Modérateurs: Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 33 invités
Pro Control Releases OLED & LCD Touchscreen Remotes
Message » 15 Sep 2012 19:17
Voici une future télécommande "best have".
Site éditeur : http://procontrol.com/
http://www.remotecentral.com/news/505/pro_control_releases_oled_&_lcd_touchscreen_remotes.html
Le couple Pro24.z and ProLink.z a été récompensé en 2012 par le RESI et le CEPro.
Programmable 5-way joystick Yes
RF frequency Bidirectional Zigbee (2.4 GHz)
Compatible with Pro Control processor ProLink.z
Recharging cradle Yes
USB recharging cable Yes
USB programming Yes
Control via IR Yes
Full color touchscreen display TFT LCD
Battery type Lithium-Ion
Number of commands and macros allowed Unlimited*
Wizard-based programming Yes
Number of controlled devices Unlimited*
Customizable graphics via programming software Yes
Integrated tilt switch automatically turns on backlight Yes
Screen size (inches) 2.4
Screen resolution (pixels) 240×320
Number of programmable hard buttons 48
Dimensions H x W x D (inches) 9.79 x 2.23 x .9
Supported remote control Pro24.z or iPro.8
Support for iPad®, iPhone®, iPod touch® app Yes
Support for virtual PC control Yes
Support for 2-way feedback from compatible device Yes
Integrated RS232 ports 2
Ethernet control Yes
Ethernet for programming Yes
Adjustable IR output strength Yes
Integrated IR routing ports 6
Voltage sense inputs 2
Integrated RF control Bidirectional Zigbee (2.4 GHz)
System commands and macro storage Unlimited*
Integrated antenna Yes
USB programming Yes
Dimensions H x W x D (inches) 4.1 x 9.49 x 1.28
Adhara
Inscription Forum: 12 Jan 2009 22:29
Message » 20 Sep 2012 10:36
Belle télécommande en effet, mais il va falloir trouver le logiciel de programmation et c'est pas gagné !
Idargos
Inscription Forum: 25 Avr 2009 18:02
Message » 20 Sep 2012 13:06
Idargos a écrit:Belle télécommande en effet, mais il va falloir trouver le logiciel de programmation et c'est pas gagné !
Le soft est fourni avec.
Ce n'est pas comme pour pronto ou il y avait une version "customers" et une version "pro" du logiciel.
Adhara
Message » 20 Sep 2012 13:22
Tu es sûre de ça ? Parce que apparemment c'est une version spécifique du soft des télécommande RTI qui lui est introuvable.
Mais si effectivement c'est bien le cas, je risque de m'intéresser fortement à cette télécommande.
Idargos
Message » 20 Sep 2012 20:25
franchement cette telco ça l'air d'etre une bombe!des touches physiques,des touches de couleurs un ecran lcd tactile de qualite et personnalisable.reste a svoir le prix quand on voit les prix des telcos rti j'imagine le pire!apres il faut voir au niveau du logciel car moi a part logitech je n'y connais nada
micha1978
Inscription Forum: 09 Sep 2009 21:33
Message » 20 Sep 2012 23:04
De tête il faut que je vérifie, ça doit être 570€ chaque élément.
kiteur27
Pro-Commercant
Pro-Commercant
Inscription Forum: 20 Oct 2007 18:26
Message » 21 Sep 2012 9:16
USD400 chaque, j'avais pas fait attention au prix.
C'est cher je trouve. A comparer avec un système Nevo ...
Adhara
Message » 07 Oct 2012 13:37
Logitech est en train de louper le virage !
très intéressante cette Telco
j'ai linké ce sujet avec la compil de Telco AIO que j'ai faite ici dans le 1er message de ce sujet
blues93
Inscription Forum: 08 Nov 2010 16:59
Localisation: XTreamer MK1, Harmony 900/700/300/200 +Blaster_RF to IR +PS3Ext_IR to BT, TS-509Pro +SB_Touch
Message » 09 Oct 2012 21:15
400 dollars la télécommande ET 400 dollars le boîtier RF = 800 dollars
whech! c'est pas donné ...........
edit : trouve sur un site qui annonçait ces produits
Pro24.r → $249
ProLink.r → $249
Pro24.z → $449
ProLink.z → $449
ShreckBull
Inscription Forum: 19 Juin 2008 13:39
Message » 11 Déc 2017 12:26
Bon je remonte un peu le sujet vu comment c'est calme au niveau des télécommandes universelles :
A priori la 24r (et non pas la 24z) est disponible chez Futureland
A voir si elle est bien fournie avec le logiciel de programmation par contre!
domin
Administrateur Suppléant de l'Association - Vice-Président & Superviseur Forum Home Cinema
