LAST NEWS
INTRO
LES BUNDLES
VPC
LES FIRMWARES
LES TELECOMMANDES
FAQ BBK
SETUP LECTEUR
DIVERS
NEWS (Historique)
_______________________________________________________________________________
** LAST NEWS **
28/11/06
- Dernier Firmware 0919_4 pour le BBK OPDV971H-E avec téléc Black-blueish usa style
Info:
http://www.livingcinema.nl/phpBB2/viewtopic.php?t=114
Dwnld:
http://www.livingcinema.nl/public/bbk/2 ... 0919_4.iso
Modifs:
all improvements from last firmware:
1. Improved handling of "forced subtitle" for DVD discs
2. Improved disc compatibility
3. Improved audio/video synchronization (previously included in the F-0316 beta firmware)
4. Eliminated Chroma Up-sampling Error (CUE) for component output
5. Improved resume play function
6. Improved DivX video playback functions
7. Output resolution display
8. Enhanced front panel dimmer control
9. Skip function for digital music files
It seems subtitle sync to frame is a little better.
Problème:
.. zoomindicator does not go away
22/09/06
- Petite relase de Fw de OppoDigital :
MVer: 05.00.01.07 Batch: 11-0830, 11-0830B and 10-0821B
Release Date: September 22, 2006
Summary of Changes in This Release:
* This release addresses a rare occurrence of no center audio channel output through the 5.1ch analog audio output. It also includes all new features and improvements from the 10-0720 major release version.
* The above three batch numbers are equivalent firmware releases used at different stages of production.
Fil sur Oppodigital:
http://www.oppodigital.com/opdv971h_firmware_0830.html
Download:
http://www.oppodigital.com/Download/Fir ... 1-0830.iso
26/08/06
- LC a modifié le firmware 0720 pour aller avec la Black fat remote
(en enlevant la compatibilité Black blue-ish usa style remote du Fw. 0720)
Download en Nero image:
http://www.livingcinema.nl/public/bbk/2 ... 0720_3.nrg
Fil sur LC :
http://www.livingcinema.nl/phpBB2/viewtopic.php?t=70
Modèle de télécommande concernée:
http://www.livingcinema.nl/public/bbk/1 ... blacks.jpg
- Oppo Digital USA a sorti un Fw 0720
(Telec Black blue-ish et Silver)
(Cf section Firmwares)
Info Oppo:
** INTRO **
Le fabriquant chinois BBK a sorti fin 2005 2 produits :
- BBK DV971-H pour l'europe
Oppo OPDV971-H pour les US
- D'une télécommande différente (dans son look ses touches, son firmware et ses codes)
D'une prise SCART supplémentaire sortant au choix, soit du RVBS soit de l'YUV
D'un frmware adapté à sa télécommande et à sa sortie SCART (même si les moins récents des Fw. Oppo, sont OK)
D'une prise d'alim au normes CEE
D'un bundle différent (câbles DVI )
ATTENTION :
Depuis Mars 2006, les Oppo Cee (Ex BBK) sont désormais dénommés OPDV971-H-E et livrés par Living Cinema Hollande, avec la même télécommande Black Blue-ish que les Oppo livrés par Oppo Digital USA
** Les BUNDLES livrés avec le lecteur **
LC Hollande 30/04/06 (Merci à cricri49 et à gbaya)
- 1 câble DVI/DVI de 1m50 environ
1 câble Vidéo composite (rca)
1 câble Audio stéréo analogique (rca)
1 Télécommande modèle "black blue-ish" ou "black fat" selon les packages
2 piles AAA
1 manuel utilisateur Anglais/Hollandais
nb1: Fiche d'alim. du lecteur : 2 pôles, norme Cee
