Je viens de recevoir pour test, le nouveau modèle home cinema de la marque VIVITEK, le 5080 dont voici les spécifications :
2 optiques sont disponibles
* Native 1080p (1920x1080)
* 1600 lumens and 25,000:1 contrast ratio
* DLP® DarkChip3™ and BrilliantColor™ technologies from Texas Instruments
* Manual lens shift (vertical/horizontal)
* Interchangeable lens options to accommodate different home theater settings
* 3000 hours of lamp life; Whisper-quiet at 28dB
* Connectivity options include: Three (3) HDMI v1.3, VGA-In, Component, S-Video, Composite
* RS-232c for one-touch automation and 12V trigger for simple screen/projector automation functionality
* Specifications
* Downloads
* Accessories
* Distance Calculator
* Warranty
Display H5080
Brightness 1600 Lumens (Typical)
Native Resolution 1080p (1920 x 1080)
Contrast Ratio 25,000:1 (Full On/Full Off)
Lamp Life and Type ≈3000/2000 Hours (Standard/Boost Mode),
280W UHP
Lamp Part # 5811116085
Display Type Single 0.65" DarkChip3™ DLP® Technology by Texas Instruments
Throw Ratio 1.54 to 1.93:1 (Distance/Width)
Image Size (Diagonal) 37” to 300” (0.9 to 7.6 m)
Projection Distance 4’ to 30’ (1.2 to 9.1 m)
Projection Lens F=2.5 - 3.1, f=28.5 - 42.75 mm
Zoom Ratio 1.25:1 Manual Zoom/Focus
Aspect Ratio 16:9 Native, 4:3 Compatible
Keystone Correction ±15º Vertical
Color Spectrum 1.07 Billion
Horizontal Scan Rate 15, 30 to 90 KHz
Vertical Scan Rate 50 to 85 Hz
Projection Method Table Top or Ceiling Mount (Front or Rear)
Lens Shift Vertical: ±10%, Horizontal: -40% to +120%
Uniformity 85%
Computer Compatibility 1080p, UXGA, SXGA+, SXGA, XGA, SVGA, VGA Resized; VESA Standards; PC and Macintosh Compatible
Video Compatibility NTSC (M, 3.58/4.43 MHz), PAL (B, D, G, H, I, M, N), SECAM (B, D, G, K, K1, L), HDTV (720p, 1080i/p), EDTV (480i/p, 576i/p)
I/O Connection Ports HDMI v1.3 (x3), VGA-In, Component Video, S-Video, Composite Video, 12V Trigger (x2), RS-232c, USB (Service Only)
Security Kensington® Lock Port, Security Bar
Weight 19 lbs (8.6 kg)
Dimensions (W x H x D) 16.9" x 7.1" x 13.5" (429.3 x 180.3 x 342.9 mm)
Noise Level 28dB (Standard Mode)
Power Supply: AC Input 100 - 240V
Consumption: 310 Watts (Standard Mode), 370 Watts (Boost Mode), < 10 Watts (Standby Mode)
Operating Temperature 41 to 104°F (5 to 40°C), 80% Max Humidity
Standard Accessories AC Power Cord, Component Cable, Remote Control, Batteries for Remote, Lens Cap, User's Manual (CD), Warranty Card
48 messages • Accèder à une page • 1, 2, 3, 4
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 139 invités
NOUVEAU VIVITEK 5080 DLP DC3 FULL HD 120HZ
- worf
- Broker
- Inscription Forum: 25 Juin 2002 16:37
- worf
- Broker
Bonjour Greg,
Combien pour ce projecteur assez prometteur ?
(il faudrait qu'il soit au dessous des 2000)
- LCD 31
- Inscription Forum: 16 Sep 2006 9:48
Effectivement à ce prix là ce serait royal, mais le prix public est de 3200 euros, soit 700 euros de moins que celui de l'optoma HD86 qui est moins performant que le vivitek (et pourtant ils ont les mêmes gênes ).
- worf
- Broker
"whisper quiet @ 28db"
J'adore.
C'est du murmure de film de boules, ça. .
Xavier.
J'adore.
Xavier.
