 (480i/p,576i/p,720p,1080i/p)
HDMI Input 2
Power Consumption 47LB2RF: 310W / 42LB2RF: 250W
WxHxD (mm) with Stand 47LB2RF: 1280x828x315. 42LB2RF: 1175x768x300
WxHxD (mm) with out Stand 47LB2RF: 1280x719x137. 42LB2RF: 1175x670x144
Weight (Kg) with Stand 47LB2RF: 64,24. 42LB2RF: 48,2