nb2: Alimentation 110/220 auto
nb3: Firmware 0302 ou plus ancien (à upgrader) , selon les packages
1 câble DVI/HDMI de 1m50 environ
2 piles AAA
nb1: Fiche d'alim. du lecteur : US (prévoir un simple adaptateur US/EU à
1,50€ chez Bricomerlin)
nb3: Firmware US OP971-F-0302
** Les BBK / Oppo en VPC **
France
Pas de VPC ni de revendeur officiel
Hollande : Living Cinema
http://www.livingcinema.nl/catalog/prod ... cts_id/168
UK : CRTprojectors
http://www.crtprojectors.co.uk/dvd_players.htm
Suede : BBK (Importateur central pour la Cee)
http://www.bbkes.se/
Allemagne : Pipro
http://pipro.de/oppo_opdv971h.htm
Finlande : Mareks
http://www.mareks.fi/?p=productsMore&iProduct=41
USA : Oppo Digital
USA : Extreme Phono
http://www.extremephono.com/Oppo_DV971.htm
USA : HKFlix
http://www.hkflix.com/hardware/xq/asp/p ... etails.htm
** Les FIRMWARES du BBK **
Les Firmwares OFFICIELS
Nb: Les télécommandes sont livrées avec le paramétrage "New RC"
La Manoeuvre de passage New RC -> Old RC (Changer la table de codage IR de la télécommande) est décrite plus bas, au chapitre "FAQ BBK"
Oppo Digital USA. http://www.oppodigital.com
- OP971H-D-1022 (25 oct 2005)
Remote :
New RC: Silver
Old RC : Black US model 1
Infos:
http://www.oppodigital.com/opdv971h_fir ... nload.html
Release notes:
http://www.oppodigital.com/opdv971h_fir ... _note.html
Download:
http://www.oppodigital.com/Download/Fir ... d-1022.iso
OPDV971H-1111b (22 Nov 2005)
Remote :
New RC : Black Blue-ish
Infos:
Release notes de la 1111b :
Dwnld:
http://www.oppodigital.com/Download/Fir ... -1111b.iso
OP971H-F-0220 (27 Fevrier 2006)
Remote :
New RC : Black US model 1
Old RC : Silver
Infos :
http://www.oppodigital.com/opdv971h_support.html
Release notes:
Dwnld:
http://www.oppodigital.com/Download/Fir ... f-0220.iso
OP971H-F-0302 (8 mars 2006)
Remote :
New RC : Black blue-ish
Old RC : Silver
Infos:
Release notes:
Dwnld:
http://www.oppodigital.com/Download/Fir ... f-0302.iso
OP971-F-0316 (18 mars 2006)
Remote :
Old RC : Silver
Infos :
Release notes:
Download:
http://www.oppodigital.com/Download/Fir ... f-0316.iso
971h-10-0720 ( 28 juillet 2006)
Remote :
Old RC : Silver
Infos :
http://www.oppodigital.com/opdv971h_firmware_0720.html
Fil sur LC :
Download:
http://www.oppodigital.com/Download/Fir ... 0-0720.iso
971H-11-0830 ( 21 Septembre 2006)
Remote :
Old RC : Silver
Infos:
Download:
Living Cinema Hollande. http://www.livingcinema.nl/
Forum des upgrades des Fw:
http://www.livingcinema.dnsalias.com/ph ... a225dbbc5c
AVERTISSEMENT : LC conseille fortement aux utilisateurs de BBK et de Oppo-E commandés chez eux, de n'utiliser que le Fw publiés par LC et ceci, pour éviter des problèmes
- OP971-D-1022 (25 oct 2005)
Remote :
New RC : Silver
Infos:
http://www.livingcinema.dnsalias.com/ph ... 43c5ccae14
Release notes:
Download:
OP971-H-0917 (19 dec 2005)
Remote:
New RC : Black model
Old RC : ?
Infos:
pour OPDV971H-E livrés après le 19/12/2005, à télécommande noire
(attention : ce n'est ni la black blue-ish, ni la black fat) ???
Dwnld:
http://www.livingcinema.nl/public/bbk/0 ... 1H0917.iso
OPDVH-E 1226 (26 dec 2005)
Remote :
New RC : Black Fat Cee remote
Old RC : ?