- tobal
- Inscription Forum: 13 Sep 2001 2:00
tobal a écrit:"whisper quiet @ 28db"
J'adore.
Xavier.
Excellent .
- lcartau
- Inscription Forum: 26 Oct 2004 17:40
Si, comme je le pense, ce VIVITEK n'est que le clone quasi-parfait du HD86, les 28dB (m$eme si c'est le bruit en mode bas) est largement supportable. Pour avoir la référence en silence (HC7000), les fréquences émises par l'OPTOMA ne sont pas génantes pour l'oreille.
Une question pour Greg, que je remercie pour son CR : Pourquoi ne peut-on pas utiliser le VIVIMotion quand on lit un DB à 24hz ? Cela saccade ?
Autre test : La restitution DB à 24Hz est-elle fluide, SANS le processeur PureMotion engagé ? (C'est une horreur sur le HD86 ...)
- alcatol
- Inscription Forum: 14 Fév 2002 2:00
alcatol a écrit:Si, comme je le pense, ce VIVITEK n'est que le clone quasi-parfait du HD86, les 28dB (m$eme si c'est le bruit en mode bas) est largement supportable. Pour avoir la référence en silence (HC7000), les fréquences émises par l'OPTOMA ne sont pas génantes pour l'oreille.
Ha ba ayé je l'ai traumatisé l'alcatol : il met des DB partout maintenant !
Xavier.
- tobal
worf a écrit:Effectivement à ce prix là ce serait royal, mais le prix public est de 3200 euros, soit 700 euros de moins que celui de l'optoma HD86 qui est moins performant que le vivitek (et pourtant ils ont les mêmes gênes ).
Le nouveau prix du hd86 est de 2999€ donc moins cher que le vivitek...
- Puma
- Inscription Forum: 13 Sep 2002 22:32
Et bien la concurrence a du bon
- worf
- Broker
Worf, tu as pu vérifier le point évoqué plus haut : A savoir la lecture parfaitement fluide d'un BD en 1080P 24hz sans utiliser le processeur VIVIMotion ?
Egalement, pourquoi on ne peut pas utiliser le processeur avec le même paramétrage ? Des saccades ? Quel genre ?
Le VIVITEK est maintenant plus cher que son cousin l'OPTOMA, espérons au moins qu'il est mieux "programmé" ...
merci par avance,
Alcatol
merci par avance,
Alcatol
- alcatol
Bon ... On constate que, décidément, les DLP Full HD ne déclenchent pas l'hystérie des forumeurs ...
J'ai trouvé l'importateur français à partir du site VIVITEK : COMIL. J'ai envoyé un email vendredi dernier, demandant leur mode de distribution en france ... Pour le moment aucune réponse !
Qui d'autre l'a vu, va le recevoir pour tests et démos ?
Va-t-il finir (maintenant qu'il est plus cher que son grand frère, pour des performances apparemment très similaires, et/ou pas meilleures) aux oubliettes, comme l'est un peu le HD86 ?
Dommage ... Aux quelques problèmes reportés auparavant (Pb fluidité en 24Hz sans processeur : un comble !), ce DELTA Inc. bi-badgé me plait décidément bien ...
- alcatol
Je te le répète, Alcatol : outre le prix (bah voui les gens voient des sammy à 900 roros qui ne semblent pas "très loin"), 28db ça décourage les personnes potentiellement intéressées.
C'est énorme comme bruit quand on a pris l'habitude de machins qui ne dépassent pas les 22db voire moins (le tien par exemple) et qu'on les à +/- 2m de la position de visionnage.
Xavier.
Xavier.
- tobal
Tobal, tu veux parler du Samsung SP-A600B ?
Pas de lens-shift, pas de 120hz, 1000 lumens : Machine basique au prix logique ! Le HD86 et le 5080 ont d'autres prétentions il me semble.
Quand au bruit, je rappelle que c'est 28dB en mode haut, 23 en mode bas, et que, moi qui suis habitué à mon inaudible HC7000, les 23dB ne sont pas plus dérangeants que cela car bien placés en fréquence.
- alcatol
48 messages
• Page 1 sur 4 • 1, 2, 3, 4
