Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 27 invités
Tout ce qui ne rentrait pas dans les catégories ci dessus lors de la réorganisation ;)
Par ailleurs, il n'est pas possible de créer un nouveau sujet : merci de le faire dans un autre forum.
theatertek 2.2 est sorti
Message » 17 Oct 2005 8:35
voici une liste des fixes/nouveautes :
Fixes:
- Command line parsing should be much improved.
- Aspect ratio settings were not always correctly remembered.
- AutoKiller will only intercept DVD's and not other media.
- Unplugging removal storage devices will not stop TheaterTek.
- An assortment of other miscellaneous fixes.
- WMV-HD files would sometimes not playback correctly.
New Features:
- New nVidia decoders which are fully compatible with MCE 2005 Rollup 2
- Updated WMV-HD library for compatibility with the latest WMV-HD titles.
- Improved WMV-HD performance.
- Improved scaling in VMR9 'Fullscreen' mode.
- Support for several new file types including:
Microsoft .dvr-ms files from MCE, NERO encoded mp4 files, .wpl Windows Media Playlists
- FFDShow is now allowed for all file types excluding WMV-HD files. NOTE: If you currently use FFDShow you MUST prevent it from resizing high definition playback. To do this, change the Resize Always option in FFDShow's tab to set maximum X and Y image size properties. If you don't do this then you're unlikey to play HD files successfully.
- New audio post-processing option. This is of primary benefit to those using analog output as various third party post-processors can now be used for effects such as room adjustments, frequency control.
- New Media Browser. The Media Browser works in all modes including VMR9 exclusive mode to allow you to browse and open files. It's very intuitive and will even show cover-art if it detects graphic files associated with media. If you prefer the Windows file browser you can override this in the Configuration dialog. You can also define the file types the Media Browser recognizes in the File Types tab of the Configuration dialog to avoid sifting through irrelevant files.
- On a new install, TheaterTek will now use the graphic card default color values until you override them. (If you already have defaults set, remove your color related registry values under HKLM\TheaterTek\TheaterTek DVD 2.0)
- Mouse hiding: This has been improved further but setting the Mouse Timeout to 0 will completely disable the mouse unless you need to access the Configurstion dialog. This is perfect for remote control users.
- iMon remote support. A new file for iMon users is in the Remote Control folder inside the TheaterTek folder.
- The AR editor now supports time-sensitive acceleration when you're trying to use the resize arrows when defining a new aspect ratio.
- New on-screen blanking editor to allow per-DVD adjustments of blanking. This is available on the Aspect Ratio menu both by right-clicking or selecting the AR menu on the top menu Status bar.
- Lip sync is now adjustable on a per-DVD basis.
- Aspect ratios can now be associated with different media types. So you can for example set an AR for transport stream or WMV-HD playback.
- The nVidia decoder system tray is no longer disabled, although we recommend you DO NOT adjust values while TheaterTek is running as all features of the decoders can be accessed directly in TheaterTek.
- New time bar. The new time bar has been re-designed to offer better visual feedback and provide significantly improved shuffling capabilities. Non-DVD media playback can now be shuffled with either a remote, the keyboard, or the mouse. For remote users, just bring up the time bar (Down arrow), then use left and right arrows to move among the media.
- The Status top bar now works for all media types to give access to aspect ratio control. The DVD Status bar also now allows you to select the Title and Chapter nuggets and produces a scrollable drop-down menu for easy chapter selection. Naturally this all works in FullScreen mode.
- The last top bar menu that was chosen is now remembered, so if you were adjustng color controls and the bar faded out out, bring the bar back up will take you right back to video adjustments.
- There is a new command line option to start TheaterTek in windowed mode. /Fullscreen 0 will start TheaterTek in windowed mode.
- The onscreen graphics are much more responsive to mouse or remote/keyboard commands.
- The 'Back' arrow on the MCE remote is a way to exit out of TheaterTek via a prompt first.
- TheaterTek no longer manipulates the anamorphic setting which caused MCE users problems when switching between TheaterTek and MCE TV functions.
- Multi-channel WMA files are now supported.
des que j'ai 5 minutes je vous parlerai plus longuement de l'audio postprocessor ...
vairulez
Inscription Forum: 03 Fév 2002 2:00
Message » 17 Oct 2005 8:55
you're welcome :wink:
le touriste
Inscription Forum: 31 Juil 2005 13:13
Message » 17 Oct 2005 10:45
Merci pour l'info !!!
Ps : en plus maintenant il y a une version trial en download ...
a+
Jcb
JcB84
Inscription Forum: 18 Nov 2003 18:50
Message » 17 Oct 2005 11:02
ou ça,ou ça ? un lien please! :wink:
merci et à+
le touriste
Message » 17 Oct 2005 11:18
Lansing
Inscription Forum: 23 Mai 2005 21:01
Message » 17 Oct 2005 11:33
:mdr: merci quand meme.google n'avait rien donné chez moi!à+
le touriste
Message » 17 Oct 2005 12:01
est il possible comme sur zoomplayer d'appliquer des filtres comme la nettete a travers ffdshow
ou y a t'il des filtres dans le soft lui meme
Merci a tous
micawais
Inscription Forum: 14 Juil 2002 12:01
Message » 17 Oct 2005 12:36
il permet de faire tourner ffdshow en post-processing et un autre filtre nommé nvidia video post processor
lester.raphael
Inscription Forum: 21 Avr 2004 19:13
Message » 19 Oct 2005 10:18
Et alors, comment il marche ce TT2.2??
Sinon, un bug sur le TT 2.1
Lorsque je lis un DVD "reel" ca marche. Par contre si je fais une image iso montée sur Daemon Tools, lorsqu je lance TT, impossible de demarrer en 16/9 :o
Il faut faire chapitre precedent pour qu'il le mette "bien".
Une idée??
Et au fait, t'as pensé a utiliser la fonction Rechercher ??? ;-)
henri66
Membre d'Honneur
Membre d'Honneur
Inscription Forum: 07 Déc 2001 2:00
Message » 19 Oct 2005 11:30
j'ai jamais eu de pbs de lecture, que ce soit a partir d'image, a partir de rip ou a partir du lecteur dvd.
ton pb doit se situer ailleurs.
vairulez
Message » 19 Oct 2005 12:40
Est-ce le meilleur logiciel pour lire les dvd?
maximus007
Inscription Forum: 17 Sep 2005 10:35
Message » 19 Oct 2005 13:26
Oui, incontestablement. Les seuls bugs gênants ont été corrigés.
Lansing
Message » 19 Oct 2005 13:29
Si Lansing le dit, je vais tester !!! :wink:
NEW mars 2024 :
kazuya
Pro-Divers.
Pro-Divers.
Inscription Forum: 19 Oct 2004 16:37
Message » 19 Oct 2005 14:55
savez-vous ce qu'apporte le nvidian video post-processing ? je n'arrive pas à voir de différences avec ou sans.
lester.raphael
Message » 19 Oct 2005 16:14
le nvidia post processing sert uniquement pour les cartes ati, les cartes nvidia faisant ce que fait ce post processor en hardware.
le nvidia postprocessing sert a faire du cadence based 3:2 pulldown
vairulez
Retourner vers Archives