Infos:
Notes from LC:
for users receiving the OPDV971H-E after 19-12-2005. (but < 17-01-2006)
Downld:
http://www.livingcinema.nl/public/bbk/1 ... E-1226.iso
OPDV971H-E-1226 (19 jan 2006)
Remote:
New RC:
3 different models (Silver, Black fat, Black blue-ish)
Infos:
Notes from LC:
All Oppo OPDV971H-E players shipped after 17 Jan 2006 have 1226_4 firmware installed.
Dwnld:
1226_2 pour BBK OPDV971H-E silver remote
http://www.livingcinema.nl/public/bbk/1 ... 1226_2.iso
1226_3 for BBK OPDV971H-E new black fat remote
http://www.livingcinema.nl/public/bbk/1 ... 1226_3.iso
1226_4 for BBK OPDV971H-E blue-ish usa style remote
http://www.livingcinema.nl/public/bbk/1 ... 1226_4.iso
Old RC : ?
0220_3 for EU Fat remote (3 Mars 2006 )
Remote :
New RC : Black fat Cee model
Old RC : Silver
Note :
Patch fait par LC, depuis le 0220 de Oppo US
No scart support
Infos:
dwnld:
http://www.livingcinema.nl/public/bbk/0 ... 0220_3.iso
Oppo 0302_3 (10 mars 2006)
Remote :
Old RC : Black FAT Cee remote
Note :
modified by LC from Oppo USA Fw 0302
No scart support
Info :
Dwnld:
http://www.livingcinema.nl/public/bbk/0 ... 0302_3.iso
Cible:
For those that have 1226_3 and experience problems with display on their sony sharp or panasonic, this 0302_3 version will be a benefit.
Note :
After upgrade, region is 1 and remote is blueish. so eject press stop 5 seconds and see "old rc" for region 0 eject> setup> 9210 > 0 > setup
You are all set now, enjoy this firmware with your FAT remote.
OPDVH-E 0315 (09 Avril 2006)
Remote:
C'est une 2e évolution du 0302 US
Info:
http://www.livingcinema.dnsalias.com/ph ... f7d441165f
The 0315 firmware has been tested and is now release to the user.
There is no official release text, but you can assume that all oppo fixes like pal synching on various displays has been improved in this release just like version 0302 from oppo usa.
Your player will show 0315 when you check the firmware number. But you can not see from the OSD which remote you are using, look at your remote
New RC:
Dwnld:
0315_2 pour Silver remote:
http://www.livingcinema.nl/public/bbk/2 ... 0315_2.iso
0315_3 pour Black Fat Cee remote:
http://www.livingcinema.nl/public/bbk/2 ... 0315_3.iso
0315_4 pour Black Blue-ish USA style remote:
http://www.livingcinema.nl/public/bbk/2 ... 0315_4.iso
Old RC : ? Silver ?
