Edit:
oncle_zamus a écrit:Hello,
à tester, mais apparemment moins de prise de tête avec cette méthode en installant : LAV Filters 0.26
copier le fichier "dtsdecoderdll.dll" de votre répertoire TMT 3 ou 5 dans le dossier LAVAUDIO
et normalement ça marche
En anglais ça donne ça
source
http://forum.doom9.org/showthread.php?p ... ost1501113
LAV Filters 0.26
Code:
General
- The VC2010 runtime is no longer required to be installed
LAV Splitter
- Further VC-1 in MKV improvements
- Added a separate "mpegvideo" (m2v files) option to the Format section
- Added a flag for secondary audio streams
- Changed the default DTS media type (better compatibility)
LAV Audio
- Added the ability to use the ArcSoft DTS decoder directly through LAV Audio
- Added an automatic algorithm to keep A/V sync stable
- Improved Bitstreaming with splitters other then LAV Splitter
- Improved timestamp generation when bitstreaming
- Fixed LPCM 24-bit Media Types
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Using the ArcSoft DTS decoder
LAV Audio can now directly interface with the ArcSoft DTS decoder. You do no longer need any complicated setup or installation.
To use the ArcSoft decoder in LAV Audio, simply get the "dtsdecoderdll.dll" from your TMT3/5 Codecs directory, and put it in the same directory as LAV Audio.
Thats all you need to do, no configuration, no hacked checkactivate.dll, no extra filter to be used.
When playing a file, you can see if its being used on the "Status" page of the LAV Audio propertys sheet. "dca" is the ffmpeg based decoder, "dts" (and any variations of that) is the ArcSoft decoder.
This will allow you full decoding of DTS-HD MA and all other variations of DTS.
One thing, though.
Do NOT ask where to get the ArcSoft decoder. If you own TMT3 or TMT5, it will be in the TMT Codecs folder. If you do not own it, you should buy it. I respect their work, and so should you!
Bitstreaming Improvements
Bitstreaming should now work much better with other splitters. Note that there is still one limitation however, TrueHD only works properly if its actually flagged as TrueHD, and the interleaved AC3 was removed. Therefor, it will most likely not work with Haali and the MPC-HC/Gabest splitters.
As always, please report any regressions or still persistent bugs directly here, with all the relevant details, and if possible a sample file.
vivement ce we que je teste ça !!!