OPDV971H O720_3 : Modification du 0720 de Oppo US (28 Aout 2006)
(en enlevant la compatibilité Black blue-ish usa style du 0720)
New RC : Black fat Cee remote
Old RC : Silver
Fil sur LC :
0919_4 (11/06)
New RC : Black-blueish usa style
Old RC :
Fil sur LC:
Dwnld:
Modifs:
Problème:
PIPRO Allemagne. http://pipro.de/oppo_opdv971h.htm
AVERTISSEMENT : Ces Fw sont, d'après LC, des copies issues des FW de LC et sont à réserver aux Oppo-E commandés chez Pipro
- OPDV971H-E1226_x (1er février 2006)
Dwnld OPDV971H-E1226_fb1:
for Black fat Cee remote :http://pipro.de/oppo/fb1.gif
http://pipro.de/oppo/OPDV971H-E-1226_fb1.zip
Dwnld OPDV971H-E1226_fb2:
for Black blue-ish remote : http://pipro.de/oppo/fb2.gif
http://pipro.de/oppo/OPDV971H-E-1226_fb2.zip
Dwnld OPDV971H-E1226_fb3
for Silver remote : http://pipro.de/oppo/fb3.gif
http://pipro.de/oppo/OPDV971H-E-1226_fb3.zip
MAREKS Finlande www.mareks.fi/oppofirmware
- BBK DV971H -1226
Remote :
Silver
Dwnld:
http://www.mareks.fi/oppofirmware/BBKDV ... silver.iso
BBK DV971H -1226
Remote :
Old black and new Black blue-ish
Dwnld:
http://www.mareks.fi/oppofirmware/opdv971h.rar
OPDV971H-3-0315 New RC (9 Avril 2006)
Remote : New Black Blue-ish
Dwnld:
http://www.mareks.fi/oppofirmware/OPDV971H(BES)%20-3-0315(new%20rc).iso
OPDV971H-3-0315 Old RC (9 Avril 2006)
Remote : Old Black Fat
Dwnld:
http://www.mareks.fi/oppofirmware/OPDV971H(BES)%20-3-0315(old%20rc).iso
Les Firmwares NON OFFICIELS
Certains ont hacké les firmwares officiels de BBK/OPPO et proposent leur version
Il va sans dire que cela est sous aucune garantie
- Les Russes
http://bbk985s.narod.ru/oppo971.html
http://www.bbk985s.com/
Avertissement (Source : AVS)
http://www.avsforum.com/avs-vb/showthre ... e=82&pp=30
Extrait:
[color=darkblue]Some russians made modded firmware for oppo 971h.
I just found it at bbk985s.narod.ru
Now I am upgrading my player.
I hope it'll work!
Firmware updates based on OP971-D-1022
OPPO971 v.9
They have no stance, though it does void your warrenty (however, this does not mean that they will not service your unit).
Officially, none of these changes have ever been implimented in official beta firmware.
The only real problem with using the European or hacked firmware is the risk of a bad installation.
If the installation fails at any time, you will not beable to use your OPDV971H anymore until OPPO services it.
Another problem is if the Russian model is using the standard BBK remote, or the one that shipped with the US model.
Why I note this is that BBK uses an entirely different IR Code for their remotes.
If the hacked firmware is using this remote code, you are still out of luck.
One thing I had completely forgot about is missing features. If the MTK hack changed any nodes that are associated with the Faroudja chipset, say by by to your DVI output.
Fw pour le oppo DV971H basés sur le Fw officiel OP971-D-1022
Version ISO OPPO971 v9
Infos:
+ Changed ugly file icons
+ Removed UOPs (prohibited user operations)
+ Pan&Scan mode works for all anamorphic DVD
+ Full width file list browser
+ Changed Audio Setup: Equalizer moved to new page, added Super bass, Bass boost, Treble boost settings
+ Extended SPDIF setup
+ Buttons "|<<" & ">>|" jumps to previous, next mp3.
+ Saves volume level after power off.
download:
http://bbk985s.narod.ru/firmwares/oppo9 ... 971.v9.zip
Version NERO digital OPPO971 vc
Infos:
+ Nero Digital (*.mp4) with chapters and embedded subtitles support.
Download:
http://bbk985s.narod.ru/firmwares/oppo9 ... 971.vC.zip
** Les TELECOMMANDES **
Oppo (US) OPDV971H Black remote
BBK OPDV971H-E black fat remote
ZOOM (217k):
http://montaleigne.free.fr/BBK/PHOTOS/T ... %20BIG.jpg
Oppo US & Oppo Cee (BBK) OPDV971H-E black blue-ish usa style remote
ZOOM (194k):
http://montaleigne.free.fr/BBK/PHOTOS/T ... sh_BIG.jpg
Note: Ceci est la dernière télécommande livrée avec les Oppo Cee de LC et aussi, avec les
télécommandes vendues par Oppo Digital US
Compte tenu que les nouveaux Fw issus des US (Oppo Digital) et de Cee (LC Hollande) sont tous compatibles avec la téléc Black blue-ish, il peut être judicieux de la commander aux US :
Il suffit d'envoyer à OPPO Digital le N° de série de vore Oppo ou BBK et vous recevrez pour 9 € ttc (prix du port) cette télécommande depuis les USA (Paiement par carte Visa ou Paypal)
C'est ici :
http://www.oppodigital.com/proddetail.a ... =971Remote
** FAQ BBK **
FAQ officielles (sur le Oppo-US, mais compatibles BBK)
- FAQ de Oppo-US
http://www.oppodigital.com/opdv971h_FAQ.htm
FAQ de extremephono.com
http://www.extremephono.com/Oppo%20971H ... stions.htm
FORUMS
Francophones sur le BBK
- BBK upgades du Firmware:
http://www.livingcinema.nl/phpBB2/viewforum.php?f=6
BBK infos:
http://www.livingcinema.nl/phpBB2/viewforum.php?f=7
OPPO:
http://www.homecinema-fr.com/forum/view ... t=29791979
FAQ commune OPPO/BBK (Questions sur les points communs)
http://www.homecinema-fr.com/forum/view ... t=29799150
Anglophones sur l' Oppo US
- Topic unique de l'Oppo US:
http://www.avsforum.com/avs-vb/showthread.php?t=482239
FAQ de l'Oppo US:
http://www.avsforum.com/avs-vb/showthread.php?t=491306
Trouver le Firmware de votre BBK
- [Setup] sur la télécommande
tapez 9210 sur la télécommande
Apparition d'un Menu où est écrit la version du Fw
[Setup] pour sortir
Upgrader son Firmware
Faut il installer un nouveau Firmware si on n'a pas de problème ?
- L'Admin. de LC m'a confimé une sage attitude :
I am getting more people with upgrade dead machines.
If it is working DO NOT FIX IT.
- - Troubles constatés (et s'assurer que l'upgrade est bien prévue pour corriger ces troubles là)
- Changement de télécommande
- Release importante recommandée par le constructeur
- http://www.livingcinema.nl/public/bbk/U ... 0steps.doc
(non specif à la version du Fw.)
La procédure de mise à jour, étape par étape
- 1. Graver le Fw sur un CD R ou CD RW (Pas un DVD) vide et neuf, avec NERO ou un autre soft de gravure
(Cf plus bas, la procédure avec Nero)
2. Allumer le lecteur DVD (BBK/Oppo) et sortez le tiroir
3. Mettre le CD du nouveau Firmware et fermez le tiroir
4. Attendez, un message sur l'écran va vous demander de presser la touche PLAY, une fois, aussi, presser la touche "PLAY"
5. Un message d'aide sur l'écran va afficher "FILE COPY”
6. Après la fin de la copie (10 secondes environ), le tiroir s'ouvre tout seul. Sortez immédiatement le CD, ne fermez pas le tiroir, l'OSD va afficher "Waiting, Update…….”
Note: A ce moment là, la mise à jour dure un moment .
N'éteignez pas le lecteur et ne pressez aucune autre touche .
Ne faites rien jusqu'à ce que le tiroir rentre
nb : si vous avez oublié d'enlever le CD, un 2e flashage du Fw se produit; pas grave , mais retour à l'étape 5
7. Attendez, quand la mise à jour est finie, le lecteur DVD va faire un Reset automatique, le tiroir rentre, et après qq instants, l'image réapparait.
NOTE: Durant la mise à jour, n'éteignez pas le lecteur et ne faites aucune autre opération sur le lecteur jusqu'à la fin de la mise à jour.
Si cela prend plus de 15 minutes pour que la mise à jour se finisse .... vous pouvez appeler Houston et dire "Houston, we have a problem.."[/color]
** Précautions à prendre **
- Assurez vous que la version soit compatible avec votre lecteur et votre...télécommande
Gravure du fichier Fw. XXX.bin :
Mode "ISO 9660" dans le soft de gravure (Nero par ex.) et non "Joliet" ou "Data"
CD mono session
Clôture du CD
Vérification des données après gravure
** ATTENTION **
Livingcinema NL m'a signalé qq. retours en SAV de Oppo/BBK morts car erreurs faites lors de l'upgrade de Fw : Alors, suivez la procédure pas à pas !!
LC rappelle de ne pas modifier un Fw qui marche
Toute fausse manoeuvre pouvant bloquer le lecteur et necessitant alors le retour en SAV du lecteur... et ceci n'est pas couvert par la garantie
Source :
http://www.livingcinema.dnsalias.com/ph ... c.php?t=38
NB: Un onduleur de sécurité est conseillé:
Toute coupure de courant durant le process, et ... Game OVER -> retour en SAV !
- Mettre un CD-R ou mieux, un CD-RW dans le graveur (réutilisation possible pour d'autres Fw)
NB : n'utilisez pas un DVD-R ou un DVD-RW : cela ne semble pas fonctionner
Ouvrir NERO 6.x
[CD]
[Copier et Sauvegarder]
[Graver une image sur disque]
Choisir le fichier Firmware que vous avez téléchargé : xxxx.iso
[Ouvrir]
Onglet [Burn]
- Cocher [Write], [Finalize CD], et [Buffer underrun protection]
Choisir pour [Write speed] : le plus lent possible
Choisir pour [Write method] : Track-at-once
Dans la fenêtre de copie en cours :
- Verifier : "Writing file CD-ROm Mode 1 Iso 9660"
Cocher : [Verify written data]
Quittez Nero
Lire le CD RW : un seul fichier visible : xxx.bin
Dézonner en toutes zones (zone 0)
entrez "0" au code région pour mettre le lecteur en toutes zones
[Setup] pour sortir
( Manoeuvre Old RC -> New RC et New RC -> Old RC )
But : Codes de la télécommande en cours -> Codes de la télécommande ancienne Oppo/BBK et réciproquement
exemples :
Black US -> Silver
Black blue-ish -> Black fat
etc..
- 1. Allumer le lecteur et l'écran
2. Fermer le tiroir (vide)
3. Attendre le msg "No Disc" en haut à gauche de l'écran
4. Appuyer et maintenir très fermement la bouton STOP du panneau avant du lecteur (pas celui de la télécommande), durant 5 secondes puis relachez.
5. Un msg "Old RC" apparaît brièvement en haut à gauche de l'écran
5bis. Si vous repêtez la manip, vous revenez alors à l'état initial :
Un msg "New RC" apparaît alors brièvement en haut à gauche de l'écran
** Setup pour la lecture de DVD **
(Merci pour tout complèment ou correction)
-(1)- Setup en fichier Word, recommandé par le forum US AVS
- Download:
http://www.avsforum.com/avs-vb/attachme ... ntid=48957
http://www.homecinema-fr.com/forum/down ... p?id=20419
Version Francophone (Merci Cedbh !)
http://www.homecinema-fr.com/forum/down ... p?id=20442
- Fichier Excel de José Hidalgo sur divers setups du Sanyo Z4 branché sur un Oppo / BBK:
http://www.homecinema-fr.com/forum/down ... p?id=20746
Setups : La plupart ne sont possibles qu'en mode [STOP]
[XX] : touche XX de la télécommande
-(3a)- [Setup] General Setup
- TV Display (Normal, Letter Box, Wide) : Wide
OSD lang : French
ScreenSaver (ON, OFF): ON
SCART (YCbCr, RVB): Y Cb Cr (permet en même temps, aussi d'activer les 3 RCA de sortie YUV)
LED Control (On, Off): On
Spectrum : OFF
-(3c)- [Setup] Audio Setup Page
-(3d)- [Setup] Video Setup Page
- Sharpness (High, Medium, Low, none) : Low
Brightness (00+) : 00 (Conseil AVS = -3) mais .. selon le Firmware qui a décalé ou pas la référence du 0 de Brightness..
Contrast (00+) : 00
Saturation : +5
(CSS) : off
TrueLife (DCDI) : off
- TV Type (PAL, NTSC, Auto) : PAL (permet aussi d'avoir les menus en 50Hz)
PBC (ON, OFF) : off
Audio : French
Subtitle (On, Off): Off
Disc Menu : French
Parental (On, Off) : Off
Password
Default
Video Mode (Video 1, Video2) : Video2 si DVD PAL (Z2 en général), Video 1 si DVD NTSC (Z1)
Noise reduction (On, Off) : Off
- [DVI] (576p, 540p, 720p, 1080i) : 720p
[P/N] (PAL, NTSC, Auto) : Auto (ou PAL pour Z2 Pal, Ntsc pour Z1 Ntsc)
[Audio] (Langages dispo sur le DVD) : French
Misologue 26/05/06
- Oppo : OPDV971H.
Firmware : 0302
DVI 720p
Diffuseur : Rétro DLP Thomson 50DLW616
- Sharpness : low
- Luminosité : -4
- Contraste : +2
- Saturation : 0
- True life : OFF
- CCS : OFF
- Noise reduction : OFF
** DIVERS **
MANUELS pour le BBK (en pdf)
- User Manual initial) de l'Oppo-US (19 Mo) (peut servir pour le BBK)
http://www.oppodigital.com/Download/OPD ... Manual.pdf
Nouvelle version (release date : 28 Juillet 2006) de l'user manual (peut servir pour le BBK)
Testez votre BBK
VIDEO
DVD de tests VIDEO (DVD de tests dont on peut télécharger puis graver l'image ISO)
- DVD de Calibration ColorHCFR Version 1.08 bêta, de nos amis de HCFR
Forums Sources :
http://www.homecinema-fr.com/forum/view ... t=29806992
http://www.homecinema-fr.com/Colorimetre/
Download :
** La dernière version 1.08 beta de l'image ISO du DVD de calibration ColorHCFR **
Le BBK pouvant projeter des diaporamas, un setup par mires couleur peut être judicieux
- MIRES RVB
Softs de réglage d'écran (permet de corriger l'overscan)
** NEWS ** (Ordre chronologique inversé)
28/07/06
Info Oppo:
- Oppo Digital US a sorti le Fw 0316
(Telec Black blue-ish & Silver)
(Cf Section Firmwares)
Info Oppo:
Comparing to the official F-0302 release, the improvement included in this version is:
1. Improvement to audio/video synchronization.
2. Improvement to DVI output timing
3. Longer audio delay option.
4. Picture settings applied for PAL mode.
5. Longer file name display in file browsing mode.
6. Proper "Skip Prev" function for CD playback.
7. Support for DivX Video-On-Demand activation.
- LC vient de sortir le Fw. 0315, (2e évolution du 0302 US)
Il est en 3 versions pour les téléc Silver, Black FAT et Black Blue-ish
Il est compatible Péritel ; Menus possibles en Français
Nb : le logo '720p' manque lors du choix des résolutions de la sortie DVI (mais la résolution 720p est OK)
Info LC:
There is no official release text, but you can assume that all oppo fixes like pal synching on varuious displays has been improved in this release just like version 0302 from oppo usa.
- LC a sorti le Fw. 0302_3 pour la téléc Black FAT Cee mais compatible aussi avec la Black blue-ish
Info LC:
This firmware also works with the latest bluish-silver remote
- LC a sorti le Fw 0220_3 pour la téléc Black FAT Cee
C'est un patch du Fw 0220 de Oppo US
- Un nouveau Fw en downoad ches Oppo Digital : OPPO OPDV971H Firmware Release OP971-F-0220
Source : http://www.oppodigital.com/opdv971h_fir ... nload.html
Amélioration de nombreuses fonctions :
Compatible BBK si vous avez la télécommande "Blu-ish Oppo USA style" livrée par OPPO USA et avec les derniers Oppo Cee
La manoeuvre de reset des codes IR permet, comme avec les autres Fw, de garder sa télécommande grise, premier modèle
- les 3 nouveaux Fw sont en download sur LC
Source : http://www.livingcinema.dnsalias.com/ph ... .php?p=166
Silver BKK Remote Firmware OPDV971H-E-1226_2
Black Oppo Europe Fat Remote Firmware OPDV971H-E-1226_3
Blu-ish Oppo USA style Remote Firmware OPDV971H-E-1226_4
- Les nouveauxBBK/Oppo CEE OPDV971H-E livrés après le 17 janvier 206 par LC NL sont désormais livrés avec la télecommande noire bleutée (Bloack Blue-ish) introduite par Oppo USA
Le firmware installé dans les lecteurs livrés est désormais le OPDV971H-E-1226_4 qui est une évolution CEE du 1226, avec adaptation à cette télécommande
La version du Fw affichée est : 1226
Confirmation par un forumeur de LC : la nouvelle téléc livrée est bien le modèle US , "black blu-ish, silver back", avec le Fw 1226 version 4, adapté à cette télec.
La télécommande noire "fat black Oppo/bbk Cee" semble abandonnée, dans le but d'une unification de la gamme
- [color=darkblue]
Post Posted: Thu Jan 19, 2006 12:35 pm
Post subject: BBK OPDV-971H-E remote specific firmwares 12-26-2005
The 1226 firmware has been around for some time giving the next change list:
1. Added ID3 tags for MP3 files.
2. Improved explorer support: 20 supported characters.
3. Added text scrolling (14 shown; 6 scroll)
4. Audio Delay up to 120ms.
4. DVI syncronization error fixed. Image no longer shifts at 720p/1080i.
5. PAL settings are now remembered.
We call the original Firmware 1226.
We changed the original firmware to fix the Turelife text to Truelife. And adjusted the remote options for each remote available.
Since the original 1226 Firmware from BBK we have made releases for:
Your player will show 1226 when you check the firmware number.
There is no use of using any oppo firmware as all firmwares from oppo before 1226 are worse, forgetting settings and no PAL optimisation.
We will make these firmwares available here.
Again if your firmware is running ok or you do not know what to do, don't fix it. Dead players need to be revived by us in the factory, so it is not covered by warranty and costs need to be covered by the customer.
- Le dernier Fw pour BBK à telec grise est retiré du download car Bug
- Le nouveau Fw BBKDV971H-2-1226 (silver rc) va être très bientôt dispo en download ; Revo a fini les tests qui sont OK
- Revo, l'admin de livingCinema NL a reçu le nouveau Fw pour la telec grise BBK , bénéficiant des derniers upgrades (PAL etc.); ce Fw est en test avant publication
- Nouveau Fw 1226 pour les OPDV971-H E à nouvelle telec noire CEE (Fat Black)
- Il se confirme qu'il n'y a plus que 2 modèles en vente sur le marché, tous pays confondus:
- Oppo US OPDV971-H sans Scart, avec cordon US, nouvelle télécommande noire (arrière gris), firmware adapté,
+ bundle:
1*cordon DVI/DVI 1,5m, 1*adaptateur DVI/HDMI, 1*cordon composite, 1 cordon stéreo RCA
- Oppo CEE OPDV971-H E ("E" rajouté au nom) avec Scart, cordon CEE, nouvelle télécommande noire (mais différente de l'US), firmware adapté d'origine BBK; ce dernier modèle est vendu avec la marque Oppo mais correspond en fait, à ce que vendait la semaine dernière, LivingCinema sous la marque BBK
+ bundle :
1*cordon DVI/DVI 1,5m, 1*cordon composite, 1 cordon stéreo RCA
Source :LivingCinema NLPosted: Sat Dec 24, 2005 11:50 am
Hi Jean Max,
There a currently 2 models,
1: the oppo from oppo usa, usa plug black silver remote, available from USA only.
2: the oppo from bbk europe. We call it the opdv971h-e, it has scart and euro plug, and a bit bigger new remote.
Unfortunately it has a different remote key mapping. BBKOppo production facility in china has promised to release the next firmware for both models!
